Old 06-30-2005, 01:27 PM   #11956
rc-zombies's Avatar
Originally Posted by tcdrvr
It would probably cost about 150 with shipping to convert the car then? Also, how did the Yokomo BD handle in comparison to your '05 pro 4?
cost me about that much for the new 2.25 upperdeck, 4 new shocks and the motor mount, and 1pc front bevel gear.
Old 06-30-2005, 01:32 PM   #11957
rc-zombies's Avatar
Originally Posted by Hi-LowBrow
thanks for the info again.
I wonder why the Hara edition dosen't come with the one-piece bevel gear inbut shaft.....is that better than the Hara edition's bevel gear??
I've heard that the bevel gear which comes with the Hara edition is lighter than the one-piece bevel gear, but the one-piece bevel gear is more durable??
can you please tell me the parts number of the one-piece bevel gear
and where I can get it??
thanks
the Hara edition comes with an aluminum input shaft and uses a screw to hold the stock bevel gear instead of e-clips. and yes it's lighter than the 1pc version. the 1pc is aluminum. don't know about durability...definately the 1pc gear will not break..but you may end up breaking the main bevel gear. on the Hara since both gears are plastic...one or both may break. after running my car with the 1pc bevel gear... the car runs louder than usual.
Old 06-30-2005, 01:38 PM   #11958
fjm9898's Avatar
hey is this new input shaft set have teh screw on bevel gear or the eclip style, this hobby shop is in HK
http://shopping.rcmodel.hk/product_i...oducts_id=5843
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-30-2005, 01:40 PM   #11959
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
so,,,,do you personally like the 1pc bevel gear better? since the 1pc bevel gear is more durabule than the Hara edithion's bevel gear.
Hi-LowBrow is offline   Reply With Quote
Old 06-30-2005, 01:41 PM   #11960
rc-zombies's Avatar
that's what's stock on the Hara kit. uses screw to hold the bevel gear.
Rcmodel is a great place to order option parts from.. been order from them for the last 3 years now..and not have any problems.
Old 06-30-2005, 01:42 PM   #11961
fjm9898's Avatar
yea i was goign to make agood size order from there soon but i cant seem to find the new motor mount there
and that is the one piece i could use the most lol
Old 06-30-2005, 01:44 PM   #11962
rc-zombies's Avatar
performance wise...about the same... with the 1pc..I have piece of mind that the small gear will not come loose. which has happened to me once before.
Old 06-30-2005, 01:44 PM   #11963
rc-zombies's Avatar
try RainbowTen in Japan.
Old 06-30-2005, 03:04 PM   #11964
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally Posted by nw racer
I used a set of HPI shims to take away the play. They are a perfect fit over the hingepins.
does anyone know the part number for hpi shim set?
also zombies- so the al shaft w/ plastic bevel gear and steel screw is lighter than the one piece bevelgear/shaft?
floodo1 is offline   Reply With Quote
Old 06-30-2005, 03:16 PM   #11965
Trader Rating: 16 (94%+)
HPI 72111 SHIM SET 3x5mm (M3x5x0.1-0.2-0.3mm/10pcs each)
domo is offline   Reply With Quote
Old 06-30-2005, 03:29 PM   #11966
floodo1's Avatar
AWESOME! for two reasons! first up that i now can order them. but also because i saw that part number on hpi usa website and wondered if it was hinge pin shims, but i couldnt find ANY info on it.
thanks for the help!
Old 06-30-2005, 09:48 PM   #11967
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Just wondering what shock oil people are using in their 2005 Spec Pro4's?
dontfeelcold is offline   Reply With Quote
Old 06-30-2005, 10:06 PM   #11968
Aurra Sing's Avatar
I use either a 50/40 wt combo or a 40/40 (f/r)
Aurra Sing is offline   Reply With Quote
Old 06-30-2005, 10:39 PM   #11969
Paladin's Avatar
Try here
http://www.rcmart.com/catalog/produc...ducts_id=13709
Paladin is offline   Reply With Quote
Old 06-30-2005, 10:55 PM   #11970
axel's Avatar
i never really got the purpose of using the servo saver on the pro4...if you tighten it will it reduce steering end points?
axel is offline   Reply With Quote
