Hpi Pro 4
#1261
as promised, here are some pictures of the Pro 4 with rear derlin outdrives similar to the cuda's.
enjoy!
enjoy!
#1262
I tried to wait for the pro 4 to be released, but I kinda lost interest over the last couple months, and decided to buy an R40.
Does anyone know the U.S. release date?
#1263
hi all,
i just tried out my pro4 yesterday, only managed a pack before the weather puts a stop to any further testing.
the car is setup as per manual, very smooth and easy to drive, but a tad lazy in the corners though. the drivetrain is very quietand smooth, that my fren thinks its a belt car. next step is to try a bit harder spring sets on it. i'll be using my xray evo2 springs, as they fit the spring holders nicely and almost the same length as the kit springs, only about 1mm longer.
i noticed that i have to tone down the steering dual rate a bit so as not to let the front wheels touch the lower shock mounting point, and loose out on some slow cornering radius. so any good ideas from all you pro4 owners to solve this? thanks...
#1264
2 of Pro4 beat Surikarn's 415 in one of modified race in Thailand
http://www.rcspirit.com/html/article...&mode=&order=0
#1265
Pro 4 at Snowbirds
I'll be trying my Pro 4 at the Snowbirds over the next week. I'll post how the car performs as soon as it gets some track time. Also the car did great for it's first outing on the pavement, TQ with the kit setup (less the swaybars).
#1266
Re: Pro 4 at Snowbirds
Ill be over in the evening Ill try and help you out.
#1267
Originally posted by alana07
hi all,
hi all,
#1268
do the evolution 3 surikarn special white rear diffs fit the pro4?
#1269
Pro4 gearing
Out of interest, to anyone thats got the Pro 4, could they tell me what spur gear size is included (how many teeth) in the kit and what is the pinion, if there was one? Also the weight of the shock oil that was included, as this will help me the little bits and pieces i need.
Thanx
Still waiting in the UK for the Pro 4 !!!
Thanx
#1270
Re: Pro4 gearing
Thanx
Thanx
no pinion.
50wt oil is included
#1271
gearing
Thanx 4 that much appreciated.
#1272
SQUARE OPTION PARTS
Looks like Square has put more option parts..
shock towers, front graphite bumper support and the part everyone will sure to get the purple alum. transponder/servo mount...
http://www.rc-square.com/parts22.htm
I just received the Ti input shafts...very light!
front weighs in at 1.65g vs. 3.1g stock
Rear is 3.04g vs 5.6g.
the HPI graphite drive shaft is very light as well..
And Finally... my Beveled gears have arrived as well...
I can finally run the car...
no more overcooked gears...
#1275
Just a couple of quick questions to all the learned Pro4 drivers out there.
1. Do all 64P Pinion gears fit on the Pro4 or do you have to purchase a particular brand.
2. What type of Pinion spur combination are people using out there?
Cheers!
Cheers!
