Old 06-02-2005, 10:12 AM   #11506
That's funny...I guess I'm already running the 05 Spec then with the upper deck mods and hop ups i've added.
DOTMAN is offline   Reply With Quote
Old 06-02-2005, 01:15 PM   #11507
cyclone's Avatar
could some1 tell me what the best is for tight high grip track.
With centre post or not?
Why will this change the set up, is it for rigidity?
cyclone is offline   Reply With Quote
Old 06-02-2005, 03:25 PM   #11508
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally Posted by floodo1
hpi v. ae springs:
hey i see in thad's setup for socal that he uses ae gold spring. what is closest hpi spring?
how close are hpi to ae springs? my friend was like "just use ae springs if you have them", but i dont, so are hpi and ae springs close or whats the deal?
thanks
no one can answer?
floodo1 is offline   Reply With Quote
Old 06-02-2005, 03:31 PM   #11509
rc-zombies's Avatar
no one can answer?
273(16.3) #6542 BLUE
302(16.9) #6543 SILVER
320(18.0) #6548 PINK
340(19.0) #6544 GOLD
363(20.3) #6545 WHITE
388(21.7) #6546 YELLOW
400(22.4) #6542 RED
mm/gr (in/lb)
Old 06-02-2005, 03:41 PM   #11510
Thad Garner's Avatar
no one can answer?
I can answer...
I normally use HPI white front and pink rear for SoCal.
AE springs are slightly stiffer.
HPI Racing - HB - R1Wurks - LRP
Thad Garner is offline   Reply With Quote
Old 06-02-2005, 04:56 PM   #11511
floodo1's Avatar
thx thad and zombies, quotes of your own questions sure seem effective
Old 06-03-2005, 05:08 AM   #11512
Default Pro 4 Setup
I just purchased a Pro 4 and would to find a stable setup for an asphalt technical track. Could someone please advise where I can find one.
pcmlc is offline   Reply With Quote
Old 06-03-2005, 09:37 AM   #11513
rc-zombies's Avatar
after installing the new HPI diff screw and T-nut...
the TC3 diff mod is easier to install. I like the 2mm hex on the TC3 screw vs HPI's slotted screw. plus the TC3 T-nut and screw cost a dollar or two less.
Old 06-03-2005, 10:19 AM   #11514
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Ramon what you say correct i also buy a pro 2005 spec t-nut and screw 4 Bucks after i install it in my rear diff the problem still the same did not solve also but the TC3 t-nut modified after i had install it did not slip at all even i adjust until loose.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-03-2005, 11:50 AM   #11515
axel's Avatar
Anyone here know the popular spring setup for asphalt and carpet stock. I'm thinking about getting the spring set, but i don't want to spend $30 on a setp of spring i might not need.
axel is offline   Reply With Quote
Old 06-03-2005, 11:55 AM   #11516
rc-zombies's Avatar
one of each set is all you need for asphalt and carpet.
340(19.0) #6544 GOLD Stock Spring.
400(22.4) #6542 RED
right now I'm using Yellow and gold for asphalt w/rubber tires.
Old 06-03-2005, 03:59 PM   #11517
adamkerrnz's Avatar
yer i prefer the hex head on the TC3 screw. makes it easier to adjust.
adamkerrnz is offline   Reply With Quote
Old 06-03-2005, 11:04 PM   #11518
axel's Avatar
What problems do people find wrong with the stock diff nut? I've had no problems...yet? And how do i do this tc3 mod?
Old 06-04-2005, 12:41 AM   #11519
moot's Avatar
i'm just rebuilding my diff,how tight should i do it up?
moot is offline   Reply With Quote
Old 06-04-2005, 12:43 AM   #11520
Skill's Avatar
So that when you hold one wheel and the spur gear you can hardly turn the wheel on the opposite side.
Skill is offline   Reply With Quote
