Old 05-01-2005, 07:31 PM   #11101
rc-zombies's Avatar
Originally posted by newracer
Is the 2.5mm upper deck out now the same as the one that will be on the 2005 edition?
no the 2.5mm upper deck is different than the 05 edition. 05 edition is 2.25mm and had the o-ring and upperdeck mod.
Old 05-01-2005, 09:35 PM   #11102
AMG Racer...Are you using a one way or a diff in the front?...If you are using a one way you should be using the aiioy backing plate.If using a diff make sure you are using 1.1 gears.Put your finger over the small gear on the input shaft then wiggle the diff gear...there should be a slight amount of movement between the two gears.if there is to much check the diff gear for side to side movement and shim as needed.If side to side movement is okay you might have to shim the small gear on the input shaft.See me at Logan or Wynum if you are not sure.
Bob
Barger is offline   Reply With Quote
Old 05-01-2005, 09:37 PM   #11103
Moot ...email me and I will send you a setup to try
vardy@internode.on.net
Old 05-01-2005, 10:19 PM   #11104
AMGRacer's Avatar
Bob
Thanks Barger. I think I have the mesh right, I just want to check how people are setting theirs. I am using the one-way with the backing plate, but I drive like a hacker and seem to eat gears at Hobby Station pretty regularly. Think I have done about 4 in 6 months, 2 last time out!
AMGRacer is offline   Reply With Quote
Old 05-02-2005, 12:04 AM   #11105
Nipple's Avatar
And the oring doesn't comes with the upper deck (if you buy it separately).
Nipple is offline   Reply With Quote
Old 05-02-2005, 12:24 AM   #11106
AMG Racer...Hobby Station is hard on cars....especially when you hit the ### wall!!!Most of the guys I know with Pro4s have done diffs there.You also need a completly different set up there.
Old 05-02-2005, 05:43 AM   #11107
murfy's Avatar
Trader Rating: 9 (92%+)
hey just wondering if any one has tryed the high traction arms with a foam set-up at a asphalt track??
good/bad????
Justin Murphy
Team Xray | Hudy | Hobbywing | Sanwa
murfy is offline   Reply With Quote
Old 05-02-2005, 05:59 AM   #11108
what is the advantage of running o rings under the top deck?more flex?
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 05-02-2005, 06:29 AM   #11109
Nipple's Avatar
From what I tested, I think the orings are more for reducing tweek caused by the flexing.
Just my 2cents......
Old 05-02-2005, 06:43 AM   #11110
you use them below the top deck and between the mountings
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 05-02-2005, 06:47 AM   #11111
Nipple's Avatar
No, above the top deck, between the top deck and the screw head / cone washer / washer.
Old 05-02-2005, 06:57 AM   #11112
ok i 4ort u meant bt the top deck and the mounts
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 05-02-2005, 07:04 AM   #11113
Coxy's Avatar
R/C Tech Charter Subscriber
If your still doing gears but haven't done anything about it, it won't fit itself. I would have a closer look at it and tighten up the mesh on the diff.
Coxy.
Coxy is offline   Reply With Quote
Old 05-02-2005, 04:19 PM   #11114
woozer71's Avatar
Trader Rating: 23 (96%+)
Hi guys hate to be a pain, but could you tell me what parts I need for the upper deck mod and how do I go about doing it. Or if someone could direct me to the right pages it would be greatly appreciated.
Fraser Coast RC Car Club/FCRCCC
VBC D06 / Xray T4 2013
Yokomo BMax2 ver 2 - Tamiya F104 x1
Sanwa MT-4
woozer71 is offline   Reply With Quote
Old 05-02-2005, 04:36 PM   #11115
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Question for peole with graphite drive shafts, do you still break gears?
dontfeelcold is offline   Reply With Quote
