Like Tree6Likes
Old 06-13-2005, 11:53 AM   #11716
Pezz's Avatar
Send a message via Yahoo to Pezz
Originally Posted by billtc3
I've lost the e-clip too! Looks like during a crash, the forces applied to the one-way / spool are so big, that something has to break! The aluminum bevel gear won't break nor will the small gear. So, what happened to my car was that the e-clip was bent out of place and the small gear stripped at the pin that locks it on the shaft! Meaning that none of the small gear's teeth broke, instead the hole where the pin sets, opened up! (I hope what I wrote makes sense, I couldn't make any more clear)
In the end, the aluminum bevel gear might not be worth it, cause you still end up with a damaged drivetrain
I have had the same thing happen. You make one part stronger it still has to give somewhere.
Pezz is offline   Reply With Quote
Old 06-13-2005, 04:14 PM   #11717
Rcjunk-yard's Avatar
Default breakage
Yeah, it all comes down to which part you would prefer to replace all the time. I remember the time when a nitro car "MET" (rear ended) with my XXX-S and it destroyed the center of the diff pulley.
Rcjunk-yard is offline   Reply With Quote
Old 06-13-2005, 04:51 PM   #11718
axel's Avatar
Just to clear things up...is the Hara or 2005 edition out yet?? I'm assuming the 2005 one is already,I just need confirmation.
axel is offline   Reply With Quote
Old 06-13-2005, 04:54 PM   #11719
rc-zombies's Avatar
yes the '05 edition is already being sold in Asia.
$420 in HK
$490 in Japan.
Hara should be in the US by end of the month or early July.
Old 06-13-2005, 07:57 PM   #11720
Din Viesel's Avatar
Can not wait to get my hands on a Pro 4, already got the ceramic bearings on order! Have a friend who is a distributor working on a Hara Edition will be glad to hit the carpet again!
Din Viesel is offline   Reply With Quote
Old 06-13-2005, 08:07 PM   #11721
axel's Avatar
nice...how much were those bearings you ordered? And you got a Hara edition...lucky .
Old 06-13-2005, 08:12 PM   #11722
Din Viesel's Avatar
The bearings are $99.00 from Acerracing.com and I forgot how much the diff and thrust balls where any way I am excited to say the least!
Old 06-13-2005, 08:20 PM   #11723
Din Viesel's Avatar
Sorry that was $99.99 USD, I know whats .99 but if I didn't correct myself someone else would!
Old 06-13-2005, 09:21 PM   #11724
Default pro 4 shock springs
hi guys, just purchased a pro4.the hpi springset is out of stock.I have been told TC3 springs fit and work well. Can any one shed any light on this ? thanx
jim beam is offline   Reply With Quote
Old 06-13-2005, 10:45 PM   #11725
rc-zombies's Avatar
din.
what's wrong with the stock bearing...they're already super smooth and lubed with light oil... I'm able to get the drive train to spin freely with the stock bearingss
with the $99.99 I'd rather buy other neccessary parts. springs, tires, wheels, spare parts. etc.
Old 06-13-2005, 11:00 PM   #11726
Din Viesel's Avatar
RC
You are right about some stock bearings! I used to get my stocks super smooth and thought these were the best.....and then a fellow racer showed me how smooth his car was with ceramics and holy Sh!t. I (just my personal opinion) think that the bearings are well worth the investment. I have used them for years now and I can get my belt car ATLAS YM-34 SI to free spin longer than any of the other belts or any Shaft car out there! But yes that kind of money could easily go to motors, batts ect..
Old 06-14-2005, 07:32 AM   #11727
Trader Rating: 17 (100%+)
you can get it online, i just got mine part number #75175 and it have 7 pair of spring
cheers
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 06-14-2005, 05:39 PM   #11728
rc-zombies's Avatar
BMI is have a clearence sale on Pro4 chassis sets.
see the forsale threads. limited qty's
BMI PRO4 kit in satin black retail$109.99 now$88.
Old 06-14-2005, 06:47 PM   #11729
axel's Avatar
i know off- topic , but i need the most accurate way to get the holes alligned for my new stratus 3.0 body? I alsways get it wrong sometimes and have to cut the wheel holes larger to make the tires not rub against it.
thanks
Axel
Old 06-14-2005, 07:36 PM   #11730
Hi everyone i have 2 NIB LRP QC2 for sale, 130 each shipped or both 250 shipped. anything pm me. thanks.
cheers
Tamiya TB Evo 5
