Like Tree5Likes
Old 05-24-2005, 07:58 AM   #11386
rc-zombies's Avatar
Originally Posted by RCknight
I want a 05Pro4. Where can I see some pics and when will it be out? I'll BMI it there after.
Thanks.
basically the same...just for a bunch of option parts included...check out the HPI japan website... us/euro version will differ from the japan spec car.
Old 05-24-2005, 02:44 PM   #11387
RCknight's Avatar
Default RCZombies....
Will it be offered in the US? What aption parts are worth it? You got a pic of your car? I would be interested in seeing it. Thanks.
RCknight is offline   Reply With Quote
Old 05-24-2005, 02:52 PM   #11388
rc-zombies's Avatar
don't have pics yet..but soon
The USA/ Europe 2005 Spec Pro 4 will have the following:
All standard Pro 4 features
+2.5mm main chassis (original main chassis) japan edition is 2mm
+new upper deck (as shown -- more lateral flex, same fore to aft stiffness, reduced chance of tweaking on impacts, with cone washers and o-rings over the steering posts as used by Hara)
+new motor mount (as shown)
+new shocks (fluorine coated, new bladders, new pistons, new shafts, as shown)
+Delrin diff out drives
+new 1 piece aluminum rear input shaft (combines spur adapter and shaft, with solid pins, much more rigid gear mounting, different than Japanese spec parts)
+new aluminum front input shaft
+new diff nut and new diff screw (larger screw size + T-nut)
+aluminum steering servo mounts
+Spool and One Way will be included
+full range of pivot block spacers to adjust block heights
+0, 2.0, 2.5 and 3.0 degree pivot blocks included
+Heavy Duty, Self Lubricating Ball Cups are also included
Old 05-24-2005, 09:07 PM   #11389
andyh's Avatar
Default Hara Pro 4 Box
Hara Pro 4 Box
andyh is offline   Reply With Quote
Old 05-24-2005, 10:24 PM   #11390
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
does anyone have any idea of setting a pro 4 running in technical carpet? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 05-25-2005, 01:18 AM   #11391
RCknight's Avatar
Default RC-zombies...
do you know if the new motor mount works with the BMI chassis? Does the new diff bolt and t-nut woek with the older stock diff outdrives? Is there much wheel base adjustment on the Pro 4. Looking at the pics, I don't see any wheel base spacers. One more thing, does the Pro 4 have external diff adjustment? Sorry for all the questions.
Old 05-25-2005, 03:46 AM   #11392
Skill's Avatar
The stock car does have some small adjustment of the wheelbase by using the spacers in the rear hubs. However, the Team PRP chassis (www.teamprpracing.com) has a much larger adjustment for wheelbase as it allows different mounting holes for the pivot blocks.
You should have no problems using the new motor mount with the BMI chassis as all the mounting holes etc. will be the same.
Skill is offline   Reply With Quote
Old 05-25-2005, 07:46 AM   #11393
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Default Need Chassis.
Does anyone have any extra 2.5 mm Pro 4 chassis that they arent using that they would be willing to sell? On mine that i have the front set of screws that holds one of the front suspension mounts on the chassis have stripped out so I cannot take them out. Does anyone know a wasy to preserve my chassis and get the screws out? Any help would be highly appreciated.
Chirag
cpatel529 is offline   Reply With Quote
Old 05-25-2005, 07:48 AM   #11394
Nipple's Avatar
Chirag
You can look for something call screw extractor........
Nipple is offline   Reply With Quote
Old 05-25-2005, 08:01 AM   #11395
JohnB's Avatar
R/C Tech Charter Subscriber
Chirag
You can use a dremel tool and cut a slot in the head of the screw. Then use a flat blade screw driver to get the screw out.
If your very careful you can usually get away with just a small nick in the chassis.
Good luck
take care
john
JohnB is offline   Reply With Quote
Old 05-25-2005, 08:02 AM   #11396
Send a message via ICQ to atomic80 Send a message via AIM to atomic80 Send a message via Yahoo to atomic80
Does anyone know where I can get a HPI aluminum bevel gear shaft (16T/front) part number 31422? This is the last item that I need to upgrade my Pro 4 to 2005 specs. RainbowTen says that HPI has not said when they'd be re-releasing this item. Any ideas?
atomic80 is offline   Reply With Quote
Old 05-25-2005, 08:29 AM   #11397
rc-zombies's Avatar
Good thing I was able to get one...
if I find one I'll let you know....
Old 05-25-2005, 09:58 AM   #11398
newracer's Avatar
Chirag
get an old "L" allen key, put a drop of CA on the end and insert it into the screw, wait overnight for it to dry and then remove the screw.
newracer is offline   Reply With Quote
Old 05-25-2005, 12:01 PM   #11399
kewdawg's Avatar
Originally Posted by EngTat
always heard of 24 and 28 mm foam tires, can anyone tell me where i can one. tq
TRC (Trinity) now produces 28mm foam tires (black, spoked rims). Also, Parma and Jaco sell 28mm foam tires (white aero-dish rims). Your LHS should carry them or be able to get them. Plaid (50/40 shore) front and Purple (40 shore) rear are the standard. Use Cyan (50/35 shore) front and Magenta (35 shore) rear for tracks with less traction.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-25-2005, 12:16 PM   #11400
kewdawg's Avatar
Yes. You'll have to pop off the rear camber link and pull the CVD shaft from the outdrive to adjust the rear. The front is slightly difficult. You'll have to, again, pop off the camber link. Now, remove the hinge pin connecting the c-carrier to the front arm (careful not to lose the small, silver spacer on the hinge pin). Lift the c-carrier / steering knuckle / CVD assembly out of the arm and outdrive to adjust the diff.
Quinn Moon
