Old 08-10-2005, 08:03 AM   #12451
Solara's Avatar
Trader Rating: 16 (100%+)
Tower listed the HB CYCONE.........but the best part is, RTR..? READY TO RUN..? That is one funny post....
For $500.........if they are as RTR like the one on the pictures..........I will buy 10 of those immediately, $500 is CHEAP..........LOL
http://www2.towerhobbies.com/cgi-bin...?&I=LXLBD7&P=7
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-10-2005, 08:12 AM   #12452
Solara's Avatar
Originally Posted by rc-zombies
stock kit: 2.5mm chassis and 2mm upperdeck.
Hara Kit: 2.5mm chassis and 2.25mm upperdeck.
Asia '05 kit: 2.0mm chassis and 2.25mm upperdeck.
Thanks zombies...........
Old 08-10-2005, 11:47 AM   #12453
josh69162's Avatar
Send a message via AIM to josh69162
REQUIRES: Radio: 2-Channel with 2 Servos
Radio Batteries: (8) AA size
Speed Control: Electronic of modeler's choice
Motor:
Battery:
Charger: AC/DC timed or peak for battery
Paint:
Misc. Items: Building and track equipment
^^^ Straight from Tower's website.
-Josh
josh69162 is offline   Reply With Quote
Old 08-10-2005, 03:05 PM   #12454
Thad Garner's Avatar
He must be a morning person............
Morning person...not by choice.
My question is........are you going to run the CYCLONE from now on....? Thanks...
I will most likely be running the Cyclone.
HPI Racing - HB - R1Wurks - LRP
Thad Garner is offline   Reply With Quote
Old 08-10-2005, 06:27 PM   #12455
josh69162's Avatar
What does the Cyclone have that the Pro4 doesn't?
-Josh
Old 08-10-2005, 06:56 PM   #12456
rc-zombies's Avatar
-Josh
2 belts...
Old 08-10-2005, 07:12 PM   #12457
josh69162's Avatar
And why does two belts make the Cyclone better than the Pro4?
-Josh
Old 08-10-2005, 08:12 PM   #12458
-Josh
2 belts make it different…. Both cars are awesome in their own unique ways
Old 08-10-2005, 08:29 PM   #12459
josh69162's Avatar
Well, at least I got a straight answer... And what's the different between the silicone lube and the gray differential lube (part #'s z155 and z156, respectively)?
-Josh
Old 08-10-2005, 09:57 PM   #12460
rc-zombies's Avatar
once owned the new YOk BD...similar design to the cyclone...all I can say is wow...great handling and corner speed. tons of rear traction..due to the motor configuration. the torque of the motor force the rear end to be more planted... on the shaft...the torque of the motor will tend to pull it to one side better than the other.... sold the BD...now patiently waiting for the Cyclone. if the pro4 was great..I'm sure the new cyclone will be just as great or better.....
Old 08-10-2005, 11:09 PM   #12461
bob szeto's Avatar
Default Adjustable upper camber link & pivot blocks
What are the effects when changing the upper camber link heights and pivot blocks heights?
Thanks!
Hot Bodies USA / Norcal Hobbies / Speedworld Raceway / Team Sorex USA
bob szeto is offline   Reply With Quote
Old 08-11-2005, 01:53 AM   #12462
Manny's Avatar
Originally Posted by jayrodracer
in the manual it says that the higer the inner arm mount or the lower the inner camber link mount the more traction, i got the xxx main book and it says that that is the opposite. does anyone have any comments or experience with that?thanks alot
jayrod
From what I can tell, the manual IS backwards. Doing what you describe raises the roll center and you get less traction due to the decreased roll.
Manny is offline   Reply With Quote
Old 08-11-2005, 11:46 AM   #12463
Solara's Avatar
Motor:
Battery:
Paint:
-Josh
I DO know that...just want to share their ad about "RTR"....
Back 3 months ago, I ordered 6 415 MS kits from TOWER for $249.99 each....of course, when the kits are actually in TOWER's warehouse, they emailed me and said the actual price is $449.99.........then I cancelled all my orders......
For something like that....I have to give that a shot.
Old 08-11-2005, 11:49 AM   #12464
Solara's Avatar
From what I understand, the LOWER the inner link (camber link over the gear box) and the HIGHER the hub position (over the wheel hub by adding spacer) the more traction that will be.............
At least, I felt that way once I add a 2mm spacer onto the hub link position.
Old 08-11-2005, 12:12 PM   #12465
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
it doesen't affect for amount of roll, it affects for roll speed and tire pressure force. so when we look at only the traction of tire,higher roll center has more traction. but all depending up on the total barance..
usually, the higher roll center is used on the low traction track.
just my2cents.
Hi-LowBrow is offline   Reply With Quote
