Like Tree6Likes
Old 08-20-2005, 10:41 AM   #12556
fjm9898's Avatar
i plan on running it on carpet... but i think we should talk about this stuff on the cyclone's thread not the pro4s so if you want to talk about the car go here
Hot Bodies Cyclone
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 08-20-2005, 06:14 PM   #12557
rc-zombies's Avatar
Originally Posted by ngo8
just wondering is anyone planning on running a cyclone on carpet the car looks good but hoe good will it be indoors and wilo there be a diff available ?
you should post your question on the Cyclone specific thread..you'll probably get more answeres there...
I for sure will be running the cyclone on carpet. going to have a 3mm+ chassis made and upperdeck just for carpet racing. like the pro4... the cyclone should have a complete diff available. should be the same front and rear.
Old 08-21-2005, 03:40 PM   #12558
cyclone's Avatar
o dear, last time i raced my pro4, something bad happend to my rear diff.
wat happen was it was slightly slipping or sumthings and so it put it on for about 3 inspection laps and wen i brought it of i realised that my rear diff ad locked its like a spool now because as far as im aware its melted and the diff balls have melted into the beval gear
only thing is i had just rebuilt the diff before that race so i must have done something so i thought that i must have been lose which then caused it to heat up and melt
am i right?
cyclone is offline   Reply With Quote
Old 08-21-2005, 09:16 PM   #12559
fjm9898's Avatar
when you rebuild a diff you usually want to put in a new lock nut. that might have been the case, the lock nut was locking and the diff came loose or you just my not have rebuilt it right. take it apart and if you dont see anything wrong just rebuildit again. o and make sure you put in new diff balls too, when you rebuild a diff
Old 08-21-2005, 10:37 PM   #12560
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Shameless plug:
Selling my Pro 4. Look here:
HPI Pro 4 Roller For Sale/Trade for electric TC (Highly Modified)
DOMOisCOOL is offline   Reply With Quote
Old 08-22-2005, 04:06 AM   #12561
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Anyone have any special tips when it comes to building shocks? ie the initial assembley of the orings around the shock shaft etc
dontfeelcold is offline   Reply With Quote
Old 08-22-2005, 04:13 AM   #12562
chr15tophe's Avatar
Yeah righty o, replacing carbide diff balls everytime you rebuild a diff, you must have some money, the reason there carbide doesnt wear out that quickly
chr15tophe is offline   Reply With Quote
Old 08-22-2005, 08:16 AM   #12563
how can i stop the front wheels from "chattering" when on full lock (left or right) and full power?
billtc3 is offline   Reply With Quote
Old 08-22-2005, 08:51 AM   #12564
Registered User
Make sure your CVD's are smooth. Take them apart and clean them, make sure none of the parts are binding or the pins are tweaked, and lube them with some moly grease. With the parts dry the pins should fit easily into the pin holes in the cup but should have enough play that the axel flops up and down easily and does not bind at all. If the pins bind in the drive cup you can usually just take the pin with a pair of pliers and *lightly* work it at an angle to open up the hole slightly enough to give it more play.
Also make sure there is not too much play, if the pins have worn the cup holes oval you'll chatter. Ensure your bearings are free and clean, spin easily and don't bind, your CVD's should not be bent, and your wheels should spin true and not be broken or massivly out of balance.
Yeah that is a bit excessive. You should replace the parts that have failed when you rebuild a diff. Unless you run your diff all year until it's nothing but chunks inside and feels like a ratchet head when you spin it, you can typically just clean the parts and debris out and reassemble. Balls tend to outlast the diff rings, and the nylon nut should last awhile as well. When your diff no longer holds a setting, thats when you know to replace it. Most people take apart and clean their diffs every couple of races, imagine the cost involved if you were replacing all the parts each time. Yikes.
Desolas is offline   Reply With Quote
Old 08-22-2005, 09:02 AM   #12565
thanx desolas. everything is clean and free. i think the problem is that the cup holes have got oval. in japan they use a different cvd system, it's like you turned a regular cvd link inside out. maybe i should try that. it could be better and wear less.
Old 08-22-2005, 07:05 PM   #12566
Aurra Sing's Avatar
been trying out this new asphalt setup, its been working extremely good. low traction/high traction, VHT, soda, you name it... almost always the fastest car or one of the fastest. too bad the driver hasnt been driving consistenly lately
setup influenced by recent setup trends of the JRX-S, which is to have a high front roll center.. it has a lot of steering and rounds corners well
(front/rear)
springs: gold/silver or silver/silver (or harder overall depending on track)
sway bar: copper OR silver/no rear sway bar (again varying on track)
oil: 50/40
piston: #3/#3
damper positions on shock tower: #2/#4
camber: -1deg/-1deg
droop: 6mm/5mm (measured using HPI droop guage)
inboard toe: 1.5deg/3deg
roll center:
f/f: 2mm
f/r: 2mm
r/f: 0mm
r/r: 0mm
inner camber link spacing: 3mm/2.5mm
- camber link mounted on inside hole on rear hub
- one way
- mazda 6 body
- use short wheel base for tight tracks
- 2mm chassis
Aurra Sing is offline   Reply With Quote
Old 08-22-2005, 07:26 PM   #12567
wagonman72's Avatar
Cyclone not available yet, but soon.
wagonman72 is offline   Reply With Quote
Old 08-22-2005, 08:03 PM   #12568
ChadCapece's Avatar
(front/rear)
oil: 50/40
piston: #3/#3
camber: -1deg/-1deg
roll center:
f/f: 2mm
f/r: 2mm
r/f: 0mm
r/r: 0mm
- one way
- mazda 6 body
- 2mm chassis
thanks, I'll have to try that out.
ChadCapece is offline   Reply With Quote
Old 08-22-2005, 08:40 PM   #12569
Dont mind if I too try it/Tks
Goofey is offline   Reply With Quote
Old 08-22-2005, 09:06 PM   #12570
rc-zombies's Avatar
yes...Aura Sing is very fast...his car was glued to the track.
my young apprestice is now a jedi master.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
