Like Tree6Likes
Old 07-01-2005, 03:42 PM   #12001
wagonman72's Avatar
YO YO floolo, you goin to be at Mikes tomorrow for the oval?
wagonman72 is offline   Reply With Quote
Old 07-01-2005, 05:43 PM   #12002
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally Posted by Hi-LowBrow
Are there any places in US ??
i dont think that Aluminium upper arm support are selling in US. they only will sell carbon fiber type camber plate you can get it on towerhobbies.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-01-2005, 08:49 PM   #12003
180sx's Avatar
hey guys im hoping on getting a pro4 soon and i was gonna get me some spares to so i was just wondering what spares you would reccomend (whats breaks/bends in crashes ect...) thanx
180sx is offline   Reply With Quote
Old 07-02-2005, 03:00 AM   #12004
tony2's Avatar
get lots of bevel gears! if you are new at racing or even crash at all, you will break them. the only other part is front drive shafts. they bend, and twist, would recommend the optional steel shafts. hope that helps
Anthony Campbell
Ryper Hobbies l AKA | AE
tony2 is offline   Reply With Quote
Old 07-02-2005, 03:25 AM   #12005
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
uummmm,,,,,,,,,I think the '05 version is much better than the Hara edition...
it comes with almost all hopups.......but the prices are very close
why people buy the Hara Edition??
Hi-LowBrow is offline   Reply With Quote
Old 07-02-2005, 03:44 AM   #12006
Trader Rating: 16 (94%+)
I think you have it back to front?? the Hara comes with all the extras (spool, springs, sway bars, pivot blocks, etc) the only thing you really need to buy is the 2.0mm chassis...
domo is offline   Reply With Quote
Old 07-02-2005, 09:05 AM   #12007
Registered User
Hi-LowBrow's Avatar
Yes,it comes with both a one way and a spool but the springs and sway bars come with the Hara Edition is just 1 set each, no extras.
2 extra pivot blocks are in the kit though....
I need to get white derlin out drives,alminum camber link suport,2.0mm chassis and alminum tranceponder stay !!
Old 07-02-2005, 01:15 PM   #12008
rc-zombies's Avatar
Originally Posted by Guo Chean
Hi Zombie dun forget to check for me about you car ride height which side is higher. thanks for helping
rescrewed the upperdeck making sure it was flat and untweaked. then took it to the tweakstation to set balance... front ride height measured at 4.5mm both sides... on the rear.. 5.5mm on the left and 5mm on the right...
so the rear left side is slightly higher than the right.
rechecked on the tweak station... everything stll balanced....
hope this helps...
Old 07-02-2005, 01:20 PM   #12009
rc-zombies's Avatar
worr that very much to add? are you using hara twister 2, ko 2343FET servo and ko 302 receiver? are you using 2mm chassis?
I have the Twitster 2, Fut S9550 lowprofile dig. servo. and Fut HRS receiver.
on 2.5mm chassis... I just got the 2mm chassis... haven't installed it yet...
Old 07-02-2005, 01:42 PM   #12010
Guo Chean's Avatar
hope this helps...
The rear left izzit battery side or motor side? i check already if you say battery side is more higher than the motor side them same with mine.
Old 07-02-2005, 01:43 PM   #12011
Guo Chean's Avatar
how come 2.5 still need to add 56 gram one the chassis in order to make it legal weight.
Old 07-02-2005, 01:44 PM   #12012
Guo Chean's Avatar
your car should be a lot of hop up rite? why still need so much weight?
Old 07-02-2005, 11:16 PM   #12013
rc-zombies's Avatar
I just wanted equal weight left and right. you will also notice on Hara's or any of the HPI team...they add alot of weight on the motor side. you want to the car to transition left and right equally. without any added weight... the car will tend to turn faster left than right...or is that faster right than left..well..its one of the two...
Old 07-03-2005, 12:43 AM   #12014
Guo Chean's Avatar
i add almost add 70 gram at the motor side too. but i feel that if i add to much my car will run over weight.
Old 07-03-2005, 10:52 AM   #12015
Registered User
Hi-LowBrow's Avatar
rc-zombies,is it possible to post some pic of your car ?? if it's possible, it would be very appreciated.
