Like Tree6Likes
Old 06-10-2005, 11:42 PM   #11686
rc-zombies's Avatar
Asia gets the Spec 2005 Edition: 2mm chassis w/bevel gear input shafts.
US and Europe the Hara Edition. 2.5mm chassis w/1pc spur gear input shaft and MIP CVD's
everything else is almost the same.
I agree... HPI should have released 1 kit.
Old 06-10-2005, 11:43 PM   #11687
psixt234's Avatar
Originally Posted by Rookie Solara
I am confused now...not that I would buy another PRO 4 when my current PRO 4 is more then good enough for me...
US get the 2005 spec Pro 4 and Japan is under the badge of the HARA edition? Or the other way around...? And 2005 spec is the better one (value)..? Or the HARA edition is the better one....?
Why are ppl like to screwing ppls head....can they just make one called " Atsushi HARA 2005 spec edition PRO 4" and make everyone happy...? Are we asking too much here..?
2005 ed come with oneway and Hara ed. come with spool.
psixt234 is offline   Reply With Quote
Old 06-11-2005, 12:44 AM   #11688
RCknight's Avatar
Default I guess my kit is 0.6 version....
what was improved over the 0.8 and 1.1 versions? I noticed my diff cases don't seal well. Was there an updated version?
RCknight is offline   Reply With Quote
Old 06-11-2005, 12:27 PM   #11689
RCknight's Avatar
Default Anybody out there...
Old 06-11-2005, 03:18 PM   #11690
Matt Pocknell's Avatar
Sorry about this question...cant be bothered to look through so many pages.
Is there a solution to the bevel gears stripping when using a spool? I use a diff at the moment in 19t and would like to buy a spool, only to hear so many bad things about how they strip gears.
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 06-11-2005, 03:28 PM   #11691
loopedeloop's Avatar
wrong thread
loopedeloop is offline   Reply With Quote
Old 06-11-2005, 03:33 PM   #11692
scoobydo's Avatar
They have aluminum input shafts with the 16t bevel gear. About $17 bucks.
Also, Square or Jet make the 32t aluminum bevel gear for the front.
You should be good to go with that installed up front using a spool.
EDIT:
Its was Square
Aluminum Bevel Gear for the Pro 4
#SHP-19
$34
scoobydo is offline   Reply With Quote
Old 06-11-2005, 05:37 PM   #11693
Solara's Avatar
Trader Rating: 16 (100%+)
Last time I talked to Atsushi...he said HPI will release a HARA @ USA Cali Pro 4 edition, and HARA @ Japan Homie Pro 4 edition...........since he is back and forth between these 2 countries quite a lot (I am kidding here...)
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 06-11-2005, 06:24 PM   #11694
rc-zombies's Avatar
you almost got me going there...til the end...
Old 06-11-2005, 06:25 PM   #11695
rc-zombies's Avatar
EDIT:
Its was Square
#SHP-19
$34
going with an all aluminum bevel gear set-up... something else will break.
I'd rather break a $2+ bevel gear than a $9 CVD bone or axle.
Old 06-11-2005, 06:59 PM   #11696
fjm9898's Avatar
does anyone know the part # for the new purple aluminum servo mount that has the transponder mount built in that comes with the new hara Ed?
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 06-11-2005, 07:23 PM   #11697
axel's Avatar
anybody here experince that your drive shaft is kinda getting eaten up from the scre on the servo saver? I was recomennded to put a washer, but what do you guys do
here are some pics...the big silver bar on the shaft is the problem, just gets grinded up
axel is offline   Reply With Quote
Old 06-11-2005, 07:26 PM   #11698
fjm9898's Avatar
yea i had that happen, it was so little it only took the purp;e off and that was it. what i did after the fact was take a dremel and just shave a bit of the screw part of the ball stud that was touching the shaft
Old 06-11-2005, 08:39 PM   #11699
nw racer's Avatar
I did the same thing then I also adjusted my end points to ensure it couldn't have a chance of hitting it.
nw racer is offline   Reply With Quote
Old 06-11-2005, 08:48 PM   #11700
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
I just put a 2mm purple washer on and that solved the eating the driveshaft issue! I think that's easier than taking a dremel to it.
atomic80 is offline   Reply With Quote
