Old 04-28-2005, 09:54 AM   #11041
rc-zombies's Avatar
Originally posted by fjm9898
about how much would it cost, and what is in the 05 the current one doesnt have, because i can get the current car for 175 new but so i am looking for the cheaper route
if you can get a Pro4 for $175..that is cheap. I would go that route. and upgrade to the Spec parts.
basically all you'll need is:
+new upper deck (as shown -- more lateral flex, same fore to aft stiffness, reduced chance of tweaking on impacts, with cone washers and o-rings over the steering posts as used by Hara)
+Delrin diff out drives
+new 1 piece aluminum rear input shaft (combines spur adapter and shaft, with solid pins, much more rigid gear mounting, different than Japanese spec parts)
+Spool
+full range of pivot block spacers to adjust block heights
+0, 2.0, 2.5 and 3.0 degree pivot blocks
Old 04-28-2005, 10:29 AM   #11042
Skill's Avatar
Thanks for that zombies, it looks as though it'll be cheaper to buy the whole set, are they going to be significantly better or not?
Skill is offline   Reply With Quote
Old 04-28-2005, 10:43 AM   #11043
Solara's Avatar
Trader Rating: 16 (100%+)
Originally posted by rc-zombies
Rookie..
wish I could be of help... haven't had a chance to run foams yet. majority of the outdoor track here run rubber tires.
I think those ball-cups were from Schumacher. with the stock ball-cups.. you may have to trim down the tops to make them work.
I know the Schumacher one are for the general ball cups problem that the stock HPI has....just not sure ppl use that for the lower SHOCK mount as well...
Beside, the stock HPI ball stud are too tall........that won't work.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-28-2005, 10:55 AM   #11044
rc-zombies's Avatar
yet to recieve mine..so I couldn't compare. I know the low-friction o-rings and new bladder work great... the o-rings are smooth as butter..
Old 04-28-2005, 10:55 AM   #11045
Solara's Avatar
Sorry.........wrong post.
Old 04-28-2005, 07:07 PM   #11046
Trader Rating: 16 (94%+)
i'm almost out of diff lube (2nd tub, white lid), what are some other alternatives that work just as well?
domo is offline   Reply With Quote
Old 04-28-2005, 07:12 PM   #11047
axel's Avatar
Um...bigger tube? I wonder if vasaline works?
axel is offline   Reply With Quote
Old 04-28-2005, 07:17 PM   #11048
teflon spray? graphite powder? boil them? soak in wd40? do nothing to them?
sorry, I should of said this is for the bevel gears, not the diff balls
looking to try anything really, as long as it will keep the drivetrain nice and free...
Old 04-28-2005, 07:19 PM   #11049
axel's Avatar
boil them is good softens them up so they won't crack easier. But when hitting those boards really hard... boil or no boil they will probaly break. Hopes this helps
Old 04-28-2005, 07:36 PM   #11050
loopedeloop's Avatar
I treat all gears with CRC Teflon Dry-glide then use normal grease as well ( ceramic Grease )
Some people here use dry glide only. Dry glide leaves the gears very slippery to the touch.
Hope this helps
loopedeloop is offline   Reply With Quote
Old 04-28-2005, 09:49 PM   #11051
axel's Avatar
I need help reducing understeer. Whenever i make hard rights i don't get the response i want as i do making left turns.
Old 04-28-2005, 09:52 PM   #11052
is your chassis evenly balanced? the weight of your cells along the left might be assisting your turn in....
other than that check the usual are all equal, camber/toe, ride heights, droop, steering endpoints, etc
Old 04-28-2005, 09:57 PM   #11053
axel's Avatar
everything seems alright to me. It isn't a huge problem, but it is still noticable. I find myself holding my wheel all the way to the right just to make a wide right.
Old 04-28-2005, 10:02 PM   #11054
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally posted by BlackKat
Either: Double Pink Rear and Double Pink/Orange (Cyan) Front
or: Purple Rear and Purple/Orange (Plaid) Front
Personally I like TRC's much more than the JACO's. JACO's are a bit grippier but chunk a LOT easier.
how do you prevent chunk the foam tire? which trc foam tire you recomemded? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-28-2005, 10:03 PM   #11055
BlackKat's Avatar
Sounds like a tweak issue.
Next time I see you I'll show you the "knife tweak" trick
BlackKat is offline   Reply With Quote
SEO by vBSEO 3.5.0
