Hpi Pro 4
TC3's are just as bad. Not sure how the TC4 bones work, or if there even different.
MIP TC3 shiny universals work good up front. All you would need is the bones to make the conversion. Even if you take a major hit and bend one, you can always bend them back.
Can someone mention a good site for Pro 4 parts? LHS has a limited supply. SpeedTechRC was out of the main parts I was looking for.
i usually get mine from www.rcmodel.hk they usually have alot of pro4 besuides some of the new popular 05' parts. but if you only need one part and fast you probably shouldnt use them because they are in hong kong so shipping cost a bit more.
but they are usually really cheap. Example: all the LHS i have been to sells c-hubs for $11-12 but rc model its only $6
so if you grab a few things the low priced usually make up for shipping costs
towers not bad if you spend close to 149, then you get $25 off.
I've been looking for a part number for the aluminum camber mount. I would like one, Tower doesn't have them. Any part #'s I can research?
-Josh
-Josh
Trader Rating: 102 (100%+)
Selling my Pro4
Hey guys if anyone is interested i'm selling my BMI Pro4.....
here is the link:
BMI PRO4 - Carpet Ready
asking $245 shipped....tons of spares.
here is the link:
Try Speedtech for the camber mounts.
Originally Posted by josh69162
I never have ever liked HPI's CVDs. Even if you don't bend them, you're garunteed to twist them. Is there really any way to avoid it, or do I need to keep stocking up on the TC3/4 bones?
-Josh
-Josh
The big dawgs are much thicker but seem to perform very well. They are still aluminum like the stock bones but much more durable.
setup
thx for the setup advice guys, i already have the 2mm chassis so i'll yank off the swaybars and give it a try. Going to d\l Hara's setup and check it out too.
-Josh
-Josh
old school hpi guys help me out!
the pro4 has narrow clamping hubs to which you add 0.5 and 1.0mm shim. i know that hpi made the same clamping hubs but in a widht that was wider, specifically the same thickness as the thin hub with 1.5mm of shim !!
i saw these on someones car and i measured them.
anyone know the part number? or can venture a guess?
i cant seem to find it out
