Old 05-25-2005, 12:43 PM   #11401
newnew's Avatar
what does the Heavy Duty, Self Lubricating Ball Cups do????
newnew is offline   Reply With Quote
Old 05-25-2005, 01:44 PM   #11402
dizzy1's Avatar
Trader Rating: 24 (100%+)
To adjust the diffs, do like above by popping the ball end then use the cheap "L" allen key from the kit to adjust the front is the same, if you use this allen key instead, you don't have to remove the hinge pin.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 05-25-2005, 03:48 PM   #11403
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Where can I find the TIR Titanium Bones for the front of the Pro 4? Any help would be appreciated.
cpatel529 is offline   Reply With Quote
Old 05-25-2005, 03:51 PM   #11404
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
You can find titanium dogbones on www.rc-mushroom.com in the car hopup section from Square. They're spendy though! $42!
atomic80 is offline   Reply With Quote
Old 05-25-2005, 04:42 PM   #11405
kewdawg's Avatar
No. He's referring to the Pro 4 bones made by TIR (Titanium Racing). Here ya' go:http://www.racing-cars.com/usa/main.asp
Look under "manufacturer" for TIR Titanium Racing.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-25-2005, 05:17 PM   #11406
Sorry about that...I read it too fast. Didn't see the "TIR" part. Well, there's an alternative.
Old 05-25-2005, 06:33 PM   #11407
kewdawg's Avatar
No biggie. Just clarifying.
Quinn Moon
Old 05-25-2005, 09:24 PM   #11408
tony2's Avatar
does everyone think that the 05 model has fixed some problems with the chassis tweak?? i mean i have made all the mods on my top deck that the new model has and it still tweaks, but i dont have the alloy camber plates.. so im not sure wether to upgrade or what any thoughts??
Anthony Campbell
Ryper Hobbies l AKA | AE
tony2 is offline   Reply With Quote
Old 05-25-2005, 09:35 PM   #11409
adamkerrnz's Avatar
Extremely sorry if this has been asked, but does anyone have a link to instructions so i can mod my upper deck like on hara's pro 4? and also the parts (screws) needed?
adamkerrnz is offline   Reply With Quote
Old 05-25-2005, 10:00 PM   #11410
newracer's Avatar
R/C Tech Charter Subscriber
Hpi Pro 4
newracer is offline   Reply With Quote
Old 05-25-2005, 11:20 PM   #11411
RCknight's Avatar
Default Does the Pro 4 have tweeking issues?
I seem to read this all the time. I don't hit the walls as much anymore so should it be a problem for me?
RCknight is offline   Reply With Quote
Old 05-26-2005, 07:32 AM   #11412
Trader Rating: 49 (100%+)
Recently picked up a Pro 4. I need a general setup for asphalt track on rubber tires (cs-27s). I am using a diff in the front. Also have the 2.5mm top deck on the car(to help with tweak).
I have all the toe plates, anti-squat plates and spring so hopefully I can do whatever setup is recommended.
Can someone point me to a good one?
thanks.
rodneybarrett is offline   Reply With Quote
Old 05-26-2005, 07:55 AM   #11413
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
I have run the kit setup with really good results. But, if you want to try some different things try some of the setup on HPI's site.
http://www.hpiracing.com/setups/su-m.php#Pro%204
[url]http://www.thercspeedway.net/[/url]
jt6 is offline   Reply With Quote
Old 05-26-2005, 08:01 AM   #11414
Frank McKinney's Avatar
They are molded from a plastic that includes molybdemum (sp?), which helps lubricate the ball joint/cup contact surfaces, like molybdenum grease would.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 05-26-2005, 08:21 AM   #11415
coastaltony's Avatar
If the track is smooth, stick to around 5-5.5mm RH, 3-3.5 droop, I had AE red/front, blue/rear springs, 1.5 front block, 2.5 rear block.Your standard camber setting. Keep an eye on the droop grubs. If who-ever built the kit was sloppy with a tap the grubs may be loose. NOT GOOD.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
