Like Tree6Likes
Old 07-11-2005, 06:04 PM   #12106
Oasis's Avatar
Trader Rating: 36 (100%+)
Antonio..Pro4 works in stock..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 07-11-2005, 07:04 PM   #12107
Formula1fan's Avatar
Anyone have a low grip asphalt foam tire set up
Formula1fan is offline   Reply With Quote
Old 07-11-2005, 07:41 PM   #12108
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
To stop batteries coming out from hits, get the stick pack guides on the car, have a look at what needs dremeling off and them grind them off until the batteries sit in the car without touching the guides. I did this and it has worked flawlessly. Use the 2 inner pieces aswell, stops the batteries going into the shaft.
dontfeelcold is offline   Reply With Quote
Old 07-11-2005, 07:42 PM   #12109
this means you don't need to crank the battery strap,possibly tweaking the chassis.
Old 07-11-2005, 08:11 PM   #12110
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
quick, anyone know where 2.0mm chassis is in stock? checked tower, allspeed, and speedtech. looking for some place on left coast so i can get it by this weekend
floodo1 is offline   Reply With Quote
Old 07-11-2005, 09:42 PM   #12111
nw racer's Avatar
Only place I know of is Rcmart
nw racer is offline   Reply With Quote
Old 07-11-2005, 10:22 PM   #12112
loopedeloop's Avatar
I ground off the lugs on the underside of the guides, then installed it backwards so the flat side faced the battery.
No grinding required.
And have never lost a pack.
loopedeloop is offline   Reply With Quote
Old 07-12-2005, 01:29 AM   #12113
axel's Avatar
sheldon's hobbies have them in stock
axel is offline   Reply With Quote
Old 07-12-2005, 04:12 PM   #12114
kewdawg's Avatar
Start with 35 wt. oil. No pivot block spacers. Cyan and magenta tires. 3mm spacers under rear inner camber links, 1.5mm spacers under front inner camber links. Everything else in stock postions.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-12-2005, 04:26 PM   #12115
kewdawg's Avatar
I almost forgot. Use 20 lb. springs. Sorry.
Quinn Moon
Old 07-12-2005, 04:37 PM   #12116
kewdawg's Avatar
Originally Posted by Thor_jnb
Just an old GTR body. Probably, one of the bigger reasons your car won't steer.
Have a Mazda 6 with the painter. Will definitely have better steering and handling characteristics. Mount it up immediately!
Why ask the "which body" question? Read above^
Your touring car body isn't just for show.
Quinn Moon
Old 07-14-2005, 05:56 AM   #12117
diha's Avatar
Default Pic on battery holder
Can Show some pics?
Thks....
diha is offline   Reply With Quote
Old 07-14-2005, 12:08 PM   #12118
Originally Posted by diha
Can Show some pics?
Thks....
I'll post one later tonight when I get off work
Old 07-14-2005, 01:19 PM   #12119
Rcjunk-yard's Avatar
Originally Posted by Yellowtaro
I need some advice on how to keep the batteries in place in my Pro 4. Just build one and ran in the race this last weekend. The battery was knocked out twice due to being hit on the side. I am using the battery holder and have screwed down the post down to the maximum but the battery still falls out. What are you advice on dealing with this problem? Thanks!
A cheaper "redneck like" solution is to use a cable tie around the battery and the battery strap, usually one in the middle will keep it in place but you could use 2 if need be.
$.02
Rcjunk-yard is offline   Reply With Quote
Old 07-14-2005, 04:09 PM   #12120
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Hey guys just wanted to let you know PRO4 Hara Edition Info is now on http://HPIracing.com website.
http://www.hpiracing.com/kits/187/index.php
Has list of features and how it improves the car.
Also in case you missed it. Here is the new hara edition setup sheet.
http://hpiracing.com/graphics/setup/...-187-1%20p.pdf - Standard
http://hpiracing.com/graphics/setup/...20SU-187-1.pdf - Interactive
Artificial-I is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
