Like Tree6Likes
Old 06-04-2005, 02:18 AM   #11521
adamkerrnz's Avatar
I found i could tighten my diff more than before when i put the TC3 kit and ceramic nitride balls in. It was also way smoother than it was with the stock gear
adamkerrnz is offline   Reply With Quote
Old 06-04-2005, 02:43 AM   #11522
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Erik Shauver
rc-z: I don't have anything firm, but I've heard around $75 over a std P4... but don't hold me to that.
Did I see the World Famous Erik Shauver on the results list of the Reedy Race???????????
What's up Erik? Hope all is well out there... You guys coming to Cleveland this year?
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 06-04-2005, 05:50 AM   #11523
cyclone's Avatar
Do you guys put the put the delrin outdrives on the front diff?
If not is there a reason for this? and is it softer than the grafite 1's ie will it brake easier?
cyclone is offline   Reply With Quote
Old 06-04-2005, 09:10 AM   #11524
Registered User
What problems do people find wrong with the stock diff nut? I've had no problems...yet? And how do i do this tc3 mod?
For some people it will not stay tightened, and the standard head screw is kind of a pain to adjust. You just replace the thrust screw with an associated assembly, including the nylon piece with the lock-nut in it. This gives you a 2mm hex head as well which is easier to adjust, especially if you've got a round hex driver.
Desolas is offline   Reply With Quote
Old 06-04-2005, 09:51 AM   #11525
wagonman72's Avatar
The HPI screw setup is designed to allow diff adjustment without popping the upper link off.
wagonman72 is offline   Reply With Quote
Old 06-04-2005, 02:03 PM   #11526
axel's Avatar
Does anyone here know a better one-way shim setup than the out of the box one they give you? I tried adding one more shim, but it totaly ate up 2 teeth in the front one-way gear, and ate one tooth on the input shaft gear.
axel is offline   Reply With Quote
Old 06-04-2005, 06:11 PM   #11527
axel's Avatar
Originally Posted by rc-zombies
one of each set is all you need for asphalt and carpet.
320(18.0) #6548 PINK
340(19.0) #6544 GOLD Stock Spring.
363(20.3) #6545 WHITE
388(21.7) #6546 YELLOW
400(22.4) #6542 RED
right now I'm using Yellow and gold for asphalt w/rubber tires.
which spring goes where?
Old 06-05-2005, 09:24 AM   #11528
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Most of the time, front springs are harder than the rear. you may try white for the front, gold for rear. It depends on your track condition what to use.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 06-05-2005, 09:27 AM   #11529
axel's Avatar
so I should place the gold rear and the yellow/black in the front?
Old 06-05-2005, 09:32 AM   #11530
Trader Rating: 16 (100%+)
If I remembered correctly, you are suppose to add shim in order to make your 1 way diff CLOSER to the input shaft gear, but not binding to each other...
I don't remember it was my NTC3 or the Pro 4 (which is sucks cause I service both cars at the same time and don't remember 100% which is which)....the manual said 2 shims on the 1 side for the 1 -way, I ended up using 3 shims (1 extra more then the manual said)........and I have never get stripped gear problem except 1 time my shaft cap was broken, 1 thing to the other, the whole front trans were ended up in a melted plastic.
No diff case are made the same, so yours might only need 2, but mine, I need 3....(there are no shim required on the NON DIFF GEAR side of the bearing spacing..)
Old 06-05-2005, 09:36 AM   #11531
axel's Avatar
thanks for the tip, hope this is true when i race today.
Old 06-05-2005, 09:40 AM   #11532
Geetoo's Avatar
Hope you make a few runs with your new spring settings, check if car is well balanced off the corners. Smooth tracks use harder combo's. Good luck!
www.hpiracing.com
www.nosram.com
Old 06-05-2005, 09:46 AM   #11533
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
I run white in front with the stock silver in back.This works well on low/medium grip asphalt. I also run the spool in front with 1 degree rear anti-squat...2.5 front block and 3.0 rear.
James Cooper
SouthernFriedRacing
[email protected]
SOuthernFRIED is offline   Reply With Quote
Old 06-05-2005, 09:53 AM   #11534
axel's Avatar
Thanks...well have to go now, i'll tell you how the settings went.
Old 06-05-2005, 10:14 AM   #11535
tc3 racer sc's Avatar
Default there was a posting on shock piston could some one explain
i want to know what the diffrents between shock pistons from 1 thru 5 and how would it affect handling
tc3 racer sc is offline   Reply With Quote
