Old 05-19-2005, 02:49 PM   #11326
fjm9898's Avatar
would the original pro4 with 3mm top plate and chassis be better for carpet and then grab an 05 spec for asphalt?
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 05-19-2005, 02:54 PM   #11327
rc-zombies's Avatar
Yes. 3mm upperdeck will definately stiffen the chassis.
Old 05-19-2005, 02:59 PM   #11328
fjm9898's Avatar
there is a guy at my track that is going to sell me his pro4 with both 2.5mm chassis and top plate and 3mm chassis and top plate with bunch of parts and what not for 300 and so i wanted to know if i should grab that up for carpet racing since is has both 2.5mm and 3mm chassis and top plate and then get a 05 for the days i run on asphalt as the 05 would probably be better for pavement
Old 05-19-2005, 03:01 PM   #11329
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
i would go with the one for 300... extra chassis costs a lot of money, especially 3.0 mm. you will change chassis, i don't think it is reasonable to have another pro4, unles you can afford without any problems
Exe is offline   Reply With Quote
Old 05-19-2005, 03:06 PM   #11330
fjm9898's Avatar
then should i get some of the 05 stuff like the 2.25mm top plate and 2mm chassis for running on asphalt?
Old 05-19-2005, 03:06 PM   #11331
rc-zombies's Avatar
yea..sounds like a very good deal..especailly with 2.5, 3.0mm chassis and upperdeck.
to run asphalt all you'll need is install the 2.5mm chassis and the newly released 2.25mm upperdeck.
but like Exe said..if money is no object...might as well get the 05 or Hara Kit also... while you're at it... want to buy me one too...
Old 05-19-2005, 03:08 PM   #11332
Exe
Exe's Avatar
me cylcone please
Old 05-19-2005, 03:33 PM   #11333
loopedeloop's Avatar
Default chassis flex
Hi Guys
Could someone explain to me please, why lateral flex in a chassis is a good thing>
I would have thought as in a 1:1 car that the stiffer the chassis the better as it allows the suspension to do its job properly.
Surely given the correct spring/shock/oil it would be better to have no flex, as flex only aids an untuned chassis??
I'm fairly new to the tech side of r/c so would appreciate a good explanation.
I run the 2004 spec 1.1 pro4 in std trim except for square and hpi alloy parts on asphalt with foams and wonder what the benefit would be of going to a lighter chassis.
Geoff
loopedeloop is offline   Reply With Quote
Old 05-19-2005, 03:39 PM   #11334
Exe
Exe's Avatar
i would like some pro's to anwer this one i pretty much agree that suspesnio should make all the job...no?
Old 05-19-2005, 04:16 PM   #11335
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Anybody running a GTX in their Pro4? Got any pics? I just want to see how its laid out, also how does the GTX rate since all I'm use to is a couple of Keyence Zero V Extremes? -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-19-2005, 04:21 PM   #11336
rc-zombies's Avatar
I have my GTX installed like this:
Now have the Hara Twister 2 installed.
Old 05-19-2005, 04:28 PM   #11337
JayBee's Avatar
Post
Thanks zombies ... I need to find the Square bumper brace and those graphite pieces that are over the diff cases -JB
Old 05-19-2005, 04:33 PM   #11338
rc-zombies's Avatar
Contact AllSpeed Hobbies.
they might have the parts you need.
Old 05-19-2005, 04:35 PM   #11339
JayBee's Avatar
Thumbs up
Thanx again -jb
Old 05-19-2005, 05:03 PM   #11340
fjm9898's Avatar
hehe i like having two cars mainly just for a backup but i race carpet and paved back and forth alot so it would be nice not haveing to swtich chassis and setups all the time. like i do with my tc3s. bmi for carpet and the ft for asphalt
SEO by vBSEO 3.5.0
