Like Tree5Likes
Old 09-11-2005, 10:48 PM   #12796
fjm9898's Avatar
mine has been on back order for 3 weeks, just grab the 2mm for now.
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 09-12-2005, 12:42 AM   #12797
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally Posted by josh69162
Does anyone have the Hara upper deck in stock? Nothing shows up on Tower...
-Josh
pretty sure none of the hara parts are actually avail in the US. horizon, tower, stormer, etc...none have ANY of the new parts (shock bladders, upper deck, motor mount, etc)
floodo1 is offline   Reply With Quote
Old 09-12-2005, 06:53 AM   #12798
dizzy1's Avatar
Trader Rating: 24 (100%+)
JW- My steering rack rubs sometimes to. Just sand it slightly and also make sure to align the arm blocks since they were designed to move slightly. Usually just loosen the back one slightly and move it close to the front and tighten it back down. Then you shouldn't have any more rubbing.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 09-12-2005, 08:39 AM   #12799
rc-zombies's Avatar
you are right...
most of the new '05 option parts are available overseas.
I purchased my new upperdeck, shocks, and motormount from RainbowTen in Japan... RcModel may have some of them now too...
Old 09-12-2005, 01:34 PM   #12800
Oasis's Avatar
Trader Rating: 36 (100%+)
I saw a Hara about a month ago..looked cool..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 09-12-2005, 01:35 PM   #12801
rc-zombies's Avatar
at Speedworld? that's either mine or my bros...
Old 09-12-2005, 01:51 PM   #12802
Thanks gentelman! I followed your advice, and the problem is cured!
Once again, I appreciate the help!!!!
John Warner is offline   Reply With Quote
Old 09-12-2005, 03:01 PM   #12803
josh69162's Avatar
Send a message via AIM to josh69162
What exactly is the difference between the Hara/'05 deck and the standard deck. The Hara/'05 is 0.25mm thicker, right?
-Josh
josh69162 is offline   Reply With Quote
Old 09-12-2005, 06:08 PM   #12804
cartmen34's Avatar
-Josh
I believe the Hara deck also has holes drilled at the front and rear middle mounting points instead of actually mouting points. This helps prevent the car from holding a tweak as easily as the original version. It also includes the o-ring fix which help the tweak thing as well.
cartmen34 is offline   Reply With Quote
Old 09-12-2005, 08:22 PM   #12805
newracer's Avatar
R/C Tech Charter Subscriber
The Hara deck is also thinner and has more cut out of the middle
newracer is offline   Reply With Quote
Old 09-12-2005, 08:38 PM   #12806
Hi Chad, thanx for the reply. I have an out the box pro4 with foams running on carpet, & its as good as anything out there. I am looking at purchasing a Hara pro4 to be set up for bitumen racing only. I run in stock & soon 19 turn classes.I was going to fit a 2mm chassis to this car to help with a little traction, either that or save some coin for a cyclone, but I like the pro4.
One last thing, fitting 3700's into a pro4, anyone successfully done this & if so what is the best way ?
Thanx guys
jim beam is offline   Reply With Quote
Old 09-12-2005, 08:40 PM   #12807
ngo8's Avatar
Send a message via ICQ to ngo8
ok what is exactly the O-ring mod wherew does it go ?
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 09-12-2005, 08:41 PM   #12808
ChadCapece's Avatar
Thanx guys
I was thinking about that the other day. What I might do is cut out rectangle slots where the current slots are. Then buy a Yokomo battery tray and glue it in.
ChadCapece is offline   Reply With Quote
Old 09-12-2005, 09:02 PM   #12809
cartmen34's Avatar
Get some coutersunk washers, 2 button head screws, and 2 o-rings (same as shock o-rings.) Turn the coutersunk washer upsidedown on the button head screw, then place the o-ring inside the washer. Once the buttonhead screw is through the washer and the o-ring, then thread the screw into the top of the upperdeck in place of the original steering rack screws. Don't tighten the screws down completely. Just get them close so that the o-ring can flex when the chassis does.
Take a look at some pics of the 2005 Hara edition's steering rack upperdeck mounts and you'll get the idea.
Old 09-12-2005, 09:14 PM   #12810
cartmen34's Avatar
Speaking of the o-ring mod, has anybody tried at Hara-spec upper deck on carpet?
I'm currently using a BMI 3mm main chassis and upperdeck on my carpet Pro4, but I usually have a tweak problem after a slight tap on the boards. Usually it not too bad and I can just drive around it (albiet more slowly!), but it is still annoying to have to re-set my car in the pits after every tap-o-the-boards.
I know the general idea behind the Hara spec upper deck is for lateral flex, but will this flex do more hurt than help on carpet?
