Hpi Pro 4
carpet setup
what would you guys use for a some what tight carpet track, and ill be using a stockmotor.
With the optional camber link mounting holes, what would the handling difference be if I mounted the inner link further back? You know how the graphite camber mount has the four holes, in a two by two formation? I'm just wondering what the difference would be in having the camber link more/less parallel on the verticle plane...
-Josh
-Josh
-Josh
-Josh
the reason why the holes are not in a straight line (a la tc4) is that the extra holes are "half holes" taht is they are half way in between the other holes. naturally you cant overlap holes and still have strength so they just put the middle holes farther back (or forwards).
so only worry about where they are in/out not front/back.
Originally Posted by fjm9898
try any of these, only do one change at a time, and if you still need more go to my next suggestion. 6 degree c-hubs, and 2.5 degree front pivot block. 2 degree camber front and rear. softer front spings. 1 degree tow out on the front, wheels look like \ / only not to eh that extreme, only one dgree or so. having the wheel like the that will help the inside tire pull the car through the coner more. if you do all that and still cant get teh thing to turn then i dont know what is wrong.
Will let you know how goes.
Originally Posted by kewdawg
Go over the front end of the car, CLOSELY. I bet you've overlooked something.
Will try out suggestions tomorrow, thanks for all help.
On the Pro4 floodo1 is making my Pro4 very fast.. A bit more and it will be dialed.I ran pit 30's on carpet last night and was hooked up in the main in 19 turn,Thanks Josh,I was about to give up on my Pro4..
just wait man, i plan on having the pro4 dialed beyond belief!
has anyone else run pits on carpet with any success? i HEAR they are THE ticket for rubber on carpet, but i have no experience with them myself.
also does anyone know of a source for them?
thanks
eek 30 bucks at tower... anyone know where to get the 6mm ones for cheaper?
Originally Posted by jamescam
RCMart has them for $19 but you have to jump through hopes if you are a new customer. Anyone know any other places to buy?
Originally Posted by rc-zombies
clamping hex hubs... try Integy.
Thanks for all help, much appreciated!
Do these fit? http://integy.automated-shops.com/cg...58105002153.08
so what tickness should i get? the 5mm?
yes... I've purchase several others of those in various thickness to I don't have to use the washer spacers.
floodo1..My car was really fast today.. 10.4's,changed bodys,tried a nemesis today,really freed up the car..
I'm going to ask a silly question..........
How fragile is the Pro4? Is it sturdy, or do you find it to break suspension parts easily?
Thanks!
Thanks!
