Old 07-06-2005, 10:44 AM   #12046
Aurra Sing's Avatar
Originally Posted by axel
hey marc where'd you get these?
Got it from http://www.victorracing.com in Fremont, 5 min away from hobbytown
Aurra Sing is offline   Reply With Quote
Old 07-06-2005, 11:00 AM   #12047
rc-zombies's Avatar
I'll be in the area tommorrow afternoon...
what there address... can not find it on there website?
Old 07-06-2005, 11:13 AM   #12048
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
Originally Posted by Proteus
Finally my young padawan! You have felt the force of the purple side! Welcome!!! Still have both of mine but haven't had much chance to race for the past month. And it's not looking good either for the rest of the summer.
yes,yes,yes Jeff !!!
I finally joined Team Purple
by the way,,,it was nice to see you at Reedy Race '05 Jeff !!
I'll be looking forward to see you again.
Hi-LowBrow is offline   Reply With Quote
Old 07-06-2005, 11:20 AM   #12049
rc_bam226's Avatar
Yo, Ramon, here you go:
Victor's Hobbies Inc.
39269 Cedar Blvd, Newark, CA 94560
(510) 796-8049
Hey, it's in the shopping Center next to Newark Memorial High School, if I remember correctly.
rc_bam226 is offline   Reply With Quote
Old 07-06-2005, 11:21 AM   #12050
rc-zombies's Avatar
(510) 796-8049
Thanks bro!
Old 07-06-2005, 11:22 AM   #12051
Registered User
Hi-LowBrow's Avatar
Originally Posted by Artificial-I
I guess since no one is answering your question. Even though im not an expert. Ive dealt with electrics and gear mesh quite a few times. You want to make sure it spins free but isnt too loose. If you can set it a little further apart and see how it goes.
If it frees it up a lot thats probably the best point for yah. I try to make it as close as possible with it still being as free as possible.
Also with any new car things will be a little tight. You might just try not worrying about it run it once or twice and then recheck. Also listen for any sort of unpleasant sounds of course. You want it to be pretty quiet, if you can listen to other pro4 cars and possibly check those out so you know if your within range.
Good luck.
thank you very much for the advice !!
I gave it breaking in last night for 3hours and it seems like in smoother condition than before now...
as you mentioned, I intend to give it few runs and re-check it !
thank you again !!
Old 07-06-2005, 11:25 AM   #12052
josh69162's Avatar
Send a message via AIM to josh69162
Hey guys not sure if anyone has posted this yet.
But here is the new HARA edition blank setup sheet:
http://www.hpiracing.com/graphics/se...-187-1%20p.pdf
And here is the interactive version:
http://www.hpiracing.com/graphics/se...20SU-187-1.pdf
Enjoy.
Why would they make a new set-up sheet? There aren't any structural differences, are there?
-Josh
josh69162 is offline   Reply With Quote
Old 07-06-2005, 11:28 AM   #12053
rc-zombies's Avatar
-Josh
addition of new 2.25 upperdeck w/tweak mod and few other minor changes.
Old 07-06-2005, 11:32 AM   #12054
josh69162's Avatar
I didn't think HPI endorsed, nor encouraged the tweak mod. You wouldn't happen to know what the other changes were, would you? Are the cars still compatable? It's not like TC3-TC4 changes, right?
-Josh
Old 07-06-2005, 11:56 AM   #12055
rc-zombies's Avatar
-Josh
the new 2.25 upperdeck has the 4 hole screw mod. allows for more lateral flex and still rigid for/aft...
all parts still compatible... no major changes just performance option parts.
Old 07-07-2005, 11:57 AM   #12056
josh69162's Avatar
Hey, do you guys know if anyone makes those protective plastic sheets that just stick to the chassis? It's like really thin lexan-looking stuff, and it's sticky on one side. My street is really bumpy, and I just want to protect my baby.
-Josh
Old 07-07-2005, 11:58 AM   #12057
Thraex's Avatar
associated makes it.... check out there website!
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 07-07-2005, 12:13 PM   #12058
axel's Avatar
i've tried losi...didn't work for me i ended up peeling it right off.
axel is offline   Reply With Quote
Old 07-07-2005, 12:16 PM   #12059
Thraex's Avatar
Here you go!
Chassis Protective Sheet
Thijs van M[HPI/HB]
Old 07-07-2005, 12:26 PM   #12060
Solara's Avatar
Trader Rating: 16 (100%+)
Question about shimming the diff........I am running front and rear ball diff for outdoor mod foam.........and I started to rebuild the both melted front/rear diff gears, since the manuel shimming is way off to the actual case, I want to know the main theory about the pinion/spur diff gearing fundermental....
Here is my questions, am I suppose to set the gear meshing (talking about the diff gears) closer to each other or futher apart while they are still spinning freely? That means I have to shim 1 side of bearing more then the other side, I just don't really know I should set the DIFF gear closer to the bevel pinion gear or further apart from the bevel pinion gear.....
Now, the diff setting........I replaced the stock screw/nuts with the AE TC3 setup.......now, how many TURN OUT I have to turn from complete screw in position..? TC3 would tell you 1/2 turn front and 1/4 turn rear (something like that..) but what about PRO 4...? I know no one know the exact number, but I would like to get a ball park number...
Thanks everyone
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
SEO by vBSEO 3.5.0
