Like Tree6Likes
Old 07-05-2005, 02:50 PM   #12031
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
Originally Posted by xxxkat
The Pro4 has the smoothest drivetrain out of the box period,I would shim it per the manual,If it's making any type of noise I would look at the ring and pinion gears in the front oneway,I would bet you'll find a a few teeth missing on the ring gear.I own a few other shaft drive TC's and the only one that even comes close to the drivetrain of a Pro4 is the R3 Cuda and that was with alot of hop ups and alot of time.Look for other problems..like the gears or a bad bearing..
thanks for the info.I just got mine and have been building it these 2days little by little. I followed the manual for building the drivetrain section,but
after finished to build this section, the drivetrain wasn't smooth at all.and then I spent several hours to get smoother drivetrain , so far, the problem is still there, can't solve it.
the problem is like this.....
when I spin the main drive shaft by my finger (without motor),my finger feels like the gear teeth just like the gear mesh too tight. but actually there is a liitle amout of Play on the gear mesh between the bevel gear and the one way's gear.
anyone has had the same problem ???
Hi-LowBrow is offline   Reply With Quote
Old 07-05-2005, 03:25 PM   #12032
axel's Avatar
which shims am i suppose to use the softer coper ones or the silver ones for the one-way?
axel is offline   Reply With Quote
Old 07-05-2005, 03:34 PM   #12033
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
Originally Posted by Aurra Sing
I use the HPI heavy duty cups, works great:
Where did you get the medium length ball cups? I've been looking for that one for some time now (A302). Tower Hobbies has those items still on back order.
atomic80 is offline   Reply With Quote
Old 07-05-2005, 05:16 PM   #12034
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
hpiracing has its own store sometimes they have the hard to get stuff in stock but expect to pay out the ying yang twins.
Artificial-I is offline   Reply With Quote
Old 07-05-2005, 11:08 PM   #12035
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
for me the instructions on shimming where way off. in the back i had to move all but 1 shim to one side and also change the overall number of shims.
so more than likely its a shimming problem i'd guess.
floodo1 is offline   Reply With Quote
Old 07-05-2005, 11:18 PM   #12036
Here are all four of my RC cars thus so far. I'm still waiting for the Cyclone to complete my collection!
From left to right, Xray T1FK'05, Tamiya TRF415MS, Yokomo MR-4TC BD and the HPI Pro 4 updated to Hara/2005 specs.
I'm not quite finished with all the cars so don't mind the messy wires. the Yoko is also missing an ESC. I haven't decided which one to get yet.
Old 07-06-2005, 12:53 AM   #12037
axel's Avatar
niiiiice collection...i like your marble counter too
Old 07-06-2005, 12:58 AM   #12038
chaini's Avatar
Wow, I'm getting jealous! Do you also run them or not?
chaini is offline   Reply With Quote
Old 07-06-2005, 01:01 AM   #12039
axel's Avatar
it must be nice on race days saying "hmmm...which car should i race today?"
Old 07-06-2005, 01:10 AM   #12040
Aurra Sing's Avatar
I'm actually using the extra long ones for the camber links.. small ones for everything else.
Aurra Sing is offline   Reply With Quote
Old 07-06-2005, 01:12 AM   #12041
axel's Avatar
hey marc where'd you get these?
Old 07-06-2005, 07:16 AM   #12042
Moderator
Hey guys not sure if anyone has posted this yet.
But here is the new HARA edition blank setup sheet:
http://www.hpiracing.com/graphics/se...-187-1%20p.pdf
And here is the interactive version:
http://www.hpiracing.com/graphics/se...20SU-187-1.pdf
Enjoy.
Old 07-06-2005, 07:17 AM   #12043
Yup, I definitely run them...The Xray is for carpet, the Pro 4 is for asphalt. The Tamiya is on asphalt although I haven't run it yet. The Yokomo, I just finished so I haven't decided whether to set it up for carpet or asphalt yet. Of the four, I'd say that the Tamiya is definitely the fastest and the Xray the easiest to handle. The Pro 4 is somewhere in the middle. Don't know about the Yokomo yet.
Old 07-06-2005, 08:20 AM   #12044
Send a message via AIM to Proteus
Finally my young padawan! You have felt the force of the purple side! Welcome!!! Still have both of mine but haven't had much chance to race for the past month. And it's not looking good either for the rest of the summer.
Proteus is offline   Reply With Quote
Old 07-06-2005, 09:05 AM   #12045
Moderator
I guess since no one is answering your question. Even though im not an expert. Ive dealt with electrics and gear mesh quite a few times. You want to make sure it spins free but isnt too loose. If you can set it a little further apart and see how it goes.
If it frees it up a lot thats probably the best point for yah. I try to make it as close as possible with it still being as free as possible.
Also with any new car things will be a little tight. You might just try not worrying about it run it once or twice and then recheck. Also listen for any sort of unpleasant sounds of course. You want it to be pretty quiet, if you can listen to other pro4 cars and possibly check those out so you know if your within range.
Good luck.
