Like Tree6Likes
Old 07-22-2005, 09:47 AM   #12226
You should use thread lock for the screws. The grease is very important if you want to avoid extrem wear at the outdrives of your spool.
Team Awesomatix Germany
powered by LRP electronic
Marcel is offline   Reply With Quote
Old 07-22-2005, 04:11 PM   #12227
Can someone tell me how much a bone-stock Pro4 weighs? With no electronics and no body, just the chassis
It would be VERY kind of you if you could tell me!
ThANKS IN ADVANCE!!
Tbevofreak is offline   Reply With Quote
Old 07-23-2005, 11:02 AM   #12228
diha's Avatar
Default request for setup???
Hi,
Does anyone have a good set up for aspalt using 23T motors?
Please share with me.....
Thanks.
diha is offline   Reply With Quote
Old 07-23-2005, 02:23 PM   #12229
tc3 racer sc's Avatar
Default correct way to bleed hpi shocks
i had my pro4 a while and still learning to do the correct bleeding to get the shock right there a big different from associated shock and hpi to bleed right when i bleed the hpi shock no rebound or very little some one let me know thxs
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 07-23-2005, 02:27 PM   #12230
Originally Posted by tc3 racer sc
ok thxs i will try that looseing the delrin out drive
hey i found the problem to my diff i strip the gear on my spool/and other gear so it was not the rear diff
Old 07-23-2005, 02:28 PM   #12231
Originally Posted by diha
Hi,
Thanks.
u can find goodsetup on hpi japan for 23 t
Old 07-23-2005, 11:32 PM   #12232
diha's Avatar
HI,
thanks for your info.
However I could not find the setup.
Wondering if U could help to attached the link or the file.
Thanks in advance.
Old 07-24-2005, 07:34 AM   #12233
GCT69's Avatar
Default spinning pro 4
hello , I know you guys can help me with this one I'm kinda new when it comes to pro 4 and I'm currently on a bind right now, whenever I would hit the thrttle to full speed and just let it stay there for about a second or two (top speed) and then immediately let off ( no breaks applied) the car would turn to the right, I'm running a 27 t motor and cs27 , silver springs on the rear and gold upfront. If you guys would need more info I will try and give some more. Please help.
GCT69 is offline   Reply With Quote
Old 07-24-2005, 09:56 AM   #12234
chr15tophe's Avatar
possible thing to check :- tweak in the chassis
The best way ive found is to take off body posts front and rear, stick a set of cells in and put the battery strap on, flip the car over so it sits on the shock towers, if you can rock the car on the shock towers you have a bit of tweak somewhere, try re tightening the top deck and the diff cases, ive also found the diff cases do not mount flush so you need to level them up, by filing them down.
Its worth getting the upgraded top deck with the holes drilled out to prevent tweak during the race, look on hpi site for info.
Also check nothings binding ie anti roll bars, equal droop either side, toe and camber for good measure... and you will have a car that goes straight..
chr15tophe is offline   Reply With Quote
Old 07-24-2005, 01:23 PM   #12235
GCT69's Avatar
Default tweak chassis?
even if I'm running a oneway this should not happen right? (turning right when you let of the throttle)?will try what you suggested and hopefully fix the tweak.
Old 07-24-2005, 03:03 PM   #12236
Thraex's Avatar
If you have a tweaked chassis the car will also pull to the other side (in your case the left side) when you are accelerating. It could also be somewhere in the drivetrain, maybe the diffs aren't working properly so it pulls to one side.
So also check if something's binding and be sure everything runs smooth and how it should be.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 07-24-2005, 03:40 PM   #12237
GCT69's Avatar
the car is not turning left whenever I would hit the throttle,will ckl f there is ay binding parts, I did remove my mounting post and turn it upside down and try to rock it to see if theres any movement, none at all.
and can anybody tell me what does the attachment do? will it work for the front and back?
Old 07-24-2005, 06:00 PM   #12238
josh69162's Avatar
Send a message via AIM to josh69162
It gives you more mounting positions for the inner part of the camber rod. I THINK it works for front and back, but don't quote me.
-Josh
josh69162 is offline   Reply With Quote
Old 07-24-2005, 08:36 PM   #12239
Formula1fan's Avatar
I am having this same problem. Except my car wants to spin out when I make left turns. I have to baby the car through the left turns and it is even worse in the high speed chicane at my local track. I have made the adjustments to my upper deck, changed all rear hinge pins in the rear, checked the tweak after every run and messed around with droop. I bout this car as a back up to my FK05 and would switch back, but this has got personnel! I also have rebuilt the diffs and thread locked the diff adjustment screws. What am I missing?
Formula1fan is offline   Reply With Quote
Old 07-24-2005, 10:00 PM   #12240
HI,
Thanks in advance.
i donjt know the link on hpi japan but when u go to the site just click under pro4 on the main page and guess from there i dont understand the language
