Like Tree6Likes
Old 08-26-2005, 06:36 AM   #12616
dizzy1's Avatar
Trader Rating: 24 (100%+)
Get the spool Rosen!!!!
Ron and I are going to start running the spool for this new track layout. Lots of sweeping turns=spool or oneway. With all the hacking, the spool is the only choice.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 08-26-2005, 11:12 AM   #12617
Zorn
Are you going to buy it for me?With my luck with cvd's tearing out the pins do you think that would be a good idea?
no1uno is offline   Reply With Quote
Old 08-26-2005, 12:25 PM   #12618
ChadCapece's Avatar
Originally Posted by xxxkat
2 deg. rear block.
No, 6 deg blocks. It's a sweeping high speed turn. 6 degree will give him more steering. 2 will give him less.
ChadCapece is offline   Reply With Quote
Old 08-26-2005, 01:49 PM   #12619
Oasis's Avatar
Trader Rating: 36 (100%+)
2 deg. in the rear will free up the rear of the car(as in less push)He did say that the car was pushing(as in to much traction in the rear)6deg would be good for a bumpy track.. Plus with the 2 deg. rear block your car will pick up a bit of top speed.and the rear block only takes a min. or so to change,try it.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 08-26-2005, 02:11 PM   #12620
ChadCapece's Avatar
I'm stupid. I thought you said 2 deg castor block . I meant to try a 6 degree castor block. Or the 2 deg rear block should work. Either/or will probably solve your problem.
sorry xxxkat.
Old 08-26-2005, 11:49 PM   #12621
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
thx for advice to use 2005 dhi setup for rubber on carpet!
def a good baseline. i had to change it up some, i think mainly because kingsburg is smaller than dhi track.
yay for good times with good setups
floodo1 is offline   Reply With Quote
Old 08-27-2005, 06:38 AM   #12622
cyclone's Avatar
does anybody know the part number for either the newer hpi or the ae diff locking nut?
cyclone is offline   Reply With Quote
Old 08-27-2005, 08:42 AM   #12623
Oasis's Avatar
floodo1 your Car was hooked up in the main..almost as fast as the guys in 19 foam,did you see the guys in novice running Pro4's.. I have never seen a pro4 take that "type" of abuse and not break..2 heats and a main..just pounded,they hit the boards more in one race than i have the whole time i have had a pro4..but when i hit the boards i break.. floodo1 your going to practice on wednesday??If so I'll bring my pro4 and see if i can get it to work.
Old 08-27-2005, 10:45 AM   #12624
cyclone's Avatar
also my car has a slight but of understeer at the moment
can any1 recommend how i can make it better without spending anything on it, ps i dont have a spring set...?
Old 08-27-2005, 10:45 AM   #12625
floodo1's Avatar
yeah i hate to saying things like "pro4 is durable" cuz you know how luck goes.....but man, the pro4 sure seems durable to me! my car seems to be durable and those novice guys, wow, good thing they didnt have tc3's!!!!!!!!
yeah d00d if you're gonna break out the pro4 then i'll be there fo sho!!!
i'll pm you the setup i ran so you can have a baseline, i really think in stock that it will be even better than 19t!
Old 08-27-2005, 04:11 PM   #12626
vulso's Avatar
I am having a problem with my Pro4 and wanted to know if anyone here has experienced it or could help with it. My car has a click coming from the drive train ever since I have had it. It only happens with wheels on the ground accelerating or under braking. I have changed diffs to spool to one way, the bevel gears and ring gears and nothing has helped. The car is quick it just clicks and clicks and to be honest I am pretty fed up with it at this point. I am asking for some help with it and it would be greatly appreciated.
vulso is offline   Reply With Quote
Old 08-27-2005, 04:26 PM   #12627
Oasis's Avatar
Have you checked your CVD's,one of the pins could be the cause of this.Have you checked the rear gears as well?? I know my Pro4's have allways been smooth as butter..yours has some problem that your over looking.Good luck..I would still check the rear gears..
Old 08-27-2005, 04:27 PM   #12628
BritRacer's Avatar
have you checked tehat the main driveshaft gear is meshng well with the diff gear...if its too loose it will skip under load.
BritRacer is offline   Reply With Quote
Old 08-27-2005, 04:48 PM   #12629
fjm9898's Avatar
like they said check both the pin on the outdrive and the pin onthe done bone otthe other part of the shaft. if the pin for teh cvd joint is coming out it would he hitting the knuckle which would make the noise. i have had that probelm a few times.
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 08-27-2005, 05:37 PM   #12630
Trader Rating: 16 (94%+)
it's not something simple like a stripped spur, or a tiny rock in the spur or pinion gear?
other than that, I've had a clicking noise develop when the pins in the cvd developed some play (as already mentioned), but that was only audible on the bench, not the track
domo is offline   Reply With Quote
