Like Tree5Likes
Old 07-19-2005, 04:03 PM   #12181
axel's Avatar
1st problme: Sounds like shimming to me. Is it the stock setting?
axel is offline   Reply With Quote
Old 07-19-2005, 04:17 PM   #12182
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Yep, problem one sounds like shimming.Try to eliminate the play in the front.It may take some custom shimming to tighten the mesh...and you may not have quite as free a driveline ,but it helps save gears.
Problem 2 simple.....
A. get the heavy duty drive cups or put a lil plastic under the drive cup to tighten them up!
B. and this will help with problem one also....Stop hitting stuff.
Think about where the energy goes when you tap something.The ball cups on the rear absorb all the energy form a hit.The cup under the tire cannot pop off so the inside cup pops off.
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
SOuthernFRIED is offline   Reply With Quote
Old 07-19-2005, 04:51 PM   #12183
Originally Posted by the_barbarian
hey guys everyone I know with a pro4 is having the same problem does anyone know of a fix for this cause its costing a small fortune
1st problem almost everytime the car is drivin we will break the front bevel gears its like the teeth just fall off even without any hits to the car
2nd this is really enoying the rear pivot ball on top of the rear hub after a few small taps to the rear wheels they shear off in the hub this is happening to everone I know even Nick Morris the top mod driver in Canberra
I heard you can now get alloy bevel gears but they are very pricy are they worth it and will alloy rear hubs make a difference to the pivot balls breaking off
thanks guys
Ok problem 1, the bevel gear is not shimed right, try shiming it a little tighter, also give the TC3 bevel gear a shot, i run mod with a spool up front and it has lasted 2 months now, a lot better than the HPI one ever did for me.
Problem 2, I have not had happen at all, and i have been racing my pro4 for more than a year now.
as for the alloy bevel gear, if shimming the diff tighter wont fix it try the TC3 gear seems to be a lot stronger,
ATXPro4 is offline   Reply With Quote
Old 07-19-2005, 05:38 PM   #12184
tc3 racer sc's Avatar
Default diffs slipping
when i apply throttle my car goes like it drifting i ran mod saturday the diffs were ok ANd all of sudden look like it start to slip so i replace rear diff with delrin and still doing it do i hve to tighten it up more plse help
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 07-19-2005, 05:46 PM   #12185
axel's Avatar
drifting? sounds like a traction problem. Check ur diffs by holding ur spur gear and turning one wheel and holding the other down, if they don't move then it should be alright.
Old 07-19-2005, 06:30 PM   #12186
it could also be that your diff is to tight, and the rear end is just spinning when u hit the gas. I find that my car runs best if the rear diff is a little looser when i run mod.
Old 07-19-2005, 06:37 PM   #12187
josh69162's Avatar
Send a message via AIM to josh69162
I'm running 48 pitch gears, and when the pinion isn't in, the car is dead quiet, but once the pinion goes in, it sounds like a tank is rolling through town. Is it just the motor resistance? My mesh isn't tight at all, there is a good amount of play between the spur and pinion, but it isn't slipping at all... Any ideas?
-Josh
josh69162 is offline   Reply With Quote
Old 07-19-2005, 07:48 PM   #12188
dontfeelcold's Avatar
what brand spur and pinion and what condition are they in?
dontfeelcold is offline   Reply With Quote
Old 07-19-2005, 08:52 PM   #12189
Essnowyt's Avatar
Send a message via AIM to Essnowyt
josh69162 - Carefully look in-between the teeth of both the spur and pinion for a small grain of sand. That can make a weird sound..
dontfeelcold - Did you ever fig out your understeer problem?
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 07-19-2005, 09:28 PM   #12190
ok thxs i will try that looseing the delrin out drive
Old 07-19-2005, 09:40 PM   #12191
josh69162's Avatar
I don't remember what brand the spur is. The pinion is a fresh Robinson 25 tooth. Both gears have really good looking teeth, nice and sharp. They are both very clean, with no dirt. How quiet are your cars? Maybe I'm just over reacting.
-Josh
Old 07-20-2005, 02:50 AM   #12192
the_barbarian's Avatar
thanks for the ideas guys
im tring my xray parts to see what happens with the pivot ball problem and a titanium screw
as for the bevel gear well it seems to be meshing great so im not sure thats the prob
I was told by my hobby shop to boil the bevel gears has anyone seen tried or heard of this
and ill give the TC3 bevel gears a go next time
I've tried the rest but XRAY is the best 555
the_barbarian is offline   Reply With Quote
Old 07-20-2005, 06:29 AM   #12193
Trader Rating: 37 (100%+)
Default hpi shirt...
I have 3 HPI Racer shirts left over from the HPI club we formed here. Unfortunately the club no longer exists.
Thought I would see if anyone on this thread wanted to pick these up. They are custom one off shirts we made just for the few guys in the club.
1 Blue size L
1 Grey size L
1 Black size M
$10.50 each shipped
PM or email me if you are interested.
thanks.
anthony.isla@gmail.com
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 07-20-2005, 06:35 AM   #12194
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
I have the same problem, I have 48pitch spur/pinion, they are always really loud. Cant quite to get it to quite down..
vi3tishduy is offline   Reply With Quote
Old 07-20-2005, 07:00 AM   #12195
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
Default SELLING
I'm selling my Pro 4. If your interested please have a look.
HPI PRO 4 TONS OF PARTS EXTRA CHASSIS
Mach10_shooter is offline   Reply With Quote
