Old 06-26-2005, 01:41 PM   #11881
josh69162's Avatar
Send a message via AIM to josh69162
Which part breaks the most? One answser for just normal wear and tear, and one for crashes, please.
-Josh
josh69162 is offline   Reply With Quote
Old 06-26-2005, 04:42 PM   #11882
Registered User
-Josh
Front gears when running a one-way tend to go easily for me. I've replaced three sets. I've gotten a lot of laps down with mine and I've gone through 3 sets of front gears, one titanium front axel, one drive cup, and one wheel bearing. That also represents three major crashes though too, so I can't complain.
Nothing appears to be "wearing out" however.
Desolas is offline   Reply With Quote
Old 06-26-2005, 04:46 PM   #11883
josh69162's Avatar
Sweet; Sounds like a really tough bullet. Any other responses? Thanks a lot!
-Josh
Old 06-26-2005, 05:15 PM   #11884
fjm9898's Avatar
the only thing that i have had break that wasent in the drive train was a ball stud
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-26-2005, 06:09 PM   #11885
Ok Im gonna change to the Hara input shaft instead.
Can someone tell me the part numbers for all the bit ill need for the conversion? Im thinking ill need gears and e clips too??
Thanks!!
Mild7 is offline   Reply With Quote
Old 06-26-2005, 07:54 PM   #11886
one peice lite weight input shaft set part # 75179
bevel gear set part #73501 make it is version 1.1
no e clips needed gear is held on with screw only 1 shim used on rear shaft none on front it all comes with the shaft set
no1uno is offline   Reply With Quote
Old 06-26-2005, 09:27 PM   #11887
axel's Avatar
I hear people using different tooth#'s on their spur gear rather than the stock 98t...i currently changes mine to 100t...does this really make a differece? As long as the final gear ratio is the same no difference will be made right?
axel is offline   Reply With Quote
Old 06-26-2005, 10:28 PM   #11888
Thanks for your help guys.
Old 06-26-2005, 10:38 PM   #11889
nw racer's Avatar
what do you do to perform the upper deck mod, and why is it done?
nw racer is offline   Reply With Quote
Old 06-26-2005, 11:07 PM   #11890
axel's Avatar
you ream the 2 bigger holes on the upper deck...well let me just show a picture
if you can see the two holes go deeper than the rest cause the holes are reamed. This is to prevent less tweak.
Old 06-26-2005, 11:22 PM   #11891
nw racer's Avatar
so you only ream the 2 behind the spur, and then the 2 just in front of the steering rack? How much do I need to ream out?
Old 06-26-2005, 11:27 PM   #11892
Trader Rating: 16 (94%+)
you need to get 4 button head screws to replace the csk screws for those locations, then using a drill bit which is slightly larger than the button head drill out the holes
and yes, the holes for the long screws running into the diff housings
domo is offline   Reply With Quote
Old 06-26-2005, 11:47 PM   #11893
nw racer's Avatar
I assume it is the same size screws in the holes, just the button head type like you said. Do you know the part number for the screws by chance?
Also, do I want to completely drill out the holes in the deck, or just enough to let the button heads sink into the top deck?
Old 06-26-2005, 11:57 PM   #11894
axel's Avatar
in mine the screws aren't even touching the carbon fiber when all the way down.
Old 06-27-2005, 12:04 AM   #11895
nw racer's Avatar
ok so I just completely bore out the holes so the screws it sounds like are just clearing the top deck and only screwing into the diff cases.
What is the size screw I need to do this with and do you have the part #
Thanks everyone for your replies.
SEO by vBSEO 3.5.0
