Old 06-24-2005, 12:26 AM   #11866
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally Posted by Mild7
Im Currently building my '05 Pro4 and am having trouble with the rear diff gears binding badly. Ive mucked around with shims for about 2 hours and still cant get a nice "quiet" mesh like i have in the front.
Any ideas?
for me i found that the number of shims that the instructions tell you to use was incorrect. iirc i had to add more shims, and move them all (but 1) to one side.
make sure you're input shafts are shimmed right first...then set the diff so there is a LITTLE play between the teeth. kinda like spur gear mess, as little play as possible without drag.
dont know if that helps you (prolly not) but thats my experience
floodo1 is offline   Reply With Quote
Old 06-24-2005, 12:28 AM   #11867
floodo1's Avatar
Originally Posted by domo
from rainbowten
3043430401640,KAWADA,400YEN,S64-90T SUPER TOUGH SPUR GEAR 64P 90T
3043430401563,KAWADA,400YEN,S48-86T SUPER TOUGH SPUR GEAR 48P 86T
wow thats nice and CHEAP.
do you have a pic of these? never seen them before
Old 06-24-2005, 12:49 AM   #11868
axel's Avatar
TC3/TC4 BEVEL GEARS...YES? OR NO? ARE THESE BETTER THAN THE HPI ONES OR NOT? I NEED TO KNOW ASAP THAT WAY I DON'T WASTE MY MONEY ON SOMETHING THAT WON'T WORK AS WELL.
axel is offline   Reply With Quote
Old 06-24-2005, 01:37 AM   #11869
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Originally Posted by fjm9898
i use RW Racing spurs, thin and light and never had one strip on me
Same here. Although the white makes it look dirty .
DOMOisCOOL is offline   Reply With Quote
Old 06-24-2005, 05:04 AM   #11870
kewdawg's Avatar
Don't know, if, they'll fit?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-24-2005, 09:06 PM   #11871
axel's Avatar
thanks for reply, anyone else?
Old 06-24-2005, 10:40 PM   #11872
rc-zombies's Avatar
you can always dye it black or any other color you want with fabric dye...beside it's inside the diff case and not seen...
Old 06-24-2005, 11:18 PM   #11873
RCknight's Avatar
Default Axel...
I looked at a set of my TC4 ones and they look the same. Infact the AE diff bearing also fits inside the HPI diff gear. It should work. I still need the new 05Pro 4 motor mount, steering knuckles, JRX-S shocks, ti screw set, AE diff screw/nut and aluminum seering bell crank. It's going to look sweet. I hope it goes sweet.
RCknight is offline   Reply With Quote
Old 06-24-2005, 11:19 PM   #11874
axel's Avatar
so yes with the ae diffs?
Old 06-24-2005, 11:23 PM   #11875
DOMOisCOOL's Avatar
I was talking about the RW spurs .
Old 06-25-2005, 06:10 AM   #11876
dizzy1's Avatar
Trader Rating: 24 (100%+)
With the AE gears, you have to remember that its bearing and shaft sizes are standard, while the pro 4 is metric. I compared the two very closely. You might have to due some slight reaming to the center of the gears to get it to fit, just make sure its snug and not loose on the shaft or bearing afterwards. Also remember to gear down about 1 tooth because your new internal ratio will be 2.5 instead of 2.4375. Maybe I will get out the reamer and give it a try some day.
All about that Hot Pockets again! Woot Woot! Tried the Russian rocket but tired of the 'part of the week'. All gold everything '15 only made a weekend, such a numb and overpriced car!
Team Hot Bodies- Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 06-25-2005, 07:37 AM   #11877
RCknight's Avatar
Default Axel...
I'll compare the two with my digital caliper and let you know.
Old 06-25-2005, 08:49 AM   #11878
I have one of the AE TC3 one way gears in my pro4 with a spool right now, i run mod every week and it has lasted longer than the HPI ones have for me in the past.
ATXPro4 is offline   Reply With Quote
Old 06-26-2005, 09:44 AM   #11879
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hey zombie,
did you know that ifmar approve the ride accord tsx in body list?? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-26-2005, 12:14 PM   #11880
rc-zombies's Avatar
Originally Posted by Guo Chean
hey zombie,
yea..I think I read that some where..forget where.
