Like Tree6Likes
Old 06-05-2005, 09:28 AM   #11536
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally Posted by tc3 racer sc
i want to know what the diffrents between shock pistons from 1 thru 5 and how would it affect handling
More holes on the piston the faster the travel of the shocks will do. I use 2-3 holes as my base setup.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 06-05-2005, 11:42 AM   #11537
cyclone's Avatar
Do you guys put the put the delrin outdrives on the front diff?
If not is there a reason for this? and is it softer than the grafite 1's ie will it brake easier?
cyclone is offline   Reply With Quote
Old 06-05-2005, 12:31 PM   #11538
JayBee's Avatar
Trader Rating: 31 (100%+)
I thought it was the opposite way around? -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-05-2005, 12:41 PM   #11539
Solara's Avatar
Trader Rating: 16 (100%+)
There are 2 damper sytem (may be more, but I only know these 2)....# of holes, or the size of the holes.
For Pro 4....the more the holes, the faster the rebounce speed because oil can travel thru the damper's holes inside the chamber thru more openings (holes)....if only 2 holes, oil can only travel within these 2 holes...vice versa, 5 holes, oil have more openings to travel, that is = faster damper rebounce speed.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 06-05-2005, 01:08 PM   #11540
Skill's Avatar
I run the delrin outdrives on both front and rear diffs and they have been absolutely fine so far. From what I gather delrin is supposed to be stronger than graphite so there should be no durability issues. I think the reason some people think delrin is quite weak is because of TIR's spool which uses delrin outdrives, but there's a lot more force involved when you're running a spool.
Skill is offline   Reply With Quote
Old 06-05-2005, 01:12 PM   #11541
JayBee's Avatar
Thumbs up
Thanks...BTW what part of the Chi are you from? I grew up on the South Side, 4155 So. Lake Park by the old One-Stop grocery store and Martin Luther King HS -JB
Old 06-05-2005, 06:16 PM   #11542
GRF
GRF's Avatar
What pro 4 shock piston number do you use? I still use the #3 piston as per manual. I also use 35wt shock oil with it. What piston-oil combo do you recommend for low to medium grip concrete tracks?
GRF is offline   Reply With Quote
Old 06-05-2005, 07:00 PM   #11543
axel's Avatar
Well guys i just came back from my race. I did horrible, but had fun. My spring combo was awful, and i couldn't get my car dialed, but i was able to manage. Next time i'm just going to run the out of the box combo,and use my bronze sway bars.
axel is offline   Reply With Quote
Old 06-06-2005, 01:06 PM   #11544
Erik Shauver's Avatar
Updated Pro 4 setup sheets are available. Check out the site.
Erik Shauver is offline   Reply With Quote
Old 06-06-2005, 01:08 PM   #11545
axel's Avatar
you think there will be a hara coversion kit?
Old 06-06-2005, 01:23 PM   #11546
rc-zombies's Avatar
Erik
I've built up a Hara Edition already...
can I buy just an empty box?
Old 06-06-2005, 06:28 PM   #11547
axel's Avatar
Anyone here know a good 3mm chassis asphalt setup?(stock)
Old 06-06-2005, 06:34 PM   #11548
kewdawg's Avatar
If, you're running foam, yes.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-06-2005, 06:42 PM   #11549
axel's Avatar
o sorry, i forgot to mention i'm running rubber (rp30's)
When i went racing yesterday my pro4 wasn't dialed at all, there seemed to be front traction problem, the front would leave of the ground when cronering hard.
track and tires :110 degrees, rp30's most peolpe were running rp30's that day. people claimed 27's were running out of traction during the end of the day.
My setup: front: yellow/black springs, 50wt. shock fluid, #1 shock pistons
rear: stock gold springs, 50wt. fluid, #1 shock pistons
ride height: 5mm
sway bars: 1.2mm all around
Old 06-06-2005, 06:50 PM   #11550
fjm9898's Avatar
your main problem is the 3mm chassis. if you have the stock 2.5 i would use that or possbily go the 2mm chassis. the 3mm is used mainly for carpet unless you really have extra high grip asphalt. try a different chassis it should help then work from there
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
