Like Tree5Likes
Old 06-21-2005, 09:16 PM   #11821
axel's Avatar
is that you in the middle and if it is what did hara and surikan say about the cyclone?
axel is offline   Reply With Quote
Old 06-21-2005, 09:19 PM   #11822
Entropy's Avatar
Yup, thats me. Though I think Surikarn's mom wasnt too pleased to see me giving more attention to Hara
Well, nothing new that you havent already read about the cyclone, though he was still using one tamiya pulley on his cyclone like his last race.
Entropy is offline   Reply With Quote
Old 06-21-2005, 10:05 PM   #11823
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hey does anyone know how to modified the pro 4 chassis for IB3800 or GP3700 battery. how many wide for the slot inorder to put the battery in. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-21-2005, 10:34 PM   #11824
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Talking
yes jake, go tell and let the whole world know!!!!
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 06-21-2005, 11:17 PM   #11825
Entropy's Avatar
Old 06-21-2005, 11:27 PM   #11826
RCknight's Avatar
Default Anyone know the part number for the new...
steering knuckles aand or c-hubs? The ones that won't bend the cvds?
RCknight is offline   Reply With Quote
Old 06-22-2005, 12:03 AM   #11827
Default spool bearings
Thanx for your reply zombies. Can you tell mell which bearings I would need to fit a spool ?
jim beam is offline   Reply With Quote
Old 06-22-2005, 12:14 AM   #11828
Guo...Just a thought I Have a BD as well as a Pro4...What about the battery holders that the BD uses? I have not checked if they will fit in the Pro 4 but they do take 3600 and 3700 packs.
Barger is offline   Reply With Quote
Old 06-22-2005, 01:46 AM   #11829
Skill's Avatar
I'm running a pack of GP3700's in my Pro 4 with the Team PRP chassis and haven't had to make any modifications at all. The cells do sit slightly higher in the chassis than the GP3300's but it's not really a problem. I'm not sure what the standard chassis is like for fitting them in though...
Skill is offline   Reply With Quote
Old 06-22-2005, 09:11 AM   #11830
rc-zombies's Avatar
same bearings used in the one-way and the rear diff..
Old 06-22-2005, 09:13 AM   #11831
rc-zombies's Avatar
with a cutting wheel, dremel, and file. the BD battery tray can be made to fit the Pro4 chassis.... I'll check later tonight when I get home.
Old 06-22-2005, 09:32 AM   #11832
Guo Chean's Avatar
hey zombie so you mean i need to cut some pierce to fit the 3700 battery
Old 06-22-2005, 09:43 AM   #11833
rc-zombies's Avatar
I don't have any 3700 to try...from what I've heard they are taller and slightly fatter... so you may have to file the slots longer to fit. I know the bd tray will fit the new cells. I'll see if its even possible to retrofit the tray into the pro4. I've been wanting to retrofit the trays for a while now since I got the BD... just been too lazy lately.
Old 06-22-2005, 11:07 AM   #11834
rc-zombies's Avatar
Here's the stock setting from the Hara Edition Kit.
pm me with your email if you want PDF file.
Pdf was too large to post.
This is based on the New Hara Set-up sheet.
Front:
#3 hole on shock tower
2mm on sway bar ball end
4mm camber link spacer
#1 hole on arm
2mm spacer F/R toe blocks
2.5deg toe blocks
#1 hole on camber mount
1.5deg. camber
4deg. caster
6mm droop
one-way or spool
1.4(silver) swaybar.
Rear:
3mm on sway bar ball end
3mm camber link spacer
#1 hole on arm
2.5mm spacer F/R toe blocks
3deg. toe blocks
1.5deg camber
5mm droop
Shocks:
Front:
Piston 1.1mm - 3hole
Oil: 45wt
Spring: White
Bladder: new Flat type
Rear:
Oil: 45wt
Spring: Pink
Acherman: #1 hole
Steering knuckle: #1
Front Width:
F: add 1.5mm spacer to each hub
R: add 1.5mm spacer to each hub
Chassis: 2.5mm
Upperdeck: 2.25
Center Post: No.
Old 06-22-2005, 11:19 AM   #11835
Guo Chean's Avatar
what is the part num for the yokomo bd battery tray? for the tray i think i should be fit 3300GP cell only and if you want to fit gp3700 i think you need to pull out the tray
