Like Tree6Likes
Old 05-28-2005, 10:01 AM   #11446
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally Posted by EngTat
yalar yalar know d lar
hahahar tell you before cheap stuff doesn't mean that good stuff sometime will be even worst hahahar
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 05-28-2005, 11:42 AM   #11447
Trader Rating: 17 (100%+)
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 05-28-2005, 06:06 PM   #11448
Guo Chean's Avatar
hahahar i will help u kick chun assss hahahar for the cheating pro 4
Old 05-28-2005, 11:49 PM   #11449
Send a message via Yahoo to GTIRACER
Default Hot Bodies
Im sure most of you know but HPI wont be making a pro 5. They have teamed up /merged with Hot Bodies and that will be there high end line starting with the Cyclone Hara is driving right now. HPI will focus in the entry level/ RTR market after the Pro4. Hara was flying though and the current belt drive car is based on the Pro4
GTIRACER is offline   Reply With Quote
Old 05-29-2005, 12:03 AM   #11450
axel's Avatar
Good news...So the pro4 won't be replaced...looks like HPI/HB will have 2 dominating cars on the market, and both different drivetrains.
axel is offline   Reply With Quote
Old 05-29-2005, 12:58 AM   #11451
adamkerrnz's Avatar
Got myself some nice aluminium knuckles today. they look great!
adamkerrnz is offline   Reply With Quote
Old 05-29-2005, 07:29 AM   #11452
Looks nice, but I would rather change the c hub first cos they break more often than the knuckles.
ah_liang is offline   Reply With Quote
Old 05-29-2005, 09:25 AM   #11453
nasri_saini's Avatar
nasri_saini is offline   Reply With Quote
Old 05-29-2005, 09:48 AM   #11454
nw racer's Avatar
I have a question for you guys. I just picked up a Pro 4 about 2 weeks ago and have heard back and forth about the rigidity of the chassis for carpet racing. I have seen from some that the BMI 3mm is the way to go but others seem just fine with the factory stock chassis. What is better for carpets.
Also, what is the shock oil weight and springs most of you are running on carpets, I seem to have too much chassis roll.
nw racer is offline   Reply With Quote
Old 05-29-2005, 09:55 AM   #11455
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Alum C-hubs work better if the knuckle is plastic...that way if you strip the king pin you just have to replace the knuckles on each strip
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 05-29-2005, 01:03 PM   #11456
Guo Chean's Avatar
what brand is that? for the aluminium knuckle
Old 05-29-2005, 07:59 PM   #11457
brushless's Avatar
Default New Pro 4 diff kit
Does anyone know the part number for the newer version of the diff kit or the part numbers for the individual pieces? The only things I need are:
New version diff bolt
New version retainer nut
Spring
Both ball sizes
D-Rings
Is the whole kit 75141 or is that the old version?
brushless is offline   Reply With Quote
Old 05-30-2005, 06:59 PM   #11458
tc3 racer sc's Avatar
Talking graphite camber plate
what a good basic setup on the camber plate to start and which hold should i start in since it got 4 holes can some one explain or a drawing thxs reggie
tc3 racer sc is offline   Reply With Quote
Old 05-30-2005, 07:11 PM   #11459
moot's Avatar
whats the difference between the high traction arms and normal arms? do they look any different?
moot is offline   Reply With Quote
Old 05-30-2005, 08:46 PM   #11460
normal arm are graphite arm, high traction arm are plastic nylon arm if not mistaken
cheers
Tamiya TB Evo 5
