Old 06-28-2005, 12:59 PM   #11926
fjm9898's Avatar
i think they fit in it but i am not sure, there is a guy at my local track that has the bmi chassis and he runs the 3700 cells and it didnt seem like he cut it but i am not 100% sure if he did or not
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-28-2005, 04:08 PM   #11927
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
they say even using BMI chassis without modified i will a liitle bit out the battery slot.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-28-2005, 04:37 PM   #11928
axel's Avatar
sorry really don't understand what you mean?
axel is offline   Reply With Quote
Old 06-29-2005, 01:49 AM   #11929
RCknight's Avatar
Default Frank or someone from HPI...
I want to upgrade to the new knuckles and c-hubs. Is there a new part number or are they marked so that I can identify them?
RCknight is offline   Reply With Quote
Old 06-29-2005, 08:02 AM   #11930
rc-zombies's Avatar
don't think the part # has changed... just a running change in the molds...
Old 06-29-2005, 11:08 AM   #11931
Guo Chean's Avatar
it would not really fit the battery slot. sorry for confuse you
Old 06-29-2005, 12:58 PM   #11932
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Anyone else has had a problem stripping the screw that holds the knuckle into the hub? I'm talking about the button head one on the bottom (not the ball type one on the top).
Yeah maybe the answer would be to "Stop crashing so much", but I was just wondering if there's a fix to this or if it's just a known problem.
The knuckles I use are the stock ones. I tried switching to aluminum ones, but the screw hole stripped as well.
DOMOisCOOL is offline   Reply With Quote
Old 06-29-2005, 01:01 PM   #11933
nw racer's Avatar
the only bolts I have stripped on the pro 4 are the ones that hold the steering rack in place from the chassis. I actually just did it last Sunday.
nw racer is offline   Reply With Quote
Old 06-29-2005, 01:01 PM   #11934
rc-zombies's Avatar
a quick fix is to add a little CA after the screw has been strip. should be good for another day of racing. you do not have to tighten all the way down completely.
Old 06-29-2005, 03:43 PM   #11935
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
does anyone know of anyone that makes a suspension shim set...for the hingepins? i remember that trinity used to make one, but now the only ones i can find on their site are for shelfweapon and for "american made" sedans.
so who make metric shims for the hingepins?
floodo1 is offline   Reply With Quote
Old 06-29-2005, 03:59 PM   #11936
nw racer's Avatar
I used a set of HPI shims to take away the play. They are a perfect fit over the hingepins.
Old 06-29-2005, 04:42 PM   #11937
floodo1's Avatar
part number?
sorry forgot to mention that i require part numbers!
Old 06-29-2005, 07:14 PM   #11938
axel's Avatar
Anyone here know the possible best hop-up that is more performance than cosmetic? I'm thinking about getting the aluminum one-piece input shaft to help reduce "wobbling" in the spur gear. That or either the aluminum bevel gears.
Old 06-29-2005, 08:02 PM   #11939
if your running on a tight track get a spool if u dont have it already. I was running a one way on my local track, then a dif that was tightened all the way down and i still find the spool runs a lot better. Also get the spring set from HPI, or get the AE springs they work as well. Also doing the tweek mod to the upper deck is very helpfull.
ATXPro4 is offline   Reply With Quote
Old 06-29-2005, 08:04 PM   #11940
axel's Avatar
i run stock is spool really the way to go? And what is the big difference with using AE springs than HPI ones...will i notice a difference.
