Like Tree6Likes
Old 06-22-2005, 11:34 AM   #11836
rc-zombies's Avatar
Originally Posted by Guo Chean
what is the part num for the yokomo bd battery tray? for the tray i think i should be fit 3300GP cell only and if you want to fit gp3700 i think you need to pull out the tray
tray part # BD-118T
the tray fits the GP3300 with no problem. and room for the larger cells.
with the tray the cell may sit too low and scrape on the track.
Download the exploded diagram of the BD. you will notice how big the battery slots are on the chassis.
http://www.yokomousa.com/kits/mr4tc_bd/bd_downloads.htm
Old 06-22-2005, 12:51 PM   #11837
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
so you mean that with the tray my gp3700 will be scratch easily? if without the tray how much should i file inorder to let the gp 3700 sit properly?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-22-2005, 01:03 PM   #11838
rc-zombies's Avatar
nope..you will need the tray to fit the gp3700.
on your previous post you mentioned "if you want to fit gp3700 i think you need to pull out the tray"
Old 06-22-2005, 01:15 PM   #11839
kewdawg's Avatar
Originally Posted by rc-zombies
I'm using the Xenon spur gears..very durable made of delrin.
The stock Pro 4 spur IS made by Xenon. I'm curious as to why he would not find them durable. In fact, the optional gears Hpi sales for the Pro 4 are all made by Xenon - just packaged under Hpi. 95T, 96T, 97T, 98T - stock spur, 99T and 100T.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-22-2005, 07:06 PM   #11840
loopedeloop's Avatar
I chucked my hpi gears away, They strip way too easy, and have gone to kawada 48p spurs.
no stripping since
loopedeloop is offline   Reply With Quote
Old 06-22-2005, 08:29 PM   #11841
kewdawg's Avatar
no stripping since
I still use the same spur that came with my 1st kit - from March 2004, when the kit reached my LHS! Please tell me how you guys are stripping these spurs?!
Quinn Moon
Old 06-22-2005, 08:50 PM   #11842
uummm pass
i think with the kit spur gear holder (slight wobble) + maybe slightly loose adjustment they stipped?? I dunno.
I now have the onepeice shaft and 48p gears , not an issue any more
Old 06-22-2005, 08:59 PM   #11843
Driver1's Avatar
Send a message via AIM to Driver1
can someone give me a good carpet setup....
pretty tight track...medium bite
running mod
Driver1 is offline   Reply With Quote
Old 06-22-2005, 09:06 PM   #11844
rc-zombies's Avatar
running mod
carpet with rubber tires?
try Hara's DHI carpet set-up
Old 06-22-2005, 11:01 PM   #11845
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
no stripping since
48pitch spur is a lot safer on dusty tracks hardly strips. 64pitch has the best gearing increments but best on cleaner tracks.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 06-23-2005, 04:42 AM   #11846
has anyone installed the Square R/C Pro4 Aluminum Front One-Way Gear with the HPI aluminium front bevel gear ??
Just looking for alternatives to replacing 1 bevel gear set a day ...
hapiya is offline   Reply With Quote
Old 06-23-2005, 07:47 AM   #11847
rc-zombies's Avatar
don't recommend... you will end up braking something else like the cv bones, outdrives, or other parts. would you rather break/bend a $9 bone or a $4 bevel gear?
Old 06-23-2005, 07:52 AM   #11848
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
What about using the one piece bevel gear with the square aluminum bevel gear PLUS the HPI steel dogbones? That should be a pretty strong combination?
atomic80 is offline   Reply With Quote
Old 06-23-2005, 07:55 AM   #11849
rc-zombies's Avatar
that combo may hold up.
if you have that install... let us know it's durability.
Old 06-23-2005, 07:57 AM   #11850
andyh's Avatar
..then you'd probably tweak your shaft......
andyh is offline   Reply With Quote
