Like Tree5Likes
Old 08-02-2005, 05:11 AM   #12331
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Thanks for the Pic and the info Octavio.
Very helpful
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
SOuthernFRIED is offline   Reply With Quote
Old 08-02-2005, 07:45 AM   #12332
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Default Setup for stock carpet
I am starting my stock carpet season with my Pro4 and need some setup help. I will be racing on 1 year old CRC Ozite 2 with great bite. Will also be running foam tires and the BMI Pro4 chassis and upperdeck. Any setups would be great that others have ran with success. Thank you.
Chirag Patel
cpatel529 is offline   Reply With Quote
Old 08-02-2005, 10:04 AM   #12333
Solara's Avatar
Trader Rating: 16 (100%+)
So....does TC3 bevel gears and Diff ring gears are direct bolt-in onto the PRO 4...? I have heard ppl saying that, but have not seen ppl saying that is true or not...I know their tooth counts are the same 16/39....Thanks........
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-02-2005, 10:07 AM   #12334
rc-zombies's Avatar
I have some TC3 gears...they are the same size and teeth count and look like the Version 1 gears. I 've had no problems with the V1.1 gears breaking...so have not put on the TC3 gears.
Old 08-02-2005, 10:37 AM   #12335
Solara's Avatar
I have to replace mine...so can the TC3 BEVEL be use or I can use both TC3 BEVEL and the Diff Ring Gear as well..? If I have to change both, I rather change them as a set...instead of just the BEVEL...thanks Zom....
Old 08-02-2005, 02:33 PM   #12336
fjm9898's Avatar
what do you gain/loose when you add anti-squat? mine has always been zero, it i change it to 1.5 how will the car feel?
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 08-02-2005, 02:39 PM   #12337
rc-zombies's Avatar
read page 31 of the manual explaining anti-squat.
basiclly adding anti-squat to the rear will increase rear traction and slighly reduce steering. 0deg. will reduce traction and increase steering.
Old 08-02-2005, 03:16 PM   #12338
What's the most anti-squat you can run? Any other ways to increse rear traction? I run 3mm on the upper camber links frt and rear. Anyway to change that and help with the rear traction? Front end is perfect rear always seems to be loose. Thanks for any help
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
Old 08-02-2005, 03:20 PM   #12339
rc-zombies's Avatar
1.5 is probably the max.
to increase rear traction...several things..
no sway bars.
lighter shock oil..
move the shocks inward
softer springs
more droop.
don't do all the changes at once... 1 at a time!
Old 08-02-2005, 03:25 PM   #12340
GCT69's Avatar
yes they are direct bolt on, that's what I'm using right now.
GCT69 is offline   Reply With Quote
Old 08-02-2005, 04:54 PM   #12341
Aurra Sing's Avatar
Also make sure your rear uper links are on the outside outer-most position (outside hole on the rear upright)... more rear traction
I personally never use this though because the car may have too much rear traction and it makes the rear end roll too much
Aurra Sing is offline   Reply With Quote
Old 08-02-2005, 04:58 PM   #12342
rc-zombies's Avatar
hey Marc..
you going to make the Aug.21 RcCar race? hope to make that one..since wifey is out of town...
Old 08-02-2005, 05:05 PM   #12343
Thanks Zombie.That verify's everything I've done.Good to know I'm on the right track.We just run on very low grip parking lots.Traction is never plentiful so it's nice to hear all the options.
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
Old 08-02-2005, 05:31 PM   #12344
josh69162's Avatar
Send a message via AIM to josh69162
Just curious- but when you guys change your set-up, do you try to keep things neutrally biased, and change muliple things in small amounts, or just one thing to the extreme...?
-Josh
josh69162 is offline   Reply With Quote
Old 08-02-2005, 05:50 PM   #12345
One thing at a time, a small amount. Then drive. Sometimes one change will affect another part of the car.Which requires an additional change.If you change more than one thing at a time you really have no idea what helped and what hurt.
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
