Old 01-21-2004, 10:57 AM   #1141
Erik Shauver's Avatar
I've always been told if you have nothing nice to say then don't say anything at all... that said, see my comment on that chassis below:
Erik Shauver is offline   Reply With Quote
Old 01-21-2004, 11:01 AM   #1142
Thad Garner's Avatar
Thad Garner is offline   Reply With Quote
Old 01-21-2004, 11:04 AM   #1143
rc-zombies's Avatar
Thad/Erik
you guys racing with the center chassis post installed? how's it effect the handling?
Old 01-21-2004, 11:11 AM   #1144
pucho's Avatar
Send a message via AIM to pucho
Release day?
pucho is offline   Reply With Quote
Old 01-21-2004, 11:17 AM   #1145
Old 01-21-2004, 11:23 AM   #1146
CRASH's Avatar
Trader Rating: 26 (100%+)
Ok, I am waiting very very paitiently for a release date! It is becoming very difficult not to buy another TC. You guys have to have a ballpark time frame, don't you?
Come on shed some light on this, I am definetly wanting to try this car and was hoping to have one in time for the birds, but at last I guess I will run my XRAY.
Thanks, Sort of
CRASH is offline   Reply With Quote
Old 01-21-2004, 11:24 AM   #1147
pucho's Avatar
Thumbs up How to cook gears!
I got part but no car!
Well I desided to build the extra diff I have,
You don't need to boil them just need to give them a hot bath.
Also Leave then in the water untill it cools to room temperature, you don't wan't an extreme tenperature change because they could warp.
It's Old school stuff.
Old 01-21-2004, 11:28 AM   #1148
rc-zombies's Avatar
my new gears and some other goodies are finally on it's way to me...can't wait to run the car. no Over-cooked gears this time....
Old 01-21-2004, 11:35 AM   #1149
rc-zombies's Avatar
We've had mixed results with the center post. I usually run without it. It adds a bit of overall stiffness to the chassis when installed, but at the expense of another pivot point to possibly retain a tweak in impacts.
Think of it like the old center post on a Pro 2. Try it, check your laptimes. Remove it and check your laptimes. It would be a very slight feeling difference also, but very slight. I would recommend using a button head screw and not countersinking this hole in the upper deck also.
Although most will say stiffer is better, we usually let laptimes decide.
-E
Thanks for the tip...I'll try it with and without...
yea I remember the Pro2...that was a great car..built like a tank! If HPI ever goes back to belt...they should refine the Pro2.
Old 01-21-2004, 02:36 PM   #1150
johnny55's Avatar
Send a message via AIM to johnny55
What does boiling or heating up the gears do for your car? Do you do the same with the beval gears?
Johnny Hernandez
Fight on!
johnny55 is offline   Reply With Quote
Old 01-21-2004, 02:45 PM   #1151
rc-zombies's Avatar
it's for the Bevel gears...boiling them adds moister back into the gears so that they are not so brittle. Makes them more durable. I also soak mine in some Paragon Ultralon for lubrication.
Old 01-21-2004, 02:50 PM   #1152
pucho's Avatar
Did you notice after boiling them that the spacer that goes inside the gear fit's much tighter.
Old 01-21-2004, 02:54 PM   #1153
rc-zombies's Avatar
didn't get a chance to check...I over-cooked my gears to well done. waiting for more gears to arrive from Japan ealy next week...
Old 01-21-2004, 03:55 PM   #1154
JusBox's Avatar
Thanks, Sort of
R3s are selling well!
JusBox is offline   Reply With Quote
Old 01-21-2004, 07:49 PM   #1155
tcdrvr's Avatar
Default Pro 4 on carpet and foams
Hey Erik or Thad... The website says you've done extensive carpet testing with the Pro 4. Any chance of either of you telling what springs you've found work with foam tires on carpet? I plan to race the car in the Snowbird Nationals and I could use the starting point.
tcdrvr is offline   Reply With Quote
SEO by vBSEO 3.5.0
