Like Tree6Likes
Old 06-23-2005, 07:57 AM   #11851
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
Will do...just got the one piece bevel gear. Just have to install it.
yeah yeah, something else down the "road" may break.
atomic80 is offline   Reply With Quote
Old 06-23-2005, 10:37 AM   #11852
josh69162's Avatar
Send a message via AIM to josh69162
How good is the Pro4 in taking a front end hit? I heard it can tweak the shaft or ruin one if the gears in the front/rear box. Anyone had any of these problems? I'm a pretty good driver, and I want a Pro4, but I need to know what to stock up on, just in case. What is the biggest negative about the Pro4. If you can't find anything, state the best positive, please.
-Josh
josh69162 is offline   Reply With Quote
Old 06-23-2005, 12:34 PM   #11853
fjm9898's Avatar
the biggest negative on the pro4 is the biggest negative on any shaft car, no give in the drive train. with any shaft car you will get the occational broke gear from a hard impact, more so if running a one way or spool where there is no give at all during impact. i own a tc3 and a pro4 and that is my main problem, busting bevel and diff gears with my one way. when running a normal ball diff i never had any other these problems because nothing locks up so i never broke gears. there have been lots put out for the HPI to try and sovle these problems. it has got to the point where you can get aluminum everything, which i dont think is a great idea. i got the aluminum diff gear for my one way so breakage only happens in two places the front bevel gear (you can get aluminum one piece) or the shaft out drives (0you can get purpple aluminum ones) which i left plastic so that there is some give in my drive train in case of a hard impact. i dont mind breaking these parts ever so offten because if you go to full aluminum everything some lese just has to give and these are the 2 cheapest part to replace so i would rather to that thn somthing else. but all in all the pro4 is a great car. one of the most free spinning drive trains you can get (if shimmed right) and the car is much more smooth the my tc3 as well as handling a bit better which makes it easier to drive.
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-23-2005, 01:15 PM   #11854
Rcjunk-yard's Avatar
Originally Posted by loopedeloop
I chucked my hpi gears away, They strip way too easy, and have gone to kawada 48p spurs.
no stripping since
Where can I find Kawada? never heard of them. Doesn't anybody use Kimbrough????
Rcjunk-yard is offline   Reply With Quote
Old 06-23-2005, 01:27 PM   #11855
loopedeloop's Avatar
I in newzealand mate, dont know where they are stocked in US,sorry
loopedeloop is offline   Reply With Quote
Old 06-23-2005, 01:32 PM   #11856
fjm9898's Avatar
i use RW Racing spurs, thin and light and never had one strip on me
Old 06-23-2005, 01:36 PM   #11857
newracer's Avatar
R/C Tech Charter Subscriber
Default Spur Gears
I do not think the HPI spur gear is prone to stripping. People who are having problems must not have the correct mesh or are getting debris in the gears. I am running the stock spur with a Novak brushless and my spur has held up fine.
newracer is offline   Reply With Quote
Old 06-23-2005, 01:39 PM   #11858
fjm9898's Avatar
yea, i have never had a gear strip on my pro4 yet. i think the main thing is the get stuff in them if yuor racing out doors or your mesh is off, or your motor screws are coming loose and letting the motor move away from the spur letting the mesh open up to big causinng strippage on impact.
Old 06-23-2005, 01:51 PM   #11859
Default stripped gears
I have stripped a fe but I DO race outside. 64 pitch can be a problem getting the mesh just right and that can do it. The one thing you gotta realize is that the gears aren't perfectly ROUND which creates high spots and low spots. sorry for those of you who already knew that.
Old 06-23-2005, 04:55 PM   #11860
Im Currently building my '05 Pro4 and am having trouble with the rear diff gears binding badly. Ive mucked around with shims for about 2 hours and still cant get a nice "quiet" mesh like i have in the front.
Any ideas?
Mild7 is offline   Reply With Quote
Old 06-23-2005, 05:00 PM   #11861
Trader Rating: 16 (94%+)
i had the same problem, i stuffed around for hours and couldnt fix it so in the end i gave up and ordered the new hara input shafts
domo is offline   Reply With Quote
Old 06-23-2005, 05:15 PM   #11862
JayBee's Avatar
Trader Rating: 31 (100%+)
Talking
Then can I pay YOU to ship ME a few 64p KAWADA spurs?
Oh yeah... I'll pay for the spurs -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-23-2005, 05:20 PM   #11863
from rainbowten
3043430401640,KAWADA,400YEN,S64-90T SUPER TOUGH SPUR GEAR 64P 90T
3043430401641,KAWADA,400YEN,S64-92T SUPER TOUGH SPUR GEAR 64P 92T
3043430401642,KAWADA,400YEN,S64-94T SUPER TOUGH SPUR GEAR 64P 94T
3043430401538,KAWADA,400YEN,S64-96T SUPER THOUGH SPUR GEAR 64P 96T
3043430401539,KAWADA,400YEN,S64-98T SUPER TOUGH SPUR GEAR 64P 98T
3043430401540,KAWADA,400YEN,S64-100T SUPER TOUGH SPUR GEAR 64P 100T
3043430401541,KAWADA,400YEN,S64-102T SUPER TOUGH SPUR GEAR 64P 102T
3043430401546,KAWADA,400YEN,S64-112T SUPER TOUGH SPUR GEAR 64P 112T
3043430401547,KAWADA,400YEN,S64-114T SUPER TOUGH SPUR GEAR 64P 114T
3043430401548,KAWADA,400YEN,S64-116T SUPER TOUGH SPUR GEAR 64P 116T
3043430401549,KAWADA,400YEN,S64-118T SUPER TOUGH SPUR GEAR 64P 118T
3043430401550,KAWADA,400YEN,S64-120T SUPER TOUGH SPUR GEAR 64P 120T
3043430401551,KAWADA,400YEN,S64-122T SUPER TOUGH SPUR GEAR 64P 122T
3043430401650,KAWADA,400YEN,S48-67T SUPER TOUGH SPUR GEAR 48P 67T
3043430401553,KAWADA,400YEN,S48-69T SUPER TOUGH SPUR GEAR 48P 69T
3043430401554,KAWADA,400YEN,S48-70T SUPER TOUGH SPUR GEAR 48P 70T
3043430401555,KAWADA,400YEN,S48-71T SUPER TOUGH SPUR GEAR 48P 71T
3043430401556,KAWADA,400YEN,S48-72T SUPER TOUGH SPUR GEAR 48P 72T
3043430401557,KAWADA,400YEN,S48-74T SUPER TOUGH SPUR GEAR 48P 74T
3043430401558,KAWADA,400YEN,S48-76T SUPER TOUGH SPUR GEAR 48P 76T
3043430401559,KAWADA,400YEN,S48-78T SUPER TOUGH SPUR GEAR 48P 78T
3043430401560,KAWADA,400YEN,S48-80T SUPER TOUGH SPUR GEAR 48P 80T
3043430401561,KAWADA,400YEN,S48-82T SUPER THOUGH SPUR GEAR 48P 82T
3043430401563,KAWADA,400YEN,S48-86T SUPER TOUGH SPUR GEAR 48P 86T
Old 06-23-2005, 05:23 PM   #11864
JayBee's Avatar
Talking
Thanx domo!!! -JB
Old 06-24-2005, 12:24 AM   #11865
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
idk about durability on the center shaft drive cups, but i use the aluminum ones right now. this is because i couldnt get my molded pieces to spin true, always wobbling. now the aluminum pieces fit the shaft well and spin true!
i say get onepiece front input shaft and let diff gear break (if you're using spool or oneway) and in the rear use either stock shaft or onepiece shaft (to keep the plastic bevel back there) and let the bevel be the weak spot.
this im pretty sure is also the lightest setup!
but hey dont trust me cuz i know jack about durability
floodo1 is offline   Reply With Quote
