Old 06-07-2005, 09:21 AM   #11566
rc-zombies's Avatar
Originally Posted by tony2
does anyone know where i can get the alloy camber plates that come standard on the 2005 pro4?
the Jet version is just as good and half the cost. available from RcModel in HK.
Old 06-07-2005, 10:17 AM   #11567
rc-zombies's Avatar
axel.
if you're going to race with the 3mm chassis on asphalt...you may want to aquire the new high traction arm set. more durable than stock graphite arms. made of plastics and slightly more flex. available overseas...unfortunately...I sold the last I have last month.
Old 06-07-2005, 10:42 AM   #11568
RCknight's Avatar
Default RCZombie....
what is the difference between the .08 and 1.1 versions?
Just got me a Pro 4.
Also what is the part number for the new motor mount?
What all do I need for this car? CF camber braces, aluminum steering, Ti screw set, and BMI chassis for carpet?
RCknight is offline   Reply With Quote
Old 06-07-2005, 11:13 AM   #11569
axel's Avatar
Originally Posted by rc-zombies
axel.
Where do you get these plastic arms?
axel is offline   Reply With Quote
Old 06-07-2005, 11:15 AM   #11570
rc-zombies's Avatar
don't know if they will available yet in the US... got mine from Rainbowten in Japan. $12 for a complete set of 4.
Old 06-07-2005, 11:37 AM   #11571
axel's Avatar
Well i'm hopefully going to race my car again this saturday (asphalt). I have made many adj. so far tell me what you think? I do not kno how the track is going to be though.
caster:6 degrees
droop:7 front 6 rear
ride height: 5mm
front shocks: gold, 35wt. fluid, #2 hole on shock tower and outside holes for arms
rear shocks: silver, 35wt. fluid, #2 hole on shock towers, and middle hole for arms.
swaybars: front: 1.6mm, rear:1.2mm(or none)
camber link: #1 hole on both
front roll center:-1 washer
And any suggestions on rear anti-squat and anit-dive and kick-up for the pivot blocks? (i'm also running out of the box pivot blocks settings)
Old 06-07-2005, 11:37 AM   #11572
RCknight's Avatar
Default Anyone know what page the bumper mod is....
on? What do I need?
Old 06-07-2005, 11:38 AM   #11573
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
Do you have a part number for those plastic arms from RainbowTen? I may get them
atomic80 is offline   Reply With Quote
Old 06-07-2005, 11:44 AM   #11574
rc-zombies's Avatar
full set of 4arms. 2f/2r
3023430231420,HPI,,1000yen,31420 PRO4 HIGHT TRACTION SUSPENSION ARM SET(2 PCS)
Old 06-07-2005, 11:50 AM   #11575
RCknight's Avatar
Can anyone help me?
Old 06-07-2005, 11:56 AM   #11576
rc-zombies's Avatar
new motor mount:
3023430275192,HPI,,1980yen,75192 PRO4 ALUMINUM MOTOR MOUNT PURPLE
steering set:
3023430231421,HPI,,4200yen,31421 PRO4 ALMINIUM STEEING CRANK SET
CF camber plate and Jwerk Ti screws visit
Allspeed hobbies..they have them instock. tell them I recommened you.
BMI Chassi:
http://www.bmiracing.com/products_hpi.htm
Old 06-07-2005, 12:02 PM   #11577
RCknight's Avatar
Default Thanks man....
one other thing, what is the difference between the .08 and 1.1 versions?
Old 06-07-2005, 12:05 PM   #11578
rc-zombies's Avatar
old gears had a thin back plate...thus resulting in gear strippage.
new gears are thicker and the one-way gear has an aluminum back plate to go with it... if you do not have them..contact HPI customer service and tell them you have an old kit with older gears...and they will send you out the new gears and backplate for free... if you're lucky..sometime they will send you some extra HPI / Pro4 decals as well....
Old 06-07-2005, 12:08 PM   #11579
axel's Avatar
Pics of my pro4
Old 06-07-2005, 12:36 PM   #11580
axel's Avatar
the body is from maxperformance.net...really cool paint schemes.
