Like Tree6Likes
Old 08-05-2005, 01:21 PM   #12421
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by Rookie Solara
When the Aero 2 was out, he used that on the Japan National for promotion....of course, for all the big show, he only use RJ RIDES body....not HPI nor HB.
I think the rest of the ppl did approved the AERO 2 body....that should answered your question.....
Good luck at DE.........
thank you..........
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-05-2005, 01:30 PM   #12422
loopedeloop's Avatar
I use the ride stratus 2.
A very stable body,great at speed, have to retune slightly to acheive good mid corner speed as it seems to lose traction coming out of corners.
Probably just my setup
loopedeloop is offline   Reply With Quote
Old 08-05-2005, 01:35 PM   #12423
Solara's Avatar
Trader Rating: 16 (100%+)
He must use HPI body for HPI challenge...no other bodies, tires allowed...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-05-2005, 01:46 PM   #12424
ooops sorry , unfamiliar with the format
Old 08-05-2005, 02:44 PM   #12425
fjm9898's Avatar
for the top deck mod with the spacers on the steering posts, can you use the cone head washers and pup the o ring inside the upsidedown washer? i am out of spacers
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 08-05-2005, 02:47 PM   #12426
rc-zombies's Avatar
yes...that is used...not regular spacers..
cone washer or countersink washer is used.
the o-ring inside the washer keeps enough tension to the screw does
not become loose.
Old 08-05-2005, 02:53 PM   #12427
fjm9898's Avatar
ok thanks, i was getting a little confused when i herd some people saying to use spacers
Old 08-08-2005, 02:34 PM   #12428
rc-zombies's Avatar
Old 08-08-2005, 02:51 PM   #12429
Default Narrowed upper plate
The sources of 2.25mm upper decks seem to have dried up. My Hara edition drives so much better than the my base Pro 4, that I am considering using a carbide bit and routing the 2mm stock deck to a close approximation of the Hara upper shape. Has anyone tried this? Any results?
I gave my son the Hara edition to race with and now I have to make other work for myself.
thepitcrew is offline   Reply With Quote
Old 08-08-2005, 03:07 PM   #12430
rc-zombies's Avatar
have you tried rainbowten for the 2.25mm upperdeck?
rcmodel in HK has it instock...
http://shopping.rcmodel.com.hk/
routing the original 2mm upperdeck will add alot of lateral flex...and lessen the front / rear flex.
Old 08-08-2005, 03:25 PM   #12431
Yes, we race asphalt so the idea is to get more lateral flex. I prefer to only shop the US internet sources. So, with that limitation, I'm coming up dry on the 2.25mm plate.
I can compensate for the difference in material thickness to come up with the same cross sectional area which should give me approximately the same lateral flex. I'm not as worried about front to back, as I can always insert a stand-off. Has anyone tried this approach?
Old 08-08-2005, 03:39 PM   #12432
rc-zombies's Avatar
it will be awhile before you find it in the US...
Old 08-08-2005, 05:08 PM   #12433
jayrodracer's Avatar
Default set up help
in the manual it says that the higer the inner arm mount or the lower the inner camber link mount the more traction, i got the xxx main book and it says that that is the opposite. does anyone have any comments or experience with that? also im having a problem in the front of my car with the axles having play within the bearings, does anyone know how to fix this?? thanks alot
jayrod
jayrodracer is offline   Reply With Quote
Old 08-08-2005, 07:23 PM   #12434
My diffs, both front and rear kept loosening so I bought the associated diff nut like what has been recommended. My question is do you put the nylon side in the outdrive first or the side the metal nut is on? Also do I use the associated screw or the HPI screw?
Fantom11 is offline   Reply With Quote
Old 08-09-2005, 03:08 AM   #12435
Hi Rc Zombies, how are you finding the Hara Edition Pro 4 ? I have only just run my pro 4 for 2 x race meets now on carpet indoors.It is only the original kit, not even the v 1.1, but i was surprised how competitive it was. I hear the newer kits have a different setup to my original kit. What is your take on this ? I am looking at purchasing the Hara kit to run outdoors on bitumen tracks only, & keep the " old girl " for carpet
jim beam is offline   Reply With Quote
