Like Tree5Likes
Old 05-09-2005, 03:44 AM   #11191
Nipple's Avatar
Originally posted by kewdawg
Nipple, I appreciate your effort, but you still haven't answered the question. I know what's available and what they do. I need to know the difference between them, individually - like, which are harder or softer, less or more resisance? Is "30" harder or softer than "60"?
Oh ok, 30 is the softest, 60 is the hardest.
So for the o-rings, the softer it is, the less resistance it has.
For the bladder, the harder it is, the higher is the pressure.
Hope I've answered your question.
Nipple is offline   Reply With Quote
Old 05-09-2005, 04:47 AM   #11192
kewdawg's Avatar
For the bladder, the harder it is, the higher the is the pressure.
Yes. Thanks, man.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-09-2005, 05:14 AM   #11193
newracer's Avatar
R/C Tech Charter Subscriber
Originally posted by dontfeelcold
Can you confirm that the '05 Spec comes with a spool?
Originally posted by Erik Shauver
Keep in mind that this release info posted previously is for the Japanese market 2005 spec Pro 4.
The USA/ Europe 2005 Spec Pro 4 will have the following:
All standard Pro 4 features
+2.5mm main chassis (original main chassis)
+new upper deck (as shown -- more lateral flex, same fore to aft stiffness, reduced chance of tweaking on impacts, with cone washers and o-rings over the steering posts as used by Hara)
+new motor mount (as shown)
+new shocks (fluorine coated, new bladders, new pistons, new shafts, as shown)
+Delrin diff out drives
+new 1 piece aluminum rear input shaft (combines spur adapter and shaft, with solid pins, much more rigid gear mounting, different than Japanese spec parts)
+new aluminum front input shaft
+new diff nut and new diff screw (larger screw size + T-nut)
+aluminum steering servo mounts
+Spool and One Way will be included
+full range of pivot block spacers to adjust block heights
+0, 2.0, 2.5 and 3.0 degree pivot blocks included
+Heavy Duty, Self Lubricating Ball Cups are also included
While some will say it is simply the "same old, same old" Pro 4, it does address exactly what a lot of our customers and team drivers wanted changed. It moves the weight balance forward, the motor is easier to access, the diff holds its settings better, the shocks are even easier to rebuild and maintain, the shock are even smoother, the drive train spins more true, the drive train is even lighter, a spool is included, and more suspension adjustments are possible right out of the box. The only items it is really missing to be competitive on any surface would be a full range of tuning springs (or a 3.0mm chassis and front diff for foam tire carpet racing).
newracer is offline   Reply With Quote
Old 05-09-2005, 05:18 AM   #11194
kewdawg's Avatar
What are you - some kind of non-believer?
Quinn Moon
Old 05-09-2005, 06:50 AM   #11195
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally posted by JayBee
New Yoke BD or '05 Pro4, HMMM Anyhow, what's the biggest 64p spur I can run? -JB
You can use 104T 64P spur for low turn motors
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 05-09-2005, 08:18 AM   #11196
I got two questions-
1. What's the deal with the little ?chassis stiffener? thingie; is it needed?
2. Anybody have any problems with the one-way's bevel gear stripping; I heard the fix was a plate that braces up against the back-side of the bevel gear. Anyone recall the part # for it? -JB
Call HPI and they will probably send you the backplate and v1.1 gears free. just tell them u got one of the old version kits. they should send it to you for free.
ATXPro4 is offline   Reply With Quote
Old 05-09-2005, 08:29 AM   #11197
rc-zombies's Avatar
Default Re: FINALLY...
Originally posted by cpatel529
getting a Pro 4. Worked out a deal and it should be arriving next week.
Do people recommend getting the Spec 2005 front and rear gear sets? I emailed rainbow ten about it but they only have the rear. Cant wait to get it and start to work on it.
Chirag Patel
You'll only need the front... no problems with the gears in the rear... the one-piece input shaft/spur gear adapter is great to have instead for the rear.
Old 05-09-2005, 08:30 AM   #11198
rc-zombies's Avatar
New Yoke BD or '05 Pro4, HMMM ..... -JB
I have both....
Old 05-09-2005, 04:47 PM   #11199
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Originally posted by rc-zombies
I have both....
Damn you... But I got the SDW I'm actually thinking about getting the PRP set-up; that looks NIIICE -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-09-2005, 05:08 PM   #11200
rc_bam226's Avatar
Jaybee you should know, Ramon has got EVERYTHANG
Ramon, you know I'm just messin' with you man
rc_bam226 is offline   Reply With Quote
Old 05-09-2005, 07:40 PM   #11201
axel's Avatar
When do people use the pro4 weights? what does it do? more downforce?
axel is offline   Reply With Quote
Old 05-09-2005, 07:44 PM   #11202
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
I beleive you now, its just I get lazy and don't read everything.
Where did the post from Erik come from?
dontfeelcold is offline   Reply With Quote
Old 05-09-2005, 08:51 PM   #11203
rc-zombies's Avatar
Old 05-09-2005, 08:53 PM   #11204
rc-zombies's Avatar
weights are use to balance the chassis...the batteries is heavier than the motor electronic side... I add almost 1 oz+ to this side .
Old 05-09-2005, 08:54 PM   #11205
rc-zombies's Avatar
....Where did the post from Erik come from?
from the 2005 Spec Pro4 thread...
