Like Tree6Likes
Old 08-28-2005, 04:19 PM   #12646
vulso's Avatar
Originally Posted by Skill
The version 1.1 gears diff slightly to the first version gears. First of all the small gear is backed with plastic, and the larger gear has a "step" to it on the back whereas the older gear just gradually goes inwards.
Thanks needed that info.
I fixed by the way. I shimmed the diffs on the wrong side which pushed the ring gear away from the bevel gear. I'm such a moron. Thanks for every bodies help.
vulso is offline   Reply With Quote
Old 08-28-2005, 04:27 PM   #12647
vulso's Avatar
Thanks for the info really needed that.
I finally fixed the problem. It turns out that I shimmed the diffs on the wrong side which in turn pushed the ring gear away from the bevel and that caused the clicking.
I'M A MORON!!!!!!!!!! Thanks for everybodies help.
Old 08-28-2005, 07:08 PM   #12648
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
as for shimming i'd consider it unlikely that the directions have the proper shims for your car speficically. that is to say that you should manually shim the car.
start with the diff (or oneway or spool) with no shims, then add shims to one side until the bearings dont move (the diff will still have a LITTLE movement due to the inner race moving), but still spins freely. this will give you the total shims needed.
then start adjusting where those shims are to get the mesh correct. i've had good luck setting mine with as little play as possible, but no binding.
even though the copper shims are thin, they can still make a big change, so take your time!
floodo1 is offline   Reply With Quote
Old 08-28-2005, 10:50 PM   #12649
nordheim's Avatar
Default Pro 4 CVD BONES
Any recommendations to replacement CVD BONEs in the Pro 4 and where to get them? The purple aluminum ones which comes in the kit are so soft that I bent one first time on the track.
nordheim is offline   Reply With Quote
Old 08-29-2005, 01:25 AM   #12650
Skill's Avatar
The Titanium Racing Worlds Editions are very strong, and light...
Skill is offline   Reply With Quote
Old 08-29-2005, 06:28 AM   #12651
Oasis's Avatar
Trader Rating: 36 (100%+)
And we can get them from...
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 08-29-2005, 08:23 AM   #12652
rc-zombies's Avatar
the cheapest route is the TC4 HD aluminum dogbones...alot stronger than the TC3 steel bones. it's a direct fit. only down side is it's blue
Old 08-29-2005, 08:25 AM   #12653
DWill_996's Avatar
Default cs 27
any setup advice for running cs-27 on med-low grip parking lot track ?
DWill_996 is offline   Reply With Quote
Old 08-29-2005, 08:39 AM   #12654
floodo1's Avatar
at least from schumacher.
man awhile ago i asked someone to show me pics but no one did
Old 08-29-2005, 11:31 AM   #12655
ChadCapece's Avatar
if your running stock, use the kit setup and remove swaybars
ChadCapece is offline   Reply With Quote
Old 08-29-2005, 11:56 AM   #12656
fjm9898's Avatar
also if you can, get a 2mm chassis it will help you get a bit more grip and then you can just coppy Hara's 2004 on road nats setup and fiddle with it from there. that is what i did
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 08-29-2005, 05:25 PM   #12657
josh69162's Avatar
Send a message via AIM to josh69162
Most people use TC3/4 bones. I have TC3 aluminum up front and composites in the rear.
-Josh
josh69162 is offline   Reply With Quote
Old 08-29-2005, 05:35 PM   #12658
tc3 racer sc's Avatar
i used that setup too
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 08-29-2005, 07:04 PM   #12659
nordheim's Avatar
I went and purchased the IRS big dawgs for the tc3. Seems to be a lot beefier than the stock aluminum cvd bones.
Old 08-29-2005, 07:35 PM   #12660
josh69162's Avatar
I never have ever liked HPI's CVDs. Even if you don't bend them, you're garunteed to twist them. Is there really any way to avoid it, or do I need to keep stocking up on the TC3/4 bones?
-Josh
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
