Old 06-14-2005, 08:07 PM   #11731
ExcelRC's Avatar
Send a message via Yahoo to ExcelRC
Originally Posted by jim beam
hi guys, just purchased a pro4.the hpi springset is out of stock.I have been told TC3 springs fit and work well. Can any one shed any light on this ? thanx
The TC3 springs do fit and work well. You can purchase those just about anywhere.
Or here are the HPI springs in stock:
http://excelrchobbies.com/product_in...d0aca70613a686
ExcelRC is offline   Reply With Quote
Old 06-14-2005, 11:22 PM   #11732
axel's Avatar
are the tc3 springs alomost identical to the hpi ones?
axel is offline   Reply With Quote
Old 06-15-2005, 07:01 AM   #11733
kewdawg's Avatar
Originally Posted by axel
i know off- topic , but i need the most accurate way to get the holes alligned for my new stratus 3.0 body? I alsways get it wrong sometimes and have to cut the wheel holes larger to make the tires not rub against it.
thanks
Axel
Get the Trinity "no brainer" body mounts. they work really well. Put them on your body posts, then position the body on the car where you like and press down. The mounts will make little indentations for you to use a reamer or drill to make the body holes.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-15-2005, 07:03 AM   #11734
kewdawg's Avatar
Only in size and length. They have different poudage / gram ratings.
Quinn Moon
Old 06-15-2005, 12:38 PM   #11735
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Default couple of questions
first up: how do i balance my pro4? i mean static weight distribution.
second up: what servo does(/has) hara use(d)?
floodo1 is offline   Reply With Quote
Old 06-15-2005, 12:43 PM   #11736
axel's Avatar
hara has been using the KO 2363 great servo, but the 2343 i like better cause it's cheaper. The 2363 has a heat sink cause mainly it's designed for those long nitro mains.
Old 06-15-2005, 01:03 PM   #11737
floodo1's Avatar
ok now only 1 question left
Old 06-15-2005, 02:07 PM   #11738
rc-zombies's Avatar
you could weight the battery then weight all the components on the electronic side. whichever is lighter..mostly likely the electronic side.. that is where you need to add weight to balance the car... I've added about 2oz on mine.
Old 06-15-2005, 04:55 PM   #11739
Intergy make a digital weight distribution system C22330
www.intergy.com
Barger is offline   Reply With Quote
Old 06-15-2005, 05:15 PM   #11740
loopedeloop's Avatar
www.intergy.com
umm thats a medicare site lol
Try this:
http://integy.automated-shops.com/cg...43105147061.10
loopedeloop is offline   Reply With Quote
Old 06-15-2005, 05:24 PM   #11741
rc-zombies's Avatar
I think it's easier to get 4 postal scales under each tire and probably cost less the Integy scale. scales are cheap on ebay...$10-15 each.
Old 06-15-2005, 05:29 PM   #11742
floodo1's Avatar
i was thinking of using the two holes (1 front, 1 back) that are under the tranny cases. they appear to be in the centerline of the car. support the car from underneath via those holes and see if it falls over to one side of the other.
i could use that at least for side to side. front o back i could prolly just put each end of the car on a seperate scale....prolly.
just wondering if anyone had tried anything other than weighing components or using scales under each wheel.
but now that i think about it if i let the car sit with the shocks bottomed out it would give me corner weights independant of shock settings.
hmmmm yay for thinking out loud! thanks for the advice
Old 06-15-2005, 05:31 PM   #11743
rc-zombies's Avatar
Like this.. Xray balancing tool
Old 06-15-2005, 05:42 PM   #11744
JayBee's Avatar
Trader Rating: 31 (100%+)
Wink
Is that bumper brace CA'ed -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-15-2005, 05:54 PM   #11745
rc-zombies's Avatar
nope.
