Like Tree5Likes
Old 06-21-2005, 01:56 PM   #11806
coastaltony's Avatar
RCZ, get the fan?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 06-21-2005, 02:15 PM   #11807
rc-zombies's Avatar
Originally Posted by coastaltony
RCZ, get the fan?
not yet... probably today or tommorrow..
Old 06-21-2005, 03:11 PM   #11808
axel's Avatar
i need help finding a good spur gear for my pro4. I want a 64p 98t spur gear like the hpi one, but the hpi strip too easy for me. Also right now i have geared my car at 7.6 range wiht my 32t pinion, i wanna gear to 33t so it will have a final gear ration of 7.2 like the maual says, but wondering if this might cause overheating to my motor(fantom monster stock). I have a 34t but that heats up my motor too much.
axel is offline   Reply With Quote
Old 06-21-2005, 03:18 PM   #11809
rc-zombies's Avatar
monster stock runs a little hot.. but I have a mini fan on mine
I gear mine to around 6.9 - 7.3+/- depending on track layout. .
if you have scrap lexan laying around...build your own air scoop.
Old 06-21-2005, 05:10 PM   #11810
axel's Avatar
thanks, her rc-zombies what spur gear you use? is it 64p? I'm trying to find a stronger 64p spur gear than the hpi one.
Old 06-21-2005, 05:27 PM   #11811
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
axel,
speedtechRC has a couple of nice 64p 98T spurs in stock. They're pretty strong from what I could discern. Check it out.
atomic80 is offline   Reply With Quote
Old 06-21-2005, 06:13 PM   #11812
Default caster blocks & wide bumper conversion
Hi guys, what effect will changing the front caster blocks have ?
Also, what is the wide bumper coversion I have heard of for this car, and where would be a good place to get one ?
jim beam is offline   Reply With Quote
Old 06-21-2005, 06:54 PM   #11813
Registered User
Default Square's aluminum bevel gear.
Tried searching for an hour now, and I can't find anyone who sells the one piece bevel gears. Does anyone know an online retailer that does? The LHS can't find them either in their database. Speedtech has the aluminum one-way gear, but not the bevels for some reason.
I'm also trying to find someone who sells the replacement parts for the TIR Worlds Edition CVD's. TIR's site is pointless, no good info. I need to buy new CVD pins as they use a smaller diameter pin (0.10mm smaller) and I lost one when my CVD's were apart in my pit box.
Thanks!
Desolas is offline   Reply With Quote
Old 06-21-2005, 06:59 PM   #11814
Trader Rating: 16 (94%+)
try rc champ (http://www.rc-champ.co.jp) or rainbow ten (http://www.rainbowten.co.jp)
HPI 31422 PRO4 Aluminum one piece bevel gear (16T/ front)
HPI 31423 PRO4 Aluminum one piece bevel gear (16T/ rear)
domo is offline   Reply With Quote
Old 06-21-2005, 08:39 PM   #11815
rc-zombies's Avatar
I'm using the Xenon spur gears..very durable made of delrin.
Old 06-21-2005, 08:41 PM   #11816
rc-zombies's Avatar
wide bumper is the BRP TC3 modified to fit the pro4 bumper. helps protect the front end and especially the front bevel gears.
Old 06-21-2005, 08:43 PM   #11817
rc-zombies's Avatar
Thanks!
you will not probably find the 1pc bevel gear input shafts in the US.
Rainbow Ten in Japan has both front and rear in stock...better hurry and order...they sell out very quickly.
for TIR parts.. see the Schumacher website.
Old 06-21-2005, 08:50 PM   #11818
rc-zombies's Avatar
and now something non-technical..
pics of the Hara....
car comes with everything you need.
all the toe-in blocks and spacers.
front one-way and Spool!
white and pink springs.
most of the new 05 parts...
etc etc.
all you basically need are the smaller swaybars and stiffer springs if you're running mod.
This Kit is the one to buy....
the Hara box is actually just a sleeve that goes over the original box.
Hpi Pro 4-hara-pro4-001.jpg   Hpi Pro 4-hara-pro4-002.jpg   Hpi Pro 4-hara-pro4-003.jpg   Hpi Pro 4-hara-pro4-004.jpg
Old 06-21-2005, 08:57 PM   #11819
axel's Avatar
whao! desicions desicions( hara pro4, cyclone)
Old 06-21-2005, 09:14 PM   #11820
Entropy's Avatar
etc etc.
You lucky bugger! Though I got lucky this past weekend...
Entropy is offline   Reply With Quote
