Like Tree5Likes
Old 06-01-2005, 11:04 PM   #11491
Lokanas's Avatar
Mostly with medium or low grip and fast motor tight diff would tend to lose traction. Check it yourself and you'll get the point. It's much harder to describe than to feel what it does.
Lokanas is offline   Reply With Quote
Old 06-01-2005, 11:58 PM   #11492
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
if you have the rear diff ultra tight, you can do donuts going into and coming out of corners. Something else you can try, tighten the diff some more.
Get someone who has a Pro4 that handles well and see if they can drive yours and see what they suggest.
dontfeelcold is offline   Reply With Quote
Old 06-02-2005, 12:04 AM   #11493
adamkerrnz's Avatar
so thats the pro's speed secret
adamkerrnz is offline   Reply With Quote
Old 06-02-2005, 02:34 AM   #11494
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
How do you solve diff nut loosening up?
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 06-02-2005, 02:37 AM   #11495
Pro4's Avatar
If you rebuild your diff all the time, replace the little lock nut regularly
Pro4 is offline   Reply With Quote
Old 06-02-2005, 02:37 AM   #11496
adamkerrnz's Avatar
TC3 diff rebuild kit comes with a special nylon nut with a metal nut inside the nylon. never comes loose.
Old 06-02-2005, 02:52 AM   #11497
Lokanas's Avatar
seconded
Old 06-02-2005, 08:19 AM   #11498
rc-zombies's Avatar
or just buy the new diff nut and screw kit
HPI #73522 should be in the states in a few weeks.
installing mine today.
Old 06-02-2005, 08:21 AM   #11499
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
I installed the HPI version yesterday and it works great! No more loose diff!
atomic80 is offline   Reply With Quote
Old 06-02-2005, 09:45 AM   #11500
rc-zombies's Avatar
My '05 Spec / Hara edition:
with new 2.25mm upperdeck, motor mount, and new flourine coated Pro shocks.
Hpi Pro 4-pro4-spec-001.jpg   Hpi Pro 4-pro4-spec-002.jpg   Hpi Pro 4-pro4-spec-004.jpg
Old 06-02-2005, 09:49 AM   #11501
dizzy1's Avatar
Trader Rating: 24 (100%+)
Zombie, how much thicker is the motor mount, I remember reading they made it thicker to push the motor towards the front a few millimeters to help the front to back balance.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 06-02-2005, 09:54 AM   #11502
rc-zombies's Avatar
new motor mount is approx 2mm thicker.
Old 06-02-2005, 10:07 AM   #11503
I'm sure it's been mentioned in this thread somewhere already, but what is the 05 spec. I don't see that on the HPI site anywhere? How is it different from the original?
DOTMAN is offline   Reply With Quote
Old 06-02-2005, 10:09 AM   #11504
rc-zombies's Avatar
it's on the HPI Japan website
The USA/ Europe 2005 Spec Pro 4 will have the following:
All standard Pro 4 features
+2.5mm main chassis (original main chassis)
+new upper deck (as shown -- more lateral flex, same fore to aft stiffness, reduced chance of tweaking on impacts, with cone washers and o-rings over the steering posts as used by Hara)
+new motor mount (as shown)
+new shocks (fluorine coated, new bladders, new pistons, new shafts, as shown)
+Delrin diff out drives
+new 1 piece aluminum rear input shaft (combines spur adapter and shaft, with solid pins, much more rigid gear mounting, different than Japanese spec parts)
+new aluminum front input shaft
+new diff nut and new diff screw (larger screw size + T-nut)
+aluminum steering servo mounts
+Spool and One Way will be included
+full range of pivot block spacers to adjust block heights
+0, 2.0, 2.5 and 3.0 degree pivot blocks included
+Heavy Duty, Self Lubricating Ball Cups are also included
Old 06-02-2005, 10:11 AM   #11505
rc-zombies's Avatar
I think that was only half the reason for moving it forward. the other reason was that the pinion grub screw would not make contact with the flat portion of the motor arm.
