Like Tree5Likes
Old 05-31-2005, 11:56 PM   #11476
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
Here are the part numbers and prices from RainbowTen:
73109 PRO4 UPPER DECK 2.25mm(WOVEN GRAPHITE) - $25.85
75192 PRO4 ALUMINUM MOTOR MOUNT PURPLE - $18.28
atomic80 is offline   Reply With Quote
Old 05-31-2005, 11:58 PM   #11477
moot's Avatar
i have a spool in it but its still and understeering pig.
moot is offline   Reply With Quote
Old 06-01-2005, 12:31 AM   #11478
Lokanas's Avatar
try less droop as mentioned above. If anything else won't help to increase front on-power grip, you'll have to decrease rear grip. You may even play with rear diff tightening or less toe-in to get slightly more on power oversteer.
Just don't overdo it.
Lokanas is offline   Reply With Quote
Old 06-01-2005, 12:43 AM   #11479
Skill's Avatar
Originally Posted by tony2
Skill,
Roll centers- the easy answer is yes. but its more complicated, as you need grip to produce corner speed, and when u need grip roll center is a change u can make. but also shocks setting dont forget those.
Thanks, I run foams on carpet so there's plenty of grip. Last meeting the car was rolling in the corners so I stiffened up the suspension front and rear and then later on stood the shocks up more but I still didn't feel the really quick change of direction and blinding corner speeds that I wanted so I was just wondering if there was a way I could get it. Also, would it have a similar effect if I was to raise the upper camber links?
Skill is offline   Reply With Quote
Old 06-01-2005, 04:56 AM   #11480
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Moot, post your setup, makes it a bit easier, also what class are you running and on what surface.
dontfeelcold is offline   Reply With Quote
Old 06-01-2005, 06:22 AM   #11481
brushless's Avatar
Default New version diff
Does anyone know the part number for the newer version of the diff kit or the part numbers for the individual pieces? The only things I need are:
New version diff bolt
New version retainer nut
Spring
Both ball sizes
D-Rings
Is the whole kit 75141 or is that the old version?
brushless is offline   Reply With Quote
Old 06-01-2005, 06:34 AM   #11482
brushless, I bought the new diff screw and heavy-duty nut which comes in a kit (73522) for $3.68 from RainbowTen too. If you want, you could probably get by with the one from Team Associated which was like $1.60 and could be found locally. The part number for that is 6575.
Old 06-01-2005, 12:34 PM   #11483
pro4racer's Avatar
hi
i know this has nothing to do with the pro 4 but here goes
where can i find a spare fan for the integy octane2 as ive been pc world currys dixons everywhere and cant find one.
its a 5v 0.20 amp fan
thanks
also i did the uppder deck mod with drilling the holes out and the cone washer and o-ring one just wondering wot other mods there are that i need to do.
thanks again
pro4racer is offline   Reply With Quote
Old 06-01-2005, 12:59 PM   #11484
rc-zombies's Avatar
Originally Posted by pro4racer
hi
thanks
thanks again
Integy sell the replacement fan...don't know if they have the right one to fit the Octane.
on the upperdeck mod... no other mod is needed that I know of.
Old 06-01-2005, 03:53 PM   #11485
adamkerrnz's Avatar
I bought myself a TC3 diff rebuild kit. i used the thrust bearing, spring, nut and the bolt. it works like a dream. i did this after the stock pro4 bolt's head snapped off somehow
adamkerrnz is offline   Reply With Quote
Old 06-01-2005, 04:54 PM   #11486
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
hpi v. ae springs:
hey i see in thad's setup for socal that he uses ae gold spring. what is closest hpi spring?
how close are hpi to ae springs? my friend was like "just use ae springs if you have them", but i dont, so are hpi and ae springs close or whats the deal?
thanks
floodo1 is offline   Reply With Quote
Old 06-01-2005, 06:20 PM   #11487
moot's Avatar
i'm back to the box setup.but with a spool,a 2mm chassis,no centre post,copper sway bar on the front and black on the rear.
i'm currently using cs-27's but will goto 22's now that its colder here.i normally run in 19t but like to have a go in mod with a 6t everynow and then.the surface that i run on is concrete that would be medium traction (at a guess)the location used to be tennis courts
Old 06-01-2005, 06:20 PM   #11488
Rcjunk-yard's Avatar
hi
thanks again
You might try www.cyberguys.com they sell a lot of fans.
Rcjunk-yard is offline   Reply With Quote
Old 06-01-2005, 07:50 PM   #11489
what about tyre inserts? Also, does your rear diff slip of the line when you accelerate?
Old 06-01-2005, 08:20 PM   #11490
moot's Avatar
the inserts are mediums. and from a standing start its very taily.if i have the rear diff to tight would it push in the corners like it does? because thats what i'm thinking
