Old 04-28-2005, 10:05 PM   #11056
BlackKat's Avatar
Originally posted by Guo Chean
how do you prevent chunk the foam tire?
Don't crash
See what everyone else at your local track runs. On carpet is usually Purple/Plaid or Double Pink Cyan
BlackKat is offline   Reply With Quote
Old 04-28-2005, 10:11 PM   #11057
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally posted by BlackKat
Either: Double Pink Rear and Double Pink/Orange (Cyan) Front
or: Purple Rear and Purple/Orange (Plaid) Front
Personally I like TRC's much more than the JACO's. JACO's are a bit grippier but chunk a LOT easier.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-28-2005, 10:14 PM   #11058
Guo Chean's Avatar
Don't crash
which type will used for front and rear? thanks because i have runing 3 year touring car i had never run foam tire on carpet so a bit blur which type can used
Old 04-28-2005, 11:23 PM   #11059
rc-zombies's Avatar
Originally posted by domo
teflon spray? graphite powder? boil them? soak in wd40? do nothing to them?
sorry, I should of said this is for the bevel gears, not the diff balls
looking to try anything really, as long as it will keep the drivetrain nice and free...
apply Paragon Ultralon to the gears. liquid PTFE dries dry and doesn't attract dirt. I also apply this to arm pins. pivot balls, just about anything that has moving parts.
Old 04-28-2005, 11:51 PM   #11060
Guo Chean's Avatar
Pro 4 2005 spec diff screw already officially announce by HPi it would be release on this coming month. the part num is 73522
Old 04-28-2005, 11:56 PM   #11061
jihernandez's Avatar
FINALLY!!!
Even if I was able to already break in the diff screw which prevents the usual diff screw loosening issue, would still want to have this as a permanent solution.
Although my Associated Diff Screw Assembly just arrived today (which was stated as a solution), I would still want this.
jihernandez is offline   Reply With Quote
Old 04-29-2005, 11:23 AM   #11062
kewdawg's Avatar
Originally posted by axel
i heard pro4's aren't that good with foams.
You heard wrong. The Pro 4 is excellent on foams, as any touring would be. It's just a matter of set-up. If, you need a starting set-up, just ask.
Here ya' go:
*Stock chassis & top deck*
-Springs: 25 lbs. - Front & Rear
-Shock oil: 35 wt. Trinity
-Pistons: #3 (stock)
-shock bladder: firm (stock)
-Shock positions:
front: tower / arm - #3 / inside hole
rear: tower / arm - #2 middle hole
-Ackermann:
steering plate / steering knuckle
stock postion / position #2
- camber link positions:
Front / Rear
standard standard
spacers under inside link:
Front / Rear
2mm / 3mm
-pivot block:
Front / Rear
3.0 / 2.5
pivot block spacers:
Front / Rear
(under front forward block only) .5mm / none
-Droop:
Front / Rear
3 / 3
Toe:
Front: out - 1 degree
Tires:
Front / Rear
Cyan - 50/35 shore / Magenta - 35 shore
*Use harder shores (plaid 50/40 shore & purple 40 shore) in warmer weather.
Note: This is a fast set-up. I used a 12t double, on a big track (150 x 85). If, the sterring is too agressive, use heavier oil, a stiffer spring, less droop and a harder tire up front.
Also: Camber: neg. 2mm - front & rear
Ride Height: 5mm - Front & rear
Caster Block: 0 degree
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-29-2005, 12:06 PM   #11063
kewdawg's Avatar
Guys, the previous is an aspalt set-up.
For Carpet: (stock / 19 turn )
- Use 30 lb. springs, 60 wt. oil (trinity) - front & rear.
- 2mm spacer under front inside camber link & .75 under rear inside camber link.
- 2.0 pivot block in rear.
- Use outside holes for shock towers and front arm location. Use middle hole in rear arm location.
- Camber is -1.5 mm front & rear.
- Ride Height: 5mm - front & rear
- Droop: 4mm - front & rear
- Caster blocks: 0 degree
Quinn Moon
Old 04-29-2005, 12:32 PM   #11064
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
ok, since your handing out setups.....lol....how bout a rubber asphalt one to try?
[url]http://www.thercspeedway.net/[/url]
jt6 is offline   Reply With Quote
Old 04-29-2005, 01:19 PM   #11065
kewdawg's Avatar
I haven't had the opportunity to run rubber on my Pro 4s, yet. If, you can wait a few months, after the hpi challenge, I'll have a dialed rubber set-up - (LoL). I live on the northeastern sea board (Pennsylvania, New Jersey, Delaware, New York, Maryland). Foam tires are the norm (asphalt or carpet). They give so much more traction. Try the stock set-up. It should be an excellent starting point. Sorry, i couldn't be more help, in that area.
Quinn Moon
Old 04-29-2005, 01:29 PM   #11066
jt6
jt6's Avatar
It's ok. The setup I am running is pretty decent. I copied it off of HPI's site.
I just like trying other's setup to get a different feel.
Most of the tracks around here pretty much stick with rubber on asphalt and foams on carpet.
Old 04-29-2005, 01:30 PM   #11067
loopedeloop's Avatar
Originally posted by loopedeloop
I treat all gears with CRC Teflon Dry-glide then use normal grease as well ( ceramic Grease )
Some people here use dry glide only. Dry glide leaves the gears very slippery to the touch.
Hope this helps
I have had a few PMs about dry glide so heres a link..................
http://www.crc.co.nz/item_prod.asp?pid=191
It comes in an aerosol rattlecan, sprays on wet , touch drys in 10min, absorbs into gear over 24hr by which time has fully cured.
It leaves the gears with a soapy/slippery feel, got to be good.
loopedeloop is offline   Reply With Quote
Old 04-29-2005, 01:38 PM   #11068
Post pics
ummmmmm dryglide , good s***!!
I even treat spur and pinion as it a dust free lube doesnt attract dust /dirt.
Hell I figure every lil bit helps right??
later
Old 04-29-2005, 01:43 PM   #11069
rc-zombies's Avatar
for those in the US...
Grainger sells something similar..
also in a spray can.
me I prefer the squeeze bottle applicator of the Paragon Ultralon.
Old 04-29-2005, 01:44 PM   #11070
kewdawg's Avatar
hey, if, there's no rule against foams at your track... RUN 'EM!!!
Quinn Moon
SEO by vBSEO 3.5.0
