Like Tree6Likes
Old 07-21-2005, 02:34 AM   #12211
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Originally Posted by kewdawg
What's your current set-up?
I started with kit setup (I have the Pro4 2005 spec), Ive tried Take Off 27's, Sorex's, even foams on asphalt, and "the car doesn't react to setup changes". Ive tried running other peoples setups, at the same track, same tyres etc and the car is not working like it should.
I can't visually see something that I have done wrong, even Miura from HPI has checked the suspension and he noticed nothing wrong with it.
dontfeelcold is offline   Reply With Quote
Old 07-21-2005, 09:10 AM   #12212
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Default Need Hpi Parts
Anyone have any HPI pro 4 Hara parts that they are looking to get rid of? I want to get hte motor mount, the shocks, and the front and rear input shafts.
Also what chassis(upper and top deck) should I run for carpet? I heard that the 3.0mm is the best. If so, does anyone have one of these for sale as well? Also am in need of a spool.
Please email me at [email protected]
Thank you in advance.
Chirag
cpatel529 is offline   Reply With Quote
Old 07-21-2005, 09:28 AM   #12213
Chirag
i would run the 3mm chassis for carpet, also BMI makes a really nice 3mm chassis that works well for carpet, as far as the spool your LHS should be able to get one or u can order it online for about 16.00 USD
ATXPro4 is offline   Reply With Quote
Old 07-21-2005, 09:42 AM   #12214
rc-zombies's Avatar
Chirag
for carpet get the 3mm chassis and upperdeck.
BMI makes a great chassis...unfortunately I sold my set to Axel.
or you can get the HPI 3mm chassis and upperdeck. tower should have those in stock as well as the spool.
Old 07-21-2005, 10:27 AM   #12215
what mm foam and rubber tires are peaple runing
Matthew.H is offline   Reply With Quote
Old 07-21-2005, 11:25 AM   #12216
chr15tophe's Avatar
Hi, whats everyone doing regards running the HPI spool,
how much wear do you notice, do you grease ? or run it dry so dirt doesnt increase wear? a
ny other makes out there that do a decent one, that doesnt wear so quickly ?
Or is everyone just replacing them on a regular basis ?
chr15tophe is offline   Reply With Quote
Old 07-21-2005, 11:41 AM   #12217
rc-zombies's Avatar
to minimize the wear..grease it with the gray grease.
or you can replace the CVD pins with the IRS CVD pin cushions
Old 07-22-2005, 06:21 AM   #12218
On carpet it depends on the tires which chassisplate you should run. With foam tires you should use the 3mm but with rubber you should use the 2mm plate, it's easier to drive, provides more grip and you won't have any problems with tweak.
Also very nice to drive is when you put 45g lead on your bumber, totally different steering feeling....
Team Awesomatix Germany
powered by LRP electronic
Marcel is offline   Reply With Quote
Old 07-22-2005, 06:42 AM   #12219
hmm i never thought of the weight on the front thing, any idea how that would work on asphalt? i may try it just for fun this weekend
Old 07-22-2005, 07:48 AM   #12220
jace's Avatar
Default 19 Turn Spec Class Racing
Can any one recommend 48 pitchg spur/pinion choices for the Pro 4 that suits 19t spec class motors, running on tarmac with rubber tyres?
jace is offline   Reply With Quote
Old 07-22-2005, 08:15 AM   #12221
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
that usually recommends 2.5mm upper deck for carpet
floodo1 is offline   Reply With Quote
Old 07-22-2005, 09:06 AM   #12222
We raced allways with the stock upper deck with the "hara mod". With rubber tire this was the fastest combination. Know i'm using the new 2.25mm upper deck from the hara special, but makes now big difference...
Greetz Marcel
Old 07-22-2005, 09:27 AM   #12223
Hi,
here are some pics of my P4 ready for carpet racing.
Hpi Pro 4-body.jpg   Hpi Pro 4-fronts.jpg   Hpi Pro 4-rears.jpg   Hpi Pro 4-pro4s.jpg
Old 07-22-2005, 09:33 AM   #12224
Thraex's Avatar
Car's looking great Marcel.... must be a european!
Never noticed that the new upperdeck was that narrow.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 07-22-2005, 09:37 AM   #12225
aaronb73's Avatar
I'm starting to build my hara pro4 and made a decision to use the spool. Is there anything special I should know about when putting that togehter? There aren't instructions for it but it seems rather simple just using the four screws and the new grease. Anything else?
aaronb73 is offline   Reply With Quote
