Old 06-30-2005, 10:56 PM   #11971
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hi may i know does anyone having this kind of problem before. my car ride height was difference from left and right like left 5mm and right will be 5.5mm. i check already the chassis did not tweak. and i using weight distribution from integy it show that four part will have difference weight and the most serious is front right the weight is totally out. i have a chassis balance from Hudy it and i do not know well in using it. even i add some weight on the right side it like no difference. anyone know why? thanks for helping
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-30-2005, 11:02 PM   #11972
axel's Avatar
are you concerned with height or weight? I thought ride height can always be adjusted with the shocks?
axel is offline   Reply With Quote
Old 06-30-2005, 11:11 PM   #11973
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Originally Posted by axel
i never really got the purpose of using the servo saver on the pro4...if you tighten it will it reduce steering end points?
dontfeelcold is offline   Reply With Quote
Old 06-30-2005, 11:33 PM   #11974
loopedeloop's Avatar
Default servosaver
No , if you tighten it it wont give as much when you hit something.
It will stress the servo more.
Tightening the servosaver is not a problem if you run a quality metal gear servo, but it must have give if you still use s3003's like me! lol
loopedeloop is offline   Reply With Quote
Old 06-30-2005, 11:33 PM   #11975
axel's Avatar
thanks what do you mean though by "give as much"?
Old 06-30-2005, 11:44 PM   #11976
The servosaver is held together by compressing the two halves together between the spring and screw collar.
When you hit something the shock of the hit overcomes the tension of the spring allowing the two halves of the s/s to slip a little so only a part of the shock is transmitted to the servo ( hence the term "servo saver").
You will see if you loosen it off and try to turn the wheels the effect, tho you may have to hold ther servo while you do it.
When yu tighten it, it will limit the amount of give it has.
You need to adjust it so it is just loose enough to give but tight enough to return to centre at the same place everytime.
gee i hope this makes sense!
cheers
geoff
Old 06-30-2005, 11:45 PM   #11977
axel's Avatar
that made perfect sense thanks alot.
Old 06-30-2005, 11:47 PM   #11978
JayBee's Avatar
Trader Rating: 31 (100%+)
Turn your wheels all the way in either direction and hold them there. Now grab ahold of your servo saver (it should be pointing in the same direction of the wheels) and push it over even further. That little 'spring' action is the 'give' they're talking about -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-01-2005, 10:13 AM   #11979
Guo Chean's Avatar
yup ride height can be adjusted by shock but like m case i need same ride height at left and right the shock collar will be difference length. so what the problem? anyone have this kind problem????
Old 07-01-2005, 10:18 AM   #11980
rc-zombies's Avatar
'coz of the weight of the batteries..being heavier than the electronics/motor side..the left side may end up slightly higher. as long as everything is equal when you put it on a tweak station..should be ok.
Old 07-01-2005, 10:28 AM   #11981
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Hey so is the Pro4 Hara out yet guys? Has anyone heard any release dates? Seems to have gone silent.
Im also looking to get a pro4. If the hara isnt out soon or can be had with option parts let me know. I decided today im going to get an electric touring car to race at nexts month race.
Also if anyone has a pro4 roller they want to sell thats in great condition or nib let me know.
Artificial-I is offline   Reply With Quote
Old 07-01-2005, 10:30 AM   #11982
Guo Chean's Avatar
Zombie do you have this kind of problem? i check my chassis i not tweak at all. and i have no idea why my ride height is unbalance all the time did you have other way to solve it like counter weight on chassis??? did you know how to used the Hudy Chassis balance?
thanks
Old 07-01-2005, 10:47 AM   #11983
rc-zombies's Avatar
thanks
no did not use the hudy balance too.. used the Hudy tweak station.
my left rear sometime is higher than the right..probably due to the battery weight.
Old 07-01-2005, 10:49 AM   #11984
rc-zombies's Avatar
Where have you been lately...it's been out for a couple of weeks now... Tower has them instock... $375 w/$25 discount code. $399 reg.
I posted some pics of the box and contexts a handful of pages back.
Old 07-01-2005, 11:07 AM   #11985
rc-zombies's Avatar
Guo Chean
if you look at Erik, Thad or Hara's set-up sheet...
you will notice on the rear..the droop is not equal as well.
4mm left / 5mm right.
possibly due to unequal rear right height.
