Hpi Pro 4
Originally Posted by fastharry
does that come with the HARA kit?...its not in the std kit...and that hole is over the driveshaft....where's it bolt to the chassis?...thanks
I am not sure for outdoor asphalt (for your DE challenge) the center post is necessary....I don't run mine for outdoor mod.........I use the pole for carpet only.
Try my setup, its SOO good, it works EVERYWHERE, and its close to the kit setup.. Theres only one track i've ever been to that it doesnt work (ripon speedway in california)
Front
springs gold, silver sway bar, 50wt oil, #3 piston, second hole on shock tower, 3mm spacing on the inside camber link, 1.5 inboard toe block, 4degree caster, 1 degree camber, 6mm droop (measured on HPI droop guage)... rollcenter: 1mm spacing under all blocks
Rear
silver springs, no sway bar, 40wt oil, #3 piston, outer most hole on shock tower, 2.5mm spacing on inner camber link, 3deg toe, 1 deg camber, 5mm droop (measured on HPI droop guage)... roll center: anti squat, 1mm under the front block, .7mm under the rear block
mazda 6 body, either a spool or one way will work with this setup but you may need to soften the front springs when using a spool
Front
Rear
Originally Posted by Aurra Sing
Ramon, not sure about that week yet, hehe hope to see you and your cars soon
Guys, I recommend the 2mm chassis for asphalt racing, the flex gives you noticeably more amount of traction (obviously)
Either that, or i was just used to all the tweak my old chassis plate had... wow a fresh chassis is such a relief!
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
I think I found the piece...its on the battery tray tree......but I would never had known it..to the best I can see,its not even shown in the manual...
THANKS GUYS!!!!!!
THANKS GUYS!!!!!!
Zombies.......do you think it is worth it to upgrade the bevel gears to the HARA alum 1 piece version...? About $40 shipped from HK...not cheap, but if they can eliminate the chance to get stripped gear (if shim correctly), I think I will get them....thanks
I don't see that part even listed in my kit.....Does it go around the driveshaft?.....
one-piece bevel gear in the rear is not needed. for the front..all depends who you talk to... I have it..but it runs noisy. may switch back to the plastic ones... runs smoother... and haven't stripped any v1.1 gears yet.
Yes....it does come with the stock Kit....like a pole but in "C" shaped...parts # 73512 item #5, see page #7 on your manual.
thanks Rookie!!!!!
Originally Posted by rc-zombies
invest in the one-piece spur gear/input shaft combo instead.
Thanks for you opinion, you just saved me $40... Just for my reference, do you recall how many shims you did (F/R) on your diff, and on your bevel pinion input shaft (F/R)......? I know I did MORE then what the manual said, and I thought they are OK, except, I keep stripping gears....
where can i get the 2.25mm top plate for cheap and fast
What is that thing..? The Spool...?
my shimming is close to the stock set-up.
you don't want it tight...there should be a little play.
