Old 05-09-2005, 10:11 PM   #11206
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally posted by axel
When do people use the pro4 weights? what does it do? more downforce?
Most races have a weight limit rule of 1,525 grams, since pro 4 out the box is lighter, you add weight on a balanced weight distribution.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 05-10-2005, 06:07 AM   #11207
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
Default HEAVY BALL ENDS
Can someone tell me the part # for the Hpi heavy ball ends.
Mach10_shooter is offline   Reply With Quote
Old 05-10-2005, 08:26 AM   #11208
Erik Shauver's Avatar
Mach10_shooter: A301 for the steering links and A302 for the upper links. (They both come 8 pcs to a set)
JayBee:
Re: The center stiffener post is purely optional.
Re: the gear brace, if you purchased your kit in the USA and you have the older version with no brace included, give US customer service a call.
Re: The gear shimming… for the front one-way start with 0.3mm on the gear side and 0.2mm on the longer side. The front input shaft requires no shims. For the rear, the input shaft should be per the manual. The diff should get 0.2mm on the gear side and 0.3mm on the longer side. Note, if you experience any breakage of the front gears, add more shims to reduce the gear backlash. No backlash is okay and will yield more durability (with a slight efficiency cost).
Re: your car pictures, it looks as though your battery strap is a bit loose. See the attached .jpg for possible cause. The manual is incorrect for step 41.
Re: Complete spring set is HPI Part # 75175 (7 pairs), you’ll need 2 if you want 4 of each spring.
dontfeelcold: A spool is included with USA 2005 spec (I believe will be called Hara Edition)
Pro4: The USA spec kits use MIP CVD’s. The Asian market (+Austrailia) kits use universals.
cpatel529: Any gear shims needed come with the kit as standard parts.
rc-zombies: The new shocks should be about 56.5 center to center. Set longer if running lots of droop.
Erik Shauver is offline   Reply With Quote
Old 05-10-2005, 08:37 AM   #11209
rc-zombies's Avatar
Erik...
what's ETA on the 05 US kits?
Old 05-10-2005, 08:59 AM   #11210
TFR
TFR's Avatar
Originally posted by rc-zombies
Erik...
Ramon, you got any new pictures of your 2005 spec Pro 4?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 05-10-2005, 09:03 AM   #11211
rc-zombies's Avatar
nope...nothing new...except for the one I just built with 05 Spec option parts...
Old 05-10-2005, 10:25 AM   #11212
Erik...
T- 2 weeks
Old 05-10-2005, 10:32 AM   #11213
The Evicerator
How should the 05 version be geared?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 05-10-2005, 10:43 AM   #11214
racer's Avatar
when changing the roll centre on the car, is it necessary to change the height of the camber links as well?
Thanks in advance!
racer is offline   Reply With Quote
Old 05-10-2005, 10:58 AM   #11215
JohnB's Avatar
R/C Tech Charter Subscriber
Default Re: Rubber tires on carpet
Originally posted by JohnB
Front:
#2 pistons w/ 70 wt. oil, Assoc. Copper spring
#3 mount on tower and #1 on a-arm
2* caster and -2* camber
Camber link outside hole with 4mm spacer
1.5* toe block with .8 mm spacer (#4 washer) and wheels set at 0* toe.
5mm ride height and droop set to 1mm over ride height.
Rear:
#2 pistons w/ 50 wt. oil, Assoc. Red spring
#3 mount on tower and #2 on arm.
-2* camber
Camber inside on inner mount and hub. with 3mm spacer.
2.5* toe block with .8mm spacer
5mm ride height and droop set to 2mm over ride height.
take care
john
Had a great race last Saturday. Setup turned out to work great. I was a little worried about the driving difference of the rubber tires since I was so use to foams. Turned out I could drive the car just as hard into the corner with no worries of traction rolling. Car was SOLID!!!
take care
john
JohnB is offline   Reply With Quote
Old 05-10-2005, 11:29 AM   #11216
Evicerator: Feel free to gear taller by 1 tooth. If in doubt, don't hesitate to consult your manual
racer: When you lower the inner camber link, you will raise the static roll center. When you lower the suspension pivot block, you will lower the static roll center. In transition it is a much different picture. Changing one or the other should have a bigger feel difference than doing both at once.
Old 05-10-2005, 02:45 PM   #11217
racer's Avatar
Thanks for the explanation, really appreciate it. i guess my actually question would be.
since i have changed over to a 3mm lower chassis. will the setting be altered?
i would like to keep the stock settings. how would i achieve this?
Thanks in advance!
Old 05-10-2005, 03:42 PM   #11218
racer: For a 3mm chassis I would start close to this setup(Andy Moore, Cleveland '05) for the pivot block and camber ball heights.
Old 05-10-2005, 03:43 PM   #11219
rc-zombies's Avatar
Erik..
do you have an estimated price on the new 05 Spec.
Old 05-10-2005, 03:43 PM   #11220
racer's Avatar
Thank you!
