Like Tree6Likes
Old 06-11-2005, 10:26 PM   #11701
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by fjm9898
does anyone know the part # for the new purple aluminum servo mount that has the transponder mount built in that comes with the new hara Ed?
#31401, only from JAPAN.
However, I found this place (order from them before, GOOD service), not exactly from HPI, but the parts look 99% like the HPI one except a lot cheaper...
http://precisionrc.com/cgi-bin/cart.pl?BR=JET2&DT=2
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 06-12-2005, 11:26 AM   #11702
axel's Avatar
anyone know who makes aluminum servo saver arm sets?
axel is offline   Reply With Quote
Old 06-12-2005, 02:26 PM   #11703
Rcjunk-yard's Avatar
OFNA makes some, you can get them at www.nitrohouse.com
Rcjunk-yard is offline   Reply With Quote
Old 06-12-2005, 03:26 PM   #11704
axel's Avatar
how do i prevent my front tire from running against the screw on my shocks that connect it to the a-arm?
Old 06-12-2005, 03:28 PM   #11705
rc-zombies's Avatar
jet parts hold up well.. and they cost 1/2 as much as the HPI parts.
I hove those plus the servo saver arms.
Old 06-12-2005, 03:32 PM   #11706
rc-zombies's Avatar
adjust your steering EPA
Old 06-12-2005, 09:35 PM   #11707
axel's Avatar
anyone here yet try the square aluminum front gear yet?? Is it worth it?
Old 06-12-2005, 09:38 PM   #11708
axel's Avatar
also anyone here have a link to the motor spacer to align the pinion and spur gear...or know which spur gear is thick enough to cover the whole pinion?
Old 06-12-2005, 10:10 PM   #11709
rc-zombies's Avatar
me...
to me it's worth it... I've lost the e-clip on the small bevel gear during a race..
Old 06-12-2005, 10:14 PM   #11710
rc-zombies's Avatar
you'll need something like the Speedmind motorheatsink Plate.
see:
http://shopping.rcmodel.com.hk/
type in heatsink to do the search.
or just buy the new motor mount.
Old 06-12-2005, 10:19 PM   #11711
axel's Avatar
once again Ramon to the rescue!
thanks
Old 06-12-2005, 11:08 PM   #11712
rc-zombies's Avatar
if you guys haven't yet...
the new interactive and non-interactive Hara Set-up sheets are now available for download from the HPI website.
http://www.hpiracing.com/index2.htm
Old 06-13-2005, 05:17 AM   #11713
Originally Posted by rc-zombies
me...
I've lost the e-clip too! Looks like during a crash, the forces applied to the one-way / spool are so big, that something has to break! The aluminum bevel gear won't break nor will the small gear. So, what happened to my car was that the e-clip was bent out of place and the small gear stripped at the pin that locks it on the shaft! Meaning that none of the small gear's teeth broke, instead the hole where the pin sets, opened up! (I hope what I wrote makes sense, I couldn't make any more clear)
In the end, the aluminum bevel gear might not be worth it, cause you still end up with a damaged drivetrain
billtc3 is offline   Reply With Quote
Old 06-13-2005, 09:14 AM   #11714
Skill's Avatar
You can beef up the drivetrain as much as you want but when you crash something has to give, whether it's the bevel gears, spur gear, or CVD bone. I suppose you could argue that when you crash the tyres will give, yes they probably will, but not all that much unless you have almost no grip at all!!
I suppose if you go really over board then the only thing left to give is the thing you are hitting, but if that's a brick wall then that's not likely to happen
Skill is offline   Reply With Quote
Old 06-13-2005, 09:23 AM   #11715
rc-zombies's Avatar
Erik
now that Hara's into 4wd off-road racing...and recently won the pre-worlds with a TC3 Durango. will there be a Pro4 off-road in developement?
