Old 08-03-2005, 02:26 PM   #12361
rc-zombies's Avatar
my setup in red:
My setup
Frt
Springs- white pro4 yellow
shocks- 40 w 1.2mm pistons 45wt. 1.1mm piston
shock position- 2nd hole in on tower - outer on arm same
upper camber link height-3mm same
upper camber link position- rear inner same
lower blocks- f 2.5mm r 2.5mm 2mm f/r
ride height- 5mm same
droop- 5mm 6mm
caster blocks- 4mm 4 deg.
spool same
no sway bar black 1.6mm
Rear
springs- stock silver pro4 pink
shocks- 40w 1.2mm 45wt 1.1mm
shock position- 2nd hole in on tower middle hole on arm 3rd hole from outer - middle hole on arm.
upper camber link height- 3mm 0mm
upper camber link position- outer hole on upright...rear outer hole on camber plate inside hole on hub - inside hole on plate
lower blocks- f 3.5mm r 2.5mm F 3mm - R 2.5mm
droop- 4mm 5mm L - 6mm R
delrin diff same
no sway bar silver 1.4mm
standard wheelbase
in addition:
2.5mm chassis
2.25 upperdeck
F 2.5deg toe blocks
R 3deg toe blocks
Old 08-03-2005, 07:53 PM   #12362
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I'm just finishing up the Pro 4 i won at the Challnege last year.and want to run it at the DE challenge....I picked up the 05 top deck...but I'm a little confused on what screws to mount it with...and what screws go in what holes...alsoo,it looks like from the pictures there's some kind of purple spacers......
HPI doesn't have the manual listed yet....
if anyone can give me instructions and part #'s,I'd appreciate it.....
harry
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-03-2005, 09:13 PM   #12363
rc-zombies's Avatar
fastharry...
I posted some pics of the upperdeck mod install like a handfull of pages back... sorry don't know what page....
Old 08-03-2005, 09:59 PM   #12364
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
I found the post by rc-zombie...it's #11902 if you want to see the pictures too. I've quoted the text below tho.
Originally Posted by rc-zombies
Aside from drilling out the holes... you'll have to do the o-ring mod as well.
you'll need: 2 o-rings, 2 cone washer, 2 button head screw. assemble as shown. do not tighten screw all the way down. should be about .5mm-1mm gap between the washer and upperdeck.
see pics.
nw racer: the purpose for this mod to help minimize any chassis tweak in the event of a hard crash. just drill out the hole just big enough for the screw head to pass through. the car will still be stiff with the stock chassis and upperdeck and you'll not have to change your driving style...what kind of track are you running? if you're running carpet at Raincity. recommend getting the stiffer 3mm chassis and upperdeck. asphalt..stay with the stock set-up.
centax error!.... the arms are great for low traction tracks...they are hard to get and available overseas. another option is stay with the stock arms and get the 2mm chassis.
atomic80 is offline   Reply With Quote
Old 08-04-2005, 12:27 AM   #12365
fastharry™'s Avatar
hey guys,thanks........the 05 deck diffrent holes on it then the std deck.....I'm not sure where HPI wants the orings mounted.....I need someone who has the HARA kit to post........
Old 08-04-2005, 12:42 AM   #12366
Rc-Zombies,
Just to have better understanding for the rear droop setup you have,
6mm droop R (Battery Site?)
5mm droop L (Motor site?)
MARKANO is offline   Reply With Quote
Old 08-04-2005, 05:21 AM   #12367
Frank McKinney's Avatar
My car spins out going into the corner then pushes coming out of the corner as I'm applying throttle - then when I let off it hooks to the left. And it won't stay going straight through the chicane! And I have to run after it cuz the range is only like 20 feet. I just use tires that are tossed away by the fast guys, but there's no tread on them, should I get new tires? What's the best truck body to use? Is a covered bed better than a camper shell?
(I'll leave it to Thad to finish up the agony post :P haha)#
What's up Harry!? Going to try electric finally?
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 08-04-2005, 08:02 AM   #12368
rc-zombies's Avatar
Originally Posted by MARKANO
Rc-Zombies,
look at the car like a real car...
Right side is the motor side (passenger side)
Left the batter side. (driver side)
copied from one of Hara's setup... help to eliminate or reduce any effect of torque steer or unbalance weight battery side being heavier....
Old 08-04-2005, 08:22 AM   #12369
Solara's Avatar
Trader Rating: 16 (100%+)
Harry......the purple spacers are mounted at the STEERING (pair) pole holes...and those spacers are standard spacer (I think they are 2mm or 3mm each) that PRO 4 use underneath the camber linkage/hub, you should get several packs of different thickness of those purple spacers cause you will use them throughout the car....(for roll center setting purpose).
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-04-2005, 09:07 AM   #12370
fastharry™'s Avatar
thanks rookie....and whats underneath the spacers?....the O rings?....
Old 08-04-2005, 09:12 AM   #12371
rc-zombies's Avatar
on the upperdeck... yes..
leave about 1mm gap between the spacer and upperdeck..don't tighten all the way down.
Old 08-04-2005, 09:31 AM   #12372
fastharry™'s Avatar
thanks guys......what is the center screw attached to?......(right behind the ant mount....)
Old 08-04-2005, 09:37 AM   #12373
There's a central post there. Aluminum....I got mine from RainbowTen.
Old 08-04-2005, 09:54 AM   #12374
fastharry™'s Avatar
does that come with the HARA kit?...its not in the std kit...and that hole is over the driveshaft....where's it bolt to the chassis?...thanks
Old 08-04-2005, 09:56 AM   #12375
Aurra Sing's Avatar
hey Marc..
you going to make the Aug.21 RcCar race? hope to make that one..since wifey is out of town...
Ramon, not sure about that week yet, hehe hope to see you and your cars soon
Aurra Sing is offline   Reply With Quote
