Like Tree5Likes
Old 07-26-2005, 10:23 AM   #12256
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Hey I just saw some photos from an hpi challenge and this was haras car.
The cyclone looks pretty nice.
Here is a video of it:
http://www.hpiracing.co.jp/contents/...hara_amain.asx
Artificial-I is offline   Reply With Quote
Old 07-26-2005, 01:52 PM   #12257
chr15tophe's Avatar
gtc69 : so did you find out why your car is pulling to the right ??
Does anyone ever think about the phsycology aspect of racing ? really do think to do well the state of mind you are in must be right..? Does anyone get kinda disinterested after a while, ive been racing almost non stop every weekend this season and am finding my concentration levels are dropping mid week and need to get back in the zone quick, any tips on how do this ?
Had a week off but still feel shattered and not quite there in my mind if you get me.
Any tips
chr15tophe is offline   Reply With Quote
Old 07-26-2005, 02:30 PM   #12258
Moderator
Confidence.
Old 07-27-2005, 12:42 AM   #12259
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Just came back from a Tuesday Night Weekly Race. Finished 5th out of 9 (top 4 drivers were very good).
I have the same problem every week though...that is, breaking front bevel gears. I seem to break one every single week. I don't want to pay 4.00 each week for a set.
Anyone else having problems with the front updated bevel gears? The diff gears are fine, just that when the bevel gear is messed up it tends to mess up the diff gears as well.
DOMOisCOOL is offline   Reply With Quote
Old 07-27-2005, 02:24 AM   #12260
Frank McKinney's Avatar
Artificia-I - the HPI Japan video links don't work when you just copy the link - the file extension changes to .asx for some reason, here's the link that works: http://www.hpiracing.co.jp/contents/...hara_amain.wmv
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 07-27-2005, 02:53 AM   #12261
DOMOisCOOL's Avatar
Originally Posted by Frank McKinney
Want a fully optioned one? with the carbon fiber tub and full-length thick upper deck? Make me an offer
$100
Old 07-27-2005, 04:03 AM   #12262
the_barbarian's Avatar
Yea mate I have the same BS everytime even if I drive really well and hardly hit anything it's been said to me that the TC3 bevel gears are stronger so ive ordered some of them to try out and also ive been told a standard diff is better too no oneways and no spools for the Pro4
I've tried the rest but XRAY is the best 555
the_barbarian is offline   Reply With Quote
Old 07-27-2005, 06:07 AM   #12263
Yea i used to have the same problem, usually when i rean open mod with a spool or oneway, it could be that you need to shim the diff a little tighter but i found that the TC3 gear is stronger. There are a couple of different gears so make sure u get the right one but i have had the same one in there for more than a month now.
ATXPro4 is offline   Reply With Quote
Old 07-27-2005, 06:47 AM   #12264
$100
OK, that's one offer...
Old 07-27-2005, 07:15 AM   #12265
does anyone know the part number for the front and rear alloy bevel gears from the 2005 model im thinking about getting them
never mind I finally found them pitty its only the 16 tooth gear I thought it was both that were alloy
31422 Aluminum 16T one-piece bevel gear (front)
31423 Aluminum 16T one-piece bevel gear (rear)
Old 07-27-2005, 08:01 AM   #12266
Entropy's Avatar
That's Surikarn's car. He ran stock (23T) with us and also mod. Take note of the HPI R2/Katana based motor on the car. And yes, Surikarn was using a Helios then. Anyway, the cyclone will be all black without the purple bits
Entropy is offline   Reply With Quote
Old 07-27-2005, 09:20 AM   #12267
rc-zombies's Avatar
$105.36
got pics?
Old 07-27-2005, 10:33 AM   #12268
I've been running a V1.1 Pro 4 for about a month now and I really like it. It is pretty much box stock except for the setup. I will mostly be running on carpet either stock or 19t. What are some upgrades I should get for it? I ordered a diff for the front and I am getting Delrin outrdives all around. I've been reading on here alot of guys talking about input shafts or something with an integrated spur gear vs. the bevel gears. What is that about? What is better for stock? I was also thinking about getting the Carbon driveshaft? Is that worth it? I've noticed there are alot of aluminum option parts I can get, which do you recommend to get?
Brayden
Fantom11 is offline   Reply With Quote
Old 07-27-2005, 11:02 AM   #12269
Solara's Avatar
Trader Rating: 16 (100%+)
I do....
I ran outdoor MOD.....everytime when I am turning hard, everyone can hear my car doing the "stripping gear" noise from my car........but the car ran fine on the straight or anywhere that does not have lateral force applied...only on TURNS...
Opened up the case....both front and rear does looks FINE...however, I think, the tip of the bevel pinion gear (the small one, not the diff one) are stripped like the top 10%....I have replaced the 2nd set in a roll in 2 weeks.......I shimmed mroe then what manuel told me to cause there are extra play that I have fill............but still, that stripping gear noise happened this week.
My last option.....I think the upper/lower diff case that need to replace as well, espeically the area at the bearing/shim/pinion bevel gear spot...that area might be off/stripped that I cannot be tell with my bare eye.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 07-27-2005, 11:27 AM   #12270
DOMOisCOOL's Avatar
Thanks for the suggestions guys.
I will try out the TC3 gears next week. I assume it's a direct bolt on?
Also is it worth it to run those aluminum bevel gears? Or will they just bend? I'd rather break a gear than to bend some expensive aluminum one.
Rookie Solara: Yeah I have that same feeling. I'm running my car and I didn't even notice that the gear broke. Just when I turned into the apex near the driver's stand I heard the gears. It's didn't really affect my handling but it sucked out some battery life.
Ramon: Not fair, you had a decked out BLUE Pro 4 before . $110.00
