Old 05-30-2005, 08:58 PM   #11461
GRF
GRF's Avatar
Default Question on Camber Links
I have a couple of questions. Does shortening the camber links generate more roll or reduce roll? Also, how can raising or reducing the inner camber link height affect roll?
GRF is offline   Reply With Quote
Old 05-31-2005, 04:44 AM   #11462
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
shortening the camber links reduces roll as the car rolls, raising the inner camber link increases roll.
dontfeelcold is offline   Reply With Quote
Old 05-31-2005, 04:48 AM   #11463
tony2's Avatar
this is how i see it and work off, i shorter camber link length will generally increase roll, i longer link with make the car feel stiffer. as for the roll center a lower roll center (less shims) will equall more roll and more grip as the weight is above the pivot points. for the pro4 i havent ever need to shorten the link length, but have adjusted the roll centre.
anyone else want a crack?
Anthony Campbell
Ryper Hobbies l AKA | AE
tony2 is offline   Reply With Quote
Old 05-31-2005, 06:44 AM   #11464
Skill's Avatar
So if I was to raise all the roll centres then it would give the car less roll and therefore better corner speed and change of direction?
Skill is offline   Reply With Quote
Old 05-31-2005, 08:20 AM   #11465
Default Considering a Pro 4?
I am getting rid of my 04 Xray (after 4 months) as it is just to hard to keep setup. Prior to the Xray I had various TC3 configurations (Xtreme & BMI) I like the looks of the Pro 4 and several people at my local track have them hooked up. Can anyone give me an idea as to how similar the setup is to the TC3?
Paul
pcmlc is offline   Reply With Quote
Old 05-31-2005, 08:54 AM   #11466
brushless's Avatar
Does anyone know the part number for the newer version of the diff kit or the part numbers for the individual pieces? The only things I need are:
New version diff bolt
New version retainer nut
Spring
Both ball sizes
D-Rings
Is the whole kit 75141 or is that the old version?
brushless is offline   Reply With Quote
Old 05-31-2005, 11:17 AM   #11467
rc-zombies's Avatar
anybody need a heatsink motor mount?
made by Square.
reg. $30 new
selling for $20.00 shipped.
practically still new. only 1 racing day on it.
Old 05-31-2005, 01:00 PM   #11468
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
hey is the 2.25mm upperdeck avail yet? if so where from?
what about the 2005 motor mount?
i saw that orion has the part numbers for these parts on their website but im not sure if they are avail or where to get them?
thanks
floodo1 is offline   Reply With Quote
Old 05-31-2005, 01:09 PM   #11469
rc-zombies's Avatar
thanks
yes...they are both available overseas. I got mine from Rainbowten in Japan.
Old 05-31-2005, 05:36 PM   #11470
floodo1's Avatar
can you tell me the prices in USD?
Old 05-31-2005, 06:17 PM   #11471
tc3 racer sc's Avatar
thanks
hey i got my upper deck at rcmodel in hongkong
tc3 racer sc is offline   Reply With Quote
Old 05-31-2005, 06:28 PM   #11472
wagonman72's Avatar
I'm suprised you haven't designed a chassis of our own yet Josh!
Hey how's the car working for you?
wagonman72 is offline   Reply With Quote
Old 05-31-2005, 08:02 PM   #11473
tony2's Avatar
Skill,
Roll centers- the easy answer is yes. but its more complicated, as you need grip to produce corner speed, and when u need grip roll center is a change u can make. but also shocks setting dont forget those.
Anthony Campbell
Old 05-31-2005, 09:39 PM   #11474
moot's Avatar
how can i make my car turn tighter under power? it needs to turn much tighter.
moot is offline   Reply With Quote
Old 05-31-2005, 11:51 PM   #11475
a spool helps or less front droop,
